The different air masses, the different instruments
ect. ect. obviously lead to different results. Not being the physic's expert, I was just wondering if anyone has tried flight testing Sailplanes in a wind tunnel? Could you 'hard point' it and measure weights or lack of weight to get Polar info. Im sure boeing or MD has done something like that. I suppose that you may not get a direct glide ratio but could get a common start point that all gliders then could be compared to. Any comment from the mathematicians? At 14:00 29 December 2004, Andy Blackburn wrote: This original idea has now morphed into a suggestion essentially to replicate the technique used by Dick Johnson and others, with the main difference being using the barometric altitude transducer in a flight computer instead of the mechanical altimeter(?). This might offer some improvement in accuracy, but is at least as complex to execute as the flight test techniques used for the past 40+ years. There are two main challenges with using flight logs only: 1) There is no good source for IAS, so you have to try to estimate it from GPS ground speed. 2) Typical soaring flights don't involve adequately calm vertical airmass movement and probably not constant enough airspeed to trust even long glides of many tens of miles. 9B |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 08:13 PM |
| AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 03:13 PM |
