#11
"tango4" wrote
I doubt it Steve. Once the drag pins are located the wing is stable. Ian Agreed 100%. Now, for all of us that fly gliders that have pins sticking out of the spar stub(s) (Glasflugel, Schempp-Hirth, Applebay, DG?), how many of you have not once accidentally pushed one wing out with the other while trying to assemble? Not me. That is how I found out. Put the more stable wing in first and take it off last is my motto. As for Schempp Hirth and those side hinged canopies... The L-33 Blanik is that way, too. But with it, you have to put the left wing on first if you want to use the retainer pin to hold the first wing in when yo put the second wing on. And if the fuselage is not rolled back clear of the trailer, the pilot gets to put the right wing on, run around the front of the trailer, and over to the left side. Then, open the canopy and use the assembly tool to pull the wing the rest of the way home. At least, that is how it works with the one at our field. Steve "No Wax" Leonard |
At 02:24 08 October 2003, Steve wrote:
'tango4' wrote I doubt it Steve. Once the drag pins are located the wing is stable. Ian Agreed 100%. Now, for all of us that fly gliders that have pins sticking out of the spar stub(s) (Glasflugel, Schempp-Hirth, Applebay, DG?), how many of you have not once accidentally pushed one wing out with the other while trying to assemble? Not me. That is how I found out. Put the more stable wing in first and take it off last is my motto. As for Schempp Hirth and those side hinged canopies... The L-33 Blanik is that way, too. But with it, you have to put the left wing on first if you want to use the retainer pin to hold the first wing in when yo put the second wing on. And if the fuselage is not rolled back clear of the trailer, the pilot gets to put the right wing on, run around the front of the trailer, and over to the left side. Then, open the canopy and use the assembly tool to pull the wing the rest of the way home. At least, that is how it works with the one at our field. Steve 'No Wax' Leonard The foolproof answer is this. If you hang toilet paper so that it pulls down in front, put the left wing in first; if you hang it so that it pulls down behind, put the right wing in first -- or vice versa. Have any of you queried the manufacturer? Some toilet paper hangers have done so! |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 08:10 PM |
Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 05:11 AM |
Drywall Gussets | Veeduber | Home Built | 5 | October 27th 03 09:03 PM |
Spitfire Mk XIV Wing Question | [email protected] | Military Aviation | 3 | September 19th 03 09:54 AM |
