![]() "R. Wubben" wrote in message om... I'm thinking of a Scheibe SF-25/Slingsby T.61: Vne is 99 knots. Gross wt. is 1260 I'm not sure what stall speed is, probably about 40 knots or so. So based on that, one would think it would qualify. What I'm curious is if it would fall under the glider OR the "light sport airplane" section. Does the FAA even recognise the motorglider class when talking about LSA? I couldn't find anything on the EAA website (or it's Sport pilot spin off site) and I also didn't see ANYTHING regarding LSA on the SSA website. I probably shouldn't be surprised either way. Does one just make an appointment at the FSDO office with paperwork and airplane and you then get annointed as an LSA? (like some of these foreign built factory airplanes that are reputedly going to flood our shores)...? Thanks for any collective wisdom! Ryan in Madison, WI Out of curiosity, what advantage do you see in having it registered as a LSA? Tim Ward |
![]() Out of curiosity, what advantage do you see in having it registered as a LSA? Tim Ward I was wondering the same thing, It should be registered as a "Glider" the launch method, "self launch" should not be an issue except for log book endorsements. I don't believe that they would change a "registration" on a J-3 Cub from "Airplane" to "LSA", just to get the Light Sport only Pilot to fly it. He should be qualified to fly any aircraft that falls into the qualifications for light sport aircraft, even though it is registered as an airplane. BT |
In article nsOsd.176864$bk1.112605@fed1read05,
BTIZ wrote: Out of curiosity, what advantage do you see in having it registered as a LSA? Tim Ward I was wondering the same thing, It should be registered as a "Glider" the launch method, "self launch" should not be an issue except for log book endorsements. I don't believe that they would change a "registration" on a J-3 Cub from "Airplane" to "LSA", just to get the Light Sport only Pilot to fly it. He should be qualified to fly any aircraft that falls into the qualifications for light sport aircraft, even though it is registered as an airplane. That's correct. The J-3 and 1-26 and 2-33 are considered "LSA" even though they have standard certificates. The main question is if someone wants to get an LSA certificate so they can do their own maint. after some fairly short training (instead of 18 months of experience and, you guessed it, an FAA Airframe mechanics test). -- ------------+ Mark J. Boyd |
The main reason I'm curious is that I was under the impression that
most of these imported gliders/motorgliders get registered under the "experimental-exhibition" category. I was also under the impression that there is a limit to where you can fly (technically) without letting the FSDO know in writing the area you will be operating in (which I'm sure EVERYBODY does if so requiried). So I was just thinking it was a way to avoid all of that in an aircraft the is allowed under LSA. I do have a glider rating, with a motorglider endorsement and ASEL and own a Cessna. So it's not about me. It's about the registration of the aircraft... Thanks, Ryan Wubben |
Well, my experimental has a limitation "not be flown over congested areas"
and SLSA aircraft do not have this limitation. But mine is "amatuer-built" not "exhibition." I don't know if the exhibition ones have the same limitation. In article . com, wrote: The main reason I'm curious is that I was under the impression that most of these imported gliders/motorgliders get registered under the "experimental-exhibition" category. I was also under the impression that there is a limit to where you can fly (technically) without letting the FSDO know in writing the area you will be operating in (which I'm sure EVERYBODY does if so requiried). So I was just thinking it was a way to avoid all of that in an aircraft the is allowed under LSA. I do have a glider rating, with a motorglider endorsement and ASEL and own a Cessna. So it's not about me. It's about the registration of the aircraft... Thanks, Ryan Wubben -- ------------+ Mark J. Boyd |
Tim Ward wrote:
"R. Wubben" wrote in message I'm thinking of a Scheibe SF-25/Slingsby T.61: Vne is 99 knots. Gross wt. is 1260 I'm not sure what stall speed is, probably about 40 knots or so. So based on that, one would think it would qualify. What I'm curious is if it would fall under the glider OR the "light sport airplane" section. Does the FAA even recognise the motorglider class when talking about LSA? Out of curiosity, what advantage do you see in having it registered as a LSA? The 10,000 foot rule applies to Sport Pilots, not aircraft, so this is no problem (the LSA certification isn't more limiting to the aircraft). Perhaps he doesn't have a glider license, and wants to take a passenger, but has no examiners nearby (only CFIs). And maybe he has a bunch of airplane pilot friends who'd consider a partnership, but won't take a checkride to do so. Maybe he wants to do his own yearly condition inspections. Perhaps another question is, what are the disadvantages? Well, because maintenance can be performed by someone who has only taken a 80-hour course and inspections are done by someone with only 16 hours of training, there may be a perceived loss of value at resale. Certainly a new buyer of an LSA will want a careful inspection, perhaps more careful than if a full A&P signed it off every year. For similar reasons, an insurer may have a different rate for a Standard vs. SLSA vs experimental or ELSA certificate. I haven't seen this in the past (there is a J-3 Cub I know of that the owner made experimental, and the insurer didn't even blink). But I would certainly check with an insurer before making any choices about what certificate to get. Glider vs. airplane, SLSA vs. experimental vs. standard vs. ELSA, etc. may have some effect. I simply don't know. I've bought or sold maybe a dozen aircraft, and insurance shopping was always done before a transaction. For me, the most interesting part of this whole thing is how the insurers are going to react. From the rumblings of Costello, it sounds like the airworthiness certificate and the rating of the pilot aren't as important as the make and model, and the pilot's time in make and model. If you call an insurer and ask, please write back and let us know... -- ------------+ Mark J. Boyd |
insurance for Sport Pilots! | Cub Driver | Piloting | 4 | September 11th 04 01:14 AM |
Will US Sport Pilot be insurable? | Mark James Boyd | Soaring | 12 | November 29th 03 03:57 AM |
Motorgliders (long) | JJ Sinclair | Soaring | 98 | October 9th 03 10:11 PM |
Sport Pilot (was SoCal CFIGs needed. | M B | Soaring | 1 | September 30th 03 04:21 AM |
Latest Newsletter Pipistrel Motorgliders | Michael Coates | Soaring | 20 | September 19th 03 01:25 AM |
