Cheap GPS Loggers for FAI Badges - Status?
Old May 24th 04, 05:16 AM
Marc Ramsey
Papa3 wrote:
Correct me if I'm wrong, but regardless of whether pressure altitude and
Geometric (ie. GPS) altitude differ during a flight, if you use a constant
reference (ie. always use GPS), then the consistency is similar, at least
over the altitudes we typically use.
Yes, you are wrong. If you look at the equations for converting
pressure to altitude, you'll note that one factor is the average
temperature of the column of air between the reference altitude and the
altitude at which the pressure is being measured. Altimeters,
barographs, and flight recorders are calibrated to a specific sea level
temperature (15C) and a specific temperature lapse rate (0.002C/ft), as
determined by the International Standard Atmosphere. These conditions
almost never apply to real world soaring flights, as we generally fly on
warmer days with higher lapse rates. At 10000 feet above my home field
during the summer, my properly set altimeter typically reads 500 or 600
lower than my true altitude, which can easily be verified when flying
near peaks with known elevation. This can also be verified by looking
at IGC files from an approved flight recorder, the divergence between
GPS and pressure altitude (adjusted for the different baselines)
generally increases with altitude, and the amount of divergence will
vary on a day to day basis.
Well, I think this is exactly the point. The OO system has ALWAYS been an
honor system. There are dozens of very significant records out there where
wives/husbands/best friends have handled this critical function. If that's
not truly an "honor system", I don't know what is. Unless the FAI is
willing to mandate that OO's be impartial third parties who are subject to
random lie detector tests (with violations punishible by having to sit in on
committee meetings to discuss COTS proposals), then I come back to my
primary point. There is effectively NO DIFFERENCE in the degree of
security between the two methods. There are differences in the type of
technical prowess required to defeat the system, but level of security is
effectively the same.
Actually, the OO system was much stricter in the past than it is now.
It has relaxed over time due to changes in the nature of the sport, and
the circumstances under which we fly. One of the reasons for requiring
increased security for flight recorders (and the requirement that they
be used for world and national records), was to compensate for the fact
that it was no longer possible to demand or expect completely impartial
observers.
At the end of the day, what we've done is exactly the mistake I pointed out
in the beginning. We've allowed paranoia over a few folks who may want to
fudge their gold distance flight or silver climb lead to a situation that
literally requires people to stick with 1940's technology or fork over an
extra $500 for an "approved" logger. For this cost we get what exactly?
The satisfaction in knowing that, if a guy wants to fly his Silver Distance
in a Nimbus IV, at least he didn't cheat? Am I the only one who sees a
certain irony in this????
It has been pretty well established that a greater percentage of active
pilots own flight recorders now than owned barographs in the past. I
have loaned out personally owned flight recorders, and I know several
others who have also done so. Just about every club that I know if in
my area has flight recorders available to their members. Quite a few
commercial glider operation rent them for a small fee. And, of course,
one can still use a camera and barograph. I have a barograph in my
closet I haven't been able give away to anyone in the area.
But, you know what? I think the IGC *should* allow use COTS GPS units
for badges with some restrictions. The problem that you (and others who
have proposed this) are up against is that it will take a good deal of
work to convince those who really matter. Frankly, the proposals I've
seen so far have been rather poorly argued and incomplete. I don't
think anyone has yet bothered to do the homework necessary to come up
with a proposal that might be taken seriously.
Marc
Old May 24th 04, 06:46 AM
Tony Burton
In article , Marc Ramsey
Oh yes, there is a GREAT deal of homework being done!
The drafters of the Canadian COTS proposal to the last IGC meeting and the
Canadian IGC delgate have been in constant contact recently with Garmin
and the IGC GFAC committee to resolve technical/rules mismatches. It
appears that these are being sorted out for a popular Garmin unit now that
the engineers and the GFAC committee learned to speak each other's
language. :-)
There is reason to be optomistic that a COTS GPS unit will be approved
within a bureaucratically short period of time.
Tony Burton
Old May 24th 04, 07:05 AM
Marc Ramsey
language. :-)
This is news to me, which should be a little bit surprising, given that
I am one of the members of GFAC. I know of the Canadian COTS proposal,
but have heard nothing about it since it was rejected by the IGC.
If by "bureaucratically short period of time" you mean October 2006,
then indeed, there is some finite probability that something could
happen then. IGC rule-making procedures make it impossible for it to
happen any sooner.
Marc
Old May 24th 04, 03:18 PM
Tony Burton
Tony Burton wrote:
... This is news to me, which should be a little bit surprising, given that
I've been cc'ed in the long e-mail chain between the Canadian delegate,
COTS drafter, Garmin, and Ian on your committee after the IGC annual
meeting. Things are chugging along apace.
happen any sooner.
That's what I mean - I'm familiar with the IGC approval process - "short"=
as fast as the bureaucratic system allows (I hope).
Cheers
Tony Burton
Old May 24th 04, 06:35 PM
Tony Burton
happen any sooner.
Marc, it occurs to me that this may not necessarily be so as long as the
IGC rules for FRs don't have to change in order to introduce a specific
COTS GPS. For example, each FR approved by the the GFAC comes with an
"approval document" which delineates how that FR must be used, OO actions,
etc.
So, say that some Garmin GPS is ICG-compliant except for the barograph
function. Could not such an FR be approved by the IGC GFAC committee with
the restriction in its approval document that it could not be used for
height evidence?
Tony Burton
Old May 24th 04, 06:59 PM
Marc Ramsey
etc.
height evidence?
No, since pressure altitude recording capability is a non-optional
requirement of the Technical Specification (see sections 2.4 and 2.6.5).
In any case, I believe all FAI badge-related flight performances
require altitude evidence, with the sole exception of the 5 hour
Silver/Gold duration.
Marc
Old May 24th 04, 09:45 PM
Tony Burton
height evidence?
Marc
Okay, then the solution to the regulatory barrier seems to be to broaden
the Tech Spec for COTS GPS units by enlarging the list of functions which
are optional. If COTS are deemed to be"a good thing" for the vastly larger
population of badge pilots vs record-seeking pilots, then the IGC/GFAC
committee ought to be finding the means to add a few "almost-compliant"
FRs to the approved list (how it can be done vs why it can't).
Of course, there's nothing in the Sporting Code that requires flight
evidence to come from one piece of equipment, otherwise we wouldn't have
cameras/baros.
Regards
Tony Burton
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
