#71
Assume you make a glider which is a big cylinder with a huge
hollow tube going through the middle. I lay it on its side and put a clear plexiglass on the top part for the pilot to see out of, and give him a seat inside. Then I put three yawstrings on it: one on the plexiglass "canopy", one in the middle of the center tube, and one on the bottom. I drop this "glider bomb" and it heads straight down (maybe there's a drogue chute). A gyro rotates the cylinder on the way down. Assuming no surface friction and ignoring gyroscopic precession for now, all three yaw strings, from the pilot seat, show different things. If the cylinder is rolling right, the "glider bomb pilot" sees the yawstring on the canopy and instinctively wants to add right rudder. The string in the center of pressure shows straight, and the bottom string would make the pilot want to add left rudder. None of this has anything to do with gravity, adverse yaw, or the cylinder slipping or skidding. I contest that there is an error caused on the yaw string depending on the roll rate, airspeed, and the distance of the yaw string above the center of pressure, and this will always tell the pilot to add more rudder in the direction of roll (assuming the yawstring is above the center of pressure), i.e. skid. The size and importance of this error is another matter entirely :PPP Well, the size and importance DOES matter because you are making such a point of it. I think that I adequately proved that your last point was, shall we say, pointless. The offset of the yaw string to the center of the roll axis is much less than its displacement from the CG, making your "errors" proportionally less. I think you ought to pursue a more reasonable hypothesis; like TWA 800 was downed by a stray Navy missle. Tom |
#72
Aerodynamics 101.
Parasitic drag as a topic. If you truly want down fast, a slip is not the most effective tool. AS-K 21, full spoilers deployed and 90 knots airspeed will descend at 4000 fpm. You are below both maneuvering and rough air speed. Slipping turns are a useful tool. They should be understood. So should parasitic drag. Try it at altitude. Carry a GNSS recorder (GPS logger for us unruly Americans). Analyze the data later about how much sink rate you manufacture. Don't believe it? Come fly with us. Or watch from the ground if you wish. It works for everything from 1-26s up to Nimbus 3s and all the standard class stuff inbetween. There are no too-little or ineffective spoilers, just mild differences in sink rates. Now, the AS-W 12, that's a different story.....until they fitted a fitful drogue chute. Or the Carbon Dragon. Slipping on approach to landing (or anytime), pitch attitude is your friend for airspeed control. Cindy B www.caracolesoaring.com What speed did you use? Could you have just used full spoilers and spiralled down at 90 knots or so (or faster, if air was smooth), and had the same descent rate? -- ----- change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA 80kts in an ASK-21, but who knows the accuracy of an ASI in a slip? I was turning to the left with full right rudder and the nose as far down as I dared; the noise was tremendous. |
#73
If you truly want down fast, a slip is not the most effective tool. AS-K 21, full spoilers deployed and 90 knots airspeed will descend at 4000 fpm. You are below both maneuvering and rough air speed. It works for everything from 1-26s up to Nimbus 3s and all the standard class stuff inbetween. Now, the AS-W 12, that's a different story.....until they fitted a fitful drogue chute. Or the Carbon Dragon. Slipping on approach to landing (or anytime), pitch attitude is your friend for airspeed control. A second enthusiastic for parasitic drag - and slipping turns. Downwind abeam the touchdown spot at 7000 ft agl, full brakes, 90 kts and you have to be careful to keep the pattern snug to avoid undershooot (or changing configurations). Yields about a 3:1 L/D or a glide similar to the space shuttle. The angles look pretty strange in the steep turns but one adapts. Slipping turns are the ticket in non-spoilered beasts (AS-W12 or Pawnee). Both can be flown in near-90 degree banks with full top rudder, pulling lots of G and plummeting like a stone. The "look' from inside and outside the cockpit is a bit strange but one adapts. One can blow the side windows out of Super Cubs and probably Pawnees doing this in sub-zero Colorado WX at 14,000 ft in dawn wave sorties (we will not discuss howe I know this). Hard on airframe of aircraft and pilot alike. Parasitic drag descents are much better. High-G, high bank angle slipping turns are very useful for burning airspeed (energy) in the pattern as well but are very tiring if done repeatedly. The turn allows one to load up the wing with high G's making the slip markedly more effective. Similar to military overhead break approaches with the slip thrown in for good measure. Practice at altitude and be very careful in the "know-it-all" phase of the learning curve. The "pitch" angles in these maneuvers will bear no resemblence to a conventional approach and if they do (when you revert to the known and familiar angles and habits), you have a big problem. :-) |
#74
At 02:54 31 January 2004, Adp wrote:
