LS4 - LS6 Fuselage size
Old October 27th 03, 11:53 PM
Mark
Default LS4 - LS6 Fuselage size
Simple question I hope.
In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ?
Cheers
Mark
Old October 28th 03, 12:05 AM
Stewart Kissel
The 6 is much narrower then the 4, to reduce wetted
area. If you fit in a 6, you will be able to get lost
inside a 4 cockpit-or as someone once posted here,
'Carry a bag of apples along with you'.
Cheers
Mark
Old October 28th 03, 03:38 PM
JJ Sinclair
Hi Mark,
I measured the difference when we had a 4 and a 6 in the shop. The LS-6 is 2
inches less in width and 2 inched lass in height.
JJ Sinclair
Old October 30th 03, 07:14 AM
Ernie Schneider
how would a LS6 cockpit compare with a Ventus 2a in width and height
thanks
Ernie
"When we come to the place where the road and sky collide"
"Throw me over the edge and watch my spirit fly"
"Mark" wrote in message
om...
Thanks Stewart and JJ............exactly what I was after.
Cheers
Mark
(JJ Sinclair) wrote in message
LS6a ?
Hi Mark,
is 2
JJ Sinclair
Old October 30th 03, 12:56 PM
Marcel Duenner
"Ernie Schneider" wrote in message news:4%1ob.1795$EY3.1046@edtnps84...
thanks
Ernie
Do some people not know how to use the net or are they just lazy?
LS4: 64cm / 83cm
LS6,7,8: 61cm / 80cm
S-H a: 54cm / 75cm
S-H b+c: 62cm / 81cm
ASW27+28: 64cm / 80cm
Old October 30th 03, 04:44 PM
Chris OCallaghan
Ernie,
here's a more qualitative answer from someone 6'2" and 225 lbs:
No, they don't compare. I can fly and LS-6 comfortably if I take the
seat back out. I can't even close the Ventus 2a canopy. (BTW, the 2bx
is very roomy.)
Cheers
Old October 30th 03, 05:38 PM
Robert Ehrlich
As far as I remember (flown a Ventus 2a twice in September, LS6 last
Saturday and a lot of other times) there is a little more space in
the LS6. The Ventus 2a didn't have an adjustable back rest, so I
had to add a cushion behind the parachute.
Old October 30th 03, 06:56 PM
Ernie Schneider
thanks Robert, and what would your "size" be ?
I fit comfortably in a LS6(had one for a year) and I am 178 cm/5'10"
Ernie
"Robert Ehrlich" wrote in message
Old October 30th 03, 06:57 PM
Ernie Schneider
Marcel, thanks for the legwork - highly appreciated
Ernie
"Marcel Duenner" wrote in message
om...
thanks
Ernie
LS4: 64cm / 83cm
S-H a: 54cm / 75cm
Who can identify this tube frame aircraft fuselage? Rob de Bie Home Built 5 January 13th 05 10:45 PM
Trike wing bolt size Aaron Smith Home Built 0 September 30th 03 04:02 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 04:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
Fitting canopy frame to fuselage advice Deputy Dog Soaring 5 July 27th 03 05:08 AM
