Jantars are back :)
Old December 8th 03, 07:53 PM
Mark James Boyd
Marc Till wrote:
Just remind how VNE varies with altitude !
Mark James Boyd a écrit:
Snip
Isn't Vne for this glider 255 kph?
Snip
Yep, I guess if you use the 2% per 1000 feet rule for TAS,
and you assume the Vne is a limitation based on flutter,
7000 feet is the absolute max altitude for this flight.
But I must say I don't entirely understand WHY flutter
is based on TAS. I also don't know if the IGC cares
if Vne is exceeded during a world record. It would
also be very hard to "prove" since GPS log only shows
groundspeed and never airspeed.
So part of my post was to say that I suspect he came close
to or exceeded Vne during the record attempt. This takes
some real confidence in the equipment and finesse about
its limits. Good for him, seriously. It's great to see
a new world record...
Old December 9th 03, 01:08 AM
Arnold Pieper
Gents,
As far as the pilot is concerned, VNE is always read directly as an IAS
limit, that's why it's painted on the ASI as a radial line.
I've never seen any remarks about VNE as "VNE is XXX at Sea Level at ISA".
There is no such thing.
VNE is always good as an Indicated figure, except at altitudes and airspeeds
where compressibility comes into play, in which case MMO (Maximum Mach
Operating speed) becomes the limiting factor, usually well above our speeds.
That happens at a certain altitude, up to which the pilot uses the Indicated
VNE as a limit, then after that the MMO.
Exception :
Certain models of sailplanes have limitations in IAS with altitude for
various reasons,
(Flutter is not the only factor in determining VNE).
When a sailplane does have this limitation, it will be expressed so in their
manuals, and there will be a table of limiting IAS x Altitude.
Tha Jantar Std 2 is not one of these, so, VNE is good as an IAS as high as
it will go.
The bottom-line is that it dependent on each design, but VNE is not a TAS
figure, whoever told you so, doesn't know what he/she is talking about.
AP
"Mark James Boyd" wrote in message
news:3fd4e4e4$1@darkstar...
Snip
Snip
Old December 9th 03, 01:11 AM
Mark James Boyd
various reasons,
So what are these reasons? Can someone explain this a bit better?
At 25,000 feet with a 90 knot headwind I'd like to know if
pushing the nose down to redline is maybe a bad idea...
and I'm not so sure I'd be confident doing it just
because there are blank pages in the manual...
Old December 9th 03, 04:50 AM
Eric Greenwell
various reasons,
Old (guessing: "certified before the early '80s") sailplanes may not
have the limitation in the manual because of the regulations in effect
at the time. A lot has been learned since then, leading to more
stringent testing and more conservative ratings. If I were flying an
older glider, I'd go by the TAS unless I knew for a fact it had been
designed and tested at Vne (indicated) at high altitudes (meaning the
altitudes I'd be flying it at).
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old December 9th 03, 04:34 AM
W.J. \(Bill\) Dean \(U.K.\).
No.
The BGA have produced a book published 2002 by A & C Black, London titled
"Gliding - The British Gliding Association Manual", ISBN 0-7136-5947-5
(not to be confused with the book "Gliding" by Derek Piggott published in
about 1958 and now I think in its 6th edition).
This book covers the technical knowledge which the BGA thinks glider pilots
should have, and is required reading for BGA rated instructors. The main
author is Steve Longland, and he had input from many others.
In chapter 5 "The placard, structure and flight limitations" there is a
section starting on p.155 "The effects of changes in air density".
In this section an explanation is given as to why the Vne is related to True
Air Speed and not to Indicated Air Speed. I do not claim to fully
understand it myself, but I certainly intend always to obey.
The conclusion is:
"Avoiding flutter.
"The practical rule of thumb is that you should reduce the glider's Vne by
"1.5% for every 1,000ft above sea level. If your glider's Vne is 128kt,
"then at 20,000ft the ASI reading corresponding to TAS of 128kt is 90kt,
"and at 30,000ft it will be 70kt. ....."
If you read the earlier section in the same chapter about test flying, you
will see that the glider is not tested to Vd (Design dive speed) but only to
Vdf (Demonstration design speed) which is 95% of Vd and that the placard
speed Vne is 90% of Vd.