Except it isnt is it! Gliders require you to understand fully things like adverse yaw, energy management, not being able to power-on and go around. When you land a glider, you only get one shot at it, what ever the conditions happen to be thrown at you. How much time do you spend thinking of where you are going to land out when you are at 1500 feet above the ground in your power plane? It has nothing what ever to do with irrational prejudice. This is one of the biggest nonsense myths in the soaring community. It amounts to an irrational prejudice towards power pilots who transition to gliders. There is considerably greater difference between, say, flying a Bonanza and flying a Boeing 757 than flying any glider. Gliders are incredibly easy to fly. Simply be aware of the differences. It really amounts to attitude. (In both senses of the word.) When flying a Bonanza, think Bonanza. When flying a King Air, think King Air. When flying a B-757, think 757. When flying a F18, think F18. When flying a glider, think glider. When flying a motor glider, think glider. It can't be much simpler. Allan 'Mark James Boyd' wrote in message news:401acc7c$1@darkstar... Pete Zeugma wrote: Ah, power planes, not gliders! Do you not think perhaps we should be differentiating between rudder usage in power plane, and a glider? I started flying originally in gliders, so I dont have any bad habits from power flying, and when I fly powered aircraft, i cant help but fly coordinated all the time. I know that power pilots who make the transition to gliders quite often make fundemental errors due to the power mindset when sat in a glider. What do you think? Absolutely there are subtle differences that get overlooked. Primacy is a factor here. Use of spoilers, wheel brake not at the feet, no stall horn, can't use throttle to descend, actually seeing adverse yaw, etc. All these were probably much harder to learn (unlearn) than if one started as a glider pilot first. ....Snip.... |
#75
Todd Pattist wrote:
Robert Ehrlich wrote: This terminology is or was source of a lot of discussions and misconceptions also in France where 2 equivalent terms exists, "glissade" for slip, "dérapage" for skid. So the team responsible for deciding the method and terminology that should be used by all glider instructors decided, after some discussion, that only one term should be used, "dérapage" was the choosed one. During a turn, a slip should be called "dérapage intérieur" (inside skid), a skid "dérapage extérieur" (outside skid). In straight line we speak of "dérapage à gauche" (skid toward left side) or "dérapage à droite" (skid toward right side). This has the advantage of uniformity, any case where the string is not in the middle is called by the same name and the further qualification (inside, outside, left, right) always indicate the side from which the relative wind is coming and the string is going away. Thanks for posting this. It is fascinating to see something familiar from a totally different perspective. I admit to not really understanding the advantage of using your integrated terminology. A "skid" is almost never (ever?) an appropriate maneuver, so giving it a completely different name from a "slip" allows immediate recognition that we're talking about something that's inappropriate to do. I would be more concerned that a student would be confused between when it's OK to "dérapage" and when it's not One of the ideas behind this integrated terminology is that neither skid nor slip is an appropriate maneuver in today's gliders having powerful airbrakes, morever on some of them the POH prohibits skids and/or slips. |
#76
Pete,
Unfortunately, you are wrong on this one. You can, in fact, use rudder to change direction, much to the aerodynamicist's chagrin. It is very inefficient, but by holding wings level and ruddering (a skid) you create an inward pointing force caused by the fuselage (along with a rearward componenet -- drag). It is this force that allows you to slip by counteracting the turning force of the wing with an opposite force from the fuselage. (Again, much to the chagrin of the aerodynamicist.) You need rethink your model. Remember, things only go straight if in equilibrium. An aircraft flying sideways through the air wings level won't be in equilibrium, therefore either speed or direction must change. Pete Zeugma wrote in message ... If you have zero bank, and apply rudder you will begin a flat turn. Wrong! UTTERLY WRONG!!!! A rudder yaws the airframe, it does not 'turn' or 'steer' the aircraft. Your whole problem seems to be in compairing a glider with a boat. They may both have rudders, but they both do totally different things. Next time you fly in your glider, line yourself up with a straight feature. Apply some rudder to yaw the glider, but keep the wings level. All you will do is continue in a straight line, sideways on. (commonly known as a side slip) However, the rudder does has a secondary control effect, which introduces a roll moment due to differences in lift between the wings. (which is why the first thing you do is apply full opposite rudder to counteract the rotation in a spin) It is the ailerons that instigate a turn, the rudder is used in a coordinated manner to 1) check the adverse yaw (secondary effect of ailerons), and 2) to align the airframe correctly into the airflow. Please stop using language which inforces a belief that the rudder is used to turn a glider in flight. Your very action in doing so may well end up enforcing that belief into a low airtime pilot reading these posts and KILLING THEM! |
