I'm trying to get a Compaq Aero 1530 with PocketNav to receive NMEA
output from a Colibri logger so that it can display the moving map. When I tried it for the first time in flight the PocketNav message was "No NMEA Data" and it went into simulator mode. Can anyone tell me what sentences to select in the Colibri's setup menu in order to get this to work? ....George B. |
Try this (..from memory, email me if this doesn't work and I'll get the
actual devices and walk you through it)-- *before connecting the devices, go to the "make a new connection" page and set one up--call it whatever you like, don't change any defaults *physically connect the two devices *tap the icon for the new connection you just created, say yes/ok to the windows that come up *tap the keyboard *type NMEAenter data should start scrolling on your 1530 screen *close the connection. Don't worry, the Colibri won't know you closed it and will keep spewing data *Open PocketNav Brent "George B." wrote in message om... I'm trying to get a Compaq Aero 1530 with PocketNav to receive NMEA output from a Colibri logger so that it can display the moving map. When I tried it for the first time in flight the PocketNav message was "No NMEA Data" and it went into simulator mode. Can anyone tell me what sentences to select in the Colibri's setup menu in order to get this to work? ...George B. |
Hi George,
I'm sorry for the delay getting an answer to your question. I sell and support Glide Navigator II which is the latest version of what was Pocket-NAV. I forwarded your question to Chip Garner (GN II author) and his response is below. "GPRMC message for location, GPGGA if possible, this gives the GPS altitude and allows differential final glide altitude." You may want to consider getting Glide Navigator II as there a several nice new features added since the days of Pocket-NAV such as the highlighting of reachable airports on the map screen. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "George B." wrote in message om... I'm trying to get a Compaq Aero 1530 with PocketNav to receive NMEA output from a Colibri logger so that it can display the moving map. When I tried it for the first time in flight the PocketNav message was "No NMEA Data" and it went into simulator mode. Can anyone tell me what sentences to select in the Colibri's setup menu in order to get this to work? ...George B. |
Paul Remde wrote:
Hi George, I'm sorry for the delay getting an answer to your question. I sell and support Glide Navigator II which is the latest version of what was Pocket-NAV. I forwarded your question to Chip Garner (GN II author) and his response is below. "GPRMC message for location, GPGGA if possible, this gives the GPS altitude and allows differential final glide altitude." You may want to consider getting Glide Navigator II as there a several nice new features added since the days of Pocket-NAV such as the highlighting of reachable airports on the map screen. And "Mark point"! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Pocket PC GPS software. | R.T. | Owning | 5 | November 7th 04 01:18 AM |
10,554+ NMEA-0183 Sentences | Bob Carter | Products | 0 | April 9th 04 07:44 PM |
Garmin 196 NMEA *input* | David Megginson | Piloting | 1 | December 7th 03 02:47 AM |
WingX for the Pocket PC - Version 1.2 | Hilton Software LLC | Products | 1 | October 17th 03 01:38 PM |
WinPilot Now Supports Ipaqs with Pocket PC 2003 Ipaqs 2200, 5510, 5400, 5500 Series. | rhpf | Soaring | 0 | August 15th 03 01:21 AM |
