Bill Daniels wrote:
"Hal" wrote in message om... Still learning to benefit from thermalling with another glider and so far have not realized the benefits. If you are opposite another glider and observing your progress in relationship to the other glider how do you adjust your path if you see the other glider in better lift? Use the other glider as a "zero time constant vario". When you are opposite the other glider and his climb is at the greatest, reduce your bank to swing wide on the opposite side of the thermal then tighten up again. Learn to control airspeed by sound and use an audio vario so you can keep your eyes on the other glider. Reducing bank angle from 45 deg to 30 degree will double your turn diameter. If you resume a 45 degree bank after 180 degrees of turn, you will have moved the circle center one diameter toward the stronger lift. This gentle correction will let you keep the other glider in sight. He should follow your move to stay opposite. The way I was taught and I am now teaching my students for moving your circle in a given dicrection is rather to revert to zero bank angle when your heading is just the direction to which you want to move the circle, keeping wings level the amount of time suited to the intended move and then resuming circling at the previous bank angle. Your method of reducing bank angle for half a turn assumes you start that a quarter turn (90 degrees) before your heading is in the direction you want to move. You are then in the worse part of your initial circle, maybe sinking. If you needed 45 degree bank, that means that the thermal was narrow. Lowering the bank angle at the worse part of the thermal will make most of the part of this manoeuver in the worse part of the thermal or outside of it. Anyway the main problem is to have the other glider follow your move. Regarding this, this is also a pro for the method above, at least in my country, as everybody having learnt here should have learnt in the same way and so the intent should be obvious. However going straight ahead maybe misiniterpreted at the begining of the manoeuver as leaving the thermal, although the dive associated with this last thing is missing. If the other glider is known to have a radio on the same frequency, using it may help. |
Themi thermal locator | John Jones | Soaring | 5 | April 30th 04 04:16 AM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