#77
At 14:24 02 February 2004, Chris Ocallaghan wrote:
Pete, Every now and then, I like to keep my hand in with sidesliping on finals. One airfield I fly at has a real narrow tarmac strip, like 5 meters. When I am in a nice balanced, wings level sideslip, how come I maintain a striaght path all the way down to my reference point where I kick it off to round out? Unfortunately, you are wrong on this one. You can, in fact, use rudder to change direction, much to the aerodynamicist's chagrin. especially if you have and engine up front. It is very inefficient, but by holding wings level and ruddering (a skid) side slip actually you create an inward pointing force caused by the fuselage (along with a rearward componenet -- drag). It is this force that allows you to slip by counteracting the turning force of the wing with an opposite force from the fuselage. (Again, much to the chagrin of the aerodynamicist.) Please, expand on this 'force', from an aerodynamics point of veiw. I'd love to know what law of physics you have created this thrust vector from. You need rethink your model. Remember, things only go straight if in equilibrium. actually, all objects in motion exhibit a natual tendancy to go in a straight line, unless an external force is applied to upset that equilibrium. One of Mr Newtons laws I think! An aircraft flying sideways through the air wings level won't be in equilibrium, therefore either speed or direction must change. I did loads of sideways flying this weekend soaring on our hill! Wings level, straight line constant 60knots, crabbing along at 40 odd degrees. in order to keep the wings level while applying yaw, you have to apply a roll moment to counter the secondary roll moment caused by the yaw. This puts the aircraft back into equilibrium by force. If you release the aileron, the secondary roll moment caused by the yaw will eventually bank the aircraft into a turn. Stick an engine into the equation, and it all changes. |
#78
Pete Zeugma skrev den 2 Feb 2004
15:16:31 GMT: you create an inward pointing force caused by the fuselage (along with a rearward componenet -- drag). It is this force that allows you to slip by counteracting the turning force of the wing with an opposite force from the fuselage. (Again, much to the chagrin of the aerodynamicist.) Please, expand on this 'force', from an aerodynamics point of veiw. I'd love to know what law of physics you have created this thrust vector from. The same laws which keep you in the air, in fact. When the fuselage is going through the air at a beta angle (sideslip), it generates lateral lift. That's what makes knife edge flight possible. Chances are this effect is not very noticeable in a glass bird with the streamlined fuselage, meaning that the bank angle required to keep the glider travelling in a straight path might be marginal and not really noticeable. Cheers, Fred |
#79
On Mon, 2 Feb 2004 15:16:31 UTC, Pete Zeugma
wrote: : you : create an inward pointing force caused by the fuselage : (along with a : rearward componenet -- drag). : Please, expand on this 'force', from an aerodynamics : point of veiw. I'd love to know what law of physics : you have created this thrust vector from. May I jump in? He's right, and it's dead easy, really. If the fuselage is yawed to the right, the airflow comes from the left. Which tends to push the big front big - the cockpit - to the right. And I'm an aerodynamicist, amongst other things. : in order to keep the wings level while applying yaw, : you have to apply a roll moment to counter the secondary : roll moment caused by the yaw. This puts the aircraft : back into equilibrium by force. If you release the : aileron, the secondary roll moment caused by the yaw : will eventually bank the aircraft into a turn. Whoops. I think you are confusing the effects of yawing and the effects of being yawed. As you yaw, one wing moves faster than the other and produces more lift, tending to roll the glider unless prevented. But once you are yawed, this effect ends. There may be other effects requiring use of aileron while yawed - sweep forward in the wings, for example. : Stick : an engine into the equation, and it all changes. Not very much changes, actually. Ian |
#80
Todd,
Ever try to slip an Ercoupe? No slip needed for crosswinds either. And.. There's nothing quite like flying one over the city on a fine spring evening with the window down. Cheers! Todd Pattist wrote in article ... Robert Ehrlich wrote: snip I don't see how a POH could entirely prohibit slips - as you could never land in a crosswind. :-) Todd Pattist - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 04:44 PM |
| Puch spin in | Mike Borgelt | Soaring | 18 | January 24th 04 10:29 PM |
| Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 02:35 AM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
