Here is a design that one of my friends designed tfor our club winch. The
beauty of this design is that there is no chance of getting a finger cut and it works perfectly. The design is based on a rotating cylinder mounted inside a metal cube. The metal cube has a hole drilled through it through the center line. The cylinder also has a hole drilled through it. In normal use, the hole in the cube lines up with the holein the cylinder. To activate, a handle rotates the cylinder, which the cylinder rotatesImagine an 8 inch square solid metal cube. | | | | | | | | | Nice winch but I wouldn't fly up it until you have the guillotine setup sorted out! Jim Vincent N483SZ illspam |
The cylinder only needs to rotate about 20-30 degrees.
We use a lever mounted to the end of the cylinder. The lever is attached to a handle in the winch cabin with a cable. In normal position, the cylinder holes are in line with the block. Pull the handle and the cylinder rotates. Great Idea, I bet driving the rotating cylinder/blade with a heavy duty starter would make a very nice install. Jim Vincent N483SZ illspam |
Smart CDI diesel engine | Hans Zwakenberg | Home Built | 14 | January 9th 05 12:32 PM |
Aerotow with Diesel engine? | Olfert Cleveringa | Soaring | 44 | November 2nd 04 10:22 AM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Emergency Procedures | RD | Piloting | 13 | April 11th 04 08:25 PM |
