(Terry Edmonds) wrote in message . com...
Has anyone on r.a.s. used a video borescope for inspecting linkages in glider wings? If so I would like to hear of your experience and the specific instrument you used. Thanks in advance. I used an Olympus IF4D5-15 to visually inspect the elevator actutating rod in the vertical stabilizer of my Nimbus 3. Access through the rudder balance cove and forward through the aft spar hole at the bottom. That scope was a 4mm, 1500mm length with a very nice (Olympus) light source. Here's a web page with some of the Olympus products: http://www.olympusindustrial.com/ind...7/parentid/179 There would be no problem using a larger diameter fiberscope, even an 11mm is plenty small enough, I used the 4mm because that's what we had available - the 8mm was out stuck into the back of an engine somewhere. I've always been partial to Olympus because their cable armoring seems to hold up much better over the years, fewer fiber-damage problems that the others, replacing the fiber cable is very expensive, for that matter, these things are terribly expensive to purchase, you'll want to have a lot of jobs lined up to justify the expense. The Wolf units at the top end of the line are very good as well, but it all dpends on how carefully you treat them (any of them). Jim |
Aviation Video: Another F-16 bites the dust | Iwan Bogels | Instrument Flight Rules | 0 | September 21st 04 07:02 AM |
In-Flight Video | Ron Wanttaja | Home Built | 11 | May 16th 04 06:11 AM |
Why is Melissa Morrison the *STAR* of the video... | X98 | Military Aviation | 1 | March 20th 04 07:39 PM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
Glider Club Video Montage | Todd Burch | Soaring | 0 | August 14th 03 09:15 PM |
