#11
BTIZ wrote:
I remember an article somewhere.. can't find it.. the 5 point in a glider really only keeps you from submarining under the lap belt in case of a landing accident as you rush forward from a rapid stop.. although there is some credence that the 5th strap will help keep the center of the seat belt low on your waist/hips.. and hold your hips down, but it's the shoulder straps that keep your head off the canopy.. your body still articulates around your waist when you hit that bump that puts your head on (or into) the canopy Since the 5th belt holds the buckle in the proper position, you are able to tighten the shoulder belts much more, and this reduces the severity of "canopy encounters". Even tight shoulder harnesses won't eliminate the problem, because they aren't designed to hold you down, but more to keep you from going forward. If the belts angled down behind you, instead of going straight back, a crash would likely lead to severe compression of the spine. A "work around" I use is to press my body up against the belts. This tends to reduce the "overshooting" that occurs when you are thrown against the belts by negative G's, and reduces or eliminates the impact with the canopy. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
How about a "Hans" device?
Short of that what you probably want is some sort of neck brace, the drag racers and dirt track racers wear that horse shoe looking spacer, but that probably gets most of it's benefit when used w/ a helmet. |
![]() "Eric Greenwell" wrote in message news ![]() BTIZ wrote: I remember an article somewhere.. can't find it.. the 5 point in a glider really only keeps you from submarining under the lap belt in case of a landing accident as you rush forward from a rapid stop.. although there is some credence that the 5th strap will help keep the center of the seat belt low on your waist/hips.. and hold your hips down, but it's the shoulder straps that keep your head off the canopy.. your body still articulates around your waist when you hit that bump that puts your head on (or into) the canopy Since the 5th belt holds the buckle in the proper position, you are able to tighten the shoulder belts much more, and this reduces the severity of "canopy encounters". Even tight shoulder harnesses won't eliminate the problem, because they aren't designed to hold you down, but more to keep you from going forward. If the belts angled down behind you, instead of going straight back, a crash would likely lead to severe compression of the spine. A "work around" I use is to press my body up against the belts. This tends to reduce the "overshooting" that occurs when you are thrown against the belts by negative G's, and reduces or eliminates the impact with the canopy. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA So, what about the idea of a pair of short, say 8", padded arms that rotate down over each shoulder and latch in place? That would prevent the upper body from rising and the head from snapping sideways. The latches would release and the arms spring back when the canopy was opened. Bill Daniels |
Bill Daniels wrote:
"Eric Greenwell" wrote in message A "work around" I use is to press my body up against the belts. This tends to reduce the "overshooting" that occurs when you are thrown against the belts by negative G's, and reduces or eliminates the impact with the canopy. So, what about the idea of a pair of short, say 8", padded arms that rotate down over each shoulder and latch in place? That would prevent the upper body from rising and the head from snapping sideways. The latches would release and the arms spring back when the canopy was opened. Perhaps fixed arms could be on the canopy frame, so they would rise with the canopy without any complications. Another possibility would be a modified or removed seat back that would give you more distance from your head to the canopy. Any of these things would need careful design to ensure they don't make other situations, like a crash, much worse. Or maybe it's time for a different glider with a larger cockpit, or more flexible wings! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
How about wearing a set of football shoulder pads? I would think more
downward force would be available from the shoulder harness since they would have to go up over the shoulder pads. "Mark Zivley" wrote in message . com... How about a "Hans" device? Short of that what you probably want is some sort of neck brace, the drag racers and dirt track racers wear that horse shoe looking spacer, but that probably gets most of it's benefit when used w/ a helmet. |
At 03:00 09 December 2004, Bill Daniels wrote:
snip So, what about the idea of a pair of short, say 8', padded arms that rotate down over each shoulder and latch in place? That would prevent the upper body from rising and the head from snapping sideways. The latches would release and the arms spring back when the canopy was opened. Bill Daniels You make 'em. Tim Mara will sell them! |
With all this talk about padded arms dropping over my shoulders, I keep
thinking about the "you must be this tall in order to ride" sign that would have to be nearby. Of course, a "you must be this short in order to ride" sign would actually do a better job of solving the problem. "Nyal Williams" wrote in message ... At 03:00 09 December 2004, Bill Daniels wrote: snip So, what about the idea of a pair of short, say 8', padded arms that rotate down over each shoulder and latch in place? That would prevent the upper body from rising and the head from snapping sideways. The latches would release and the arms spring back when the canopy was opened. Bill Daniels You make 'em. Tim Mara will sell them! |
If you have your head touching the canopy it cannot accelerate into the
canopy and hurt you. -Bob "Eric Greenwell" wrote in message ... Bill Daniels wrote: "Eric Greenwell" wrote in message A "work around" I use is to press my body up against the belts. This tends to reduce the "overshooting" that occurs when you are thrown against the belts by negative G's, and reduces or eliminates the impact with the canopy. So, what about the idea of a pair of short, say 8", padded arms that rotate down over each shoulder and latch in place? That would prevent the upper body from rising and the head from snapping sideways. The latches would release and the arms spring back when the canopy was opened. Perhaps fixed arms could be on the canopy frame, so they would rise with the canopy without any complications. Another possibility would be a modified or removed seat back that would give you more distance from your head to the canopy. Any of these things would need careful design to ensure they don't make other situations, like a crash, much worse. Or maybe it's time for a different glider with a larger cockpit, or more flexible wings! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
canopy and hurt you. Sure it can. If you hit a 3 G negative acceleration, not uncommon in heavy ridge lift, the glider is accelerating down at 3G. Your head is trying to stay where in one postion spatially, so the result is a force against the canopy equal to the mass of your head times the G forces. The more dense your head, the higher the force! Jim Vincent N483SZ illspam |
Tilly will happily give you, at no charge, additional cut-to-size foam
inserts. I have three in my hat, but I've met another pilot who flies with a pair of socks in his hat in rough air. wrote in message ups.com... Hi, I use a Tilley Hat. It has a 1/8" dense foam on top. IT help some but I dont know about rotor turbulence. Tom Knauff sell them. S6 Bill Daniels wrote: "Vaughn Simon" wrote in message ... "Bill Daniels" wrote in message news:rKGtd.730764$8_6.17288@attbi_s04... I'm starting to think about a pair of short arms that swing down over the pilots shoulders and lock in that position. The idea is to provide an additional, robust restraint to prevent the pilots head from hitting the canopy. Opening the canopy would release the locks so the arms would spring up and back out of the way. Wouldn't a bicycle helmet be much simpler and lighter? I've never seen one that was small enough to fit under the canopy. Anyway, that doesn't protect your neck. Bill Daniels |