To quote from the book: "If the glider's Vne is 130kt, it has only ever been
6.5kt faster, once, when it was new, in ideal conditions, and flown by a
specially trained test pilot."
If anyone thinks this is wrong, could we please have a reasoned argument and
not just abuse.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Arnold Pieper" wrote in message
om...
Gents,
airspeeds where compressibility comes into play, in which case MMO
(Maximum Mach Operating speed) becomes the limiting factor, usually well
above our speeds. That happens at a certain altitude, up to which the
pilot uses the Indicated VNE as a limit, then after that the MMO.
Exception :
various reasons, (Flutter is not the only factor in determining VNE).
their manuals, and there will be a table of limiting IAS x Altitude.
The Jantar Std 2 is not one of these, so, VNE is good as an IAS as high as
it will go.
AP
Old December 9th 03, 12:30 PM
Charles Yeates
Maybe it would be prudent to keep one's parachute straps tight and an
emergency O2 bottle attached -- then pray for luck, The Gods do get
angry now and then.
W.J. (Bill) Dean (U.K.). wrote:
No.
The conclusion is:
"Avoiding flutter.
not just abuse.
.com...
Gents,
Exception :
it will go.
AP
Old December 9th 03, 07:43 PM
Arnold Pieper
This seems to me to be some arbitrary way of staying conservative.
High altitude research is NOT an early 80s affair, I don't even know about
any such research during the 80s.
The Sierra Wave project was done during the 50s in the Owens Valley of Ca
with very old gliders that have been flown to 45000ft, altitudes at which,
according to this calculation, they would barely be able to fly.
However, curiously enough none of them flutter themselves to pieces.
To make a long story short :
-Look at the ASI on any turboprop or even some turbocharged aircraft, and
you will see that they fly at TAS much faster than the VNE painted on their
ASI.
Example : Twin Commander, VNE=255Kt (it's on it's ASI), Cruise TAS = 280Kt
to 300Kt.
The same holds true for all airplanes that fly up to the 20s and higher,
which aviation has been doing since WWII.
Look at the manual of some gliders, that do have the limitation on IAS with
Altitude.
You will see that the table of IAS is not correcting the VNE as a TAS value.
Nowhere in aviation VNE is considered a TAS value.
"W.J. (Bill) Dean (U.K.)." wrote in message
No.
pilots
True
The conclusion is:
"Avoiding flutter.
to
been
and
not just abuse.
om...
Gents,
ISA".
Exception :
as
it will go.
TAS
AP
Old December 9th 03, 09:04 PM
Eric Greenwell
ASI.
to 300Kt.
Altitude.
Quoting from the manual for my Schleicher ASH 26 E:
"4.5.8 High altitude flight
Flutter tests were carried out at about 2000 m msl. As the ASI
under-reads at increasing altitude, but since flutter limits for light
aircraft are determined by the true air speed, the following limitations
apply to high altitude flights:" [table of IAS at Vne for altitudes to
13000m follows]
Eric Greenwell
Washington State
USA
Old December 9th 03, 01:01 PM
Denis Flament
No.
No to what ???
Oh, I see... it written in a book ! So it is certainly true ;-)
Denis
Private replies: remove "moncourrielest" from my e-mail address
Pour me répondre utiliser l'adresse courriel figurant après
moncourrielest" dans mon adresse courriel...
Old December 9th 03, 12:56 PM
Denis Flament
is based on TAS.
it's not. It is only because the IAS at which flutter happens is likely
to vary with altitude (it may be lower or higher !) that some
manufacturers and/or authorities limit the VNE at a constant TAS above
2000 or 3000 m (i.e. the altitude where tests have been conducted)
IGC don't care of exceeding any limit, with the exception of legal
day/night flight rules.
I think there is still a provision that the record may only be validated
if the glider lands back in one piece (that rule was set after some
altitude gains in CuNimbs where the pilot had jumped with the barogramm
after his glider broke ;-)
Only in championships you must have a valid permit-to-fly and respect
the limitations of your glider (weight, etc.)
Denis
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 06:44 AM
gliding back to your departure airport Harold Piloting 34 October 24th 03 11:12 PM
Student Pilot Stories Wanted Greg Burkhart Piloting 6 September 18th 03 08:57 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
