At 07:00 01 January 2005, Eric Greenwell wrote:
I think the angle of attack range for an unflapped airfoil is about 10 degrees, which would suggest errors of 0 (at high speed, for example) increasing to 1.5% at low speed (or vice versa - depends on where you aim the sensor). This could be easily corrected using using the airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range is even smaller, and the errors could likely just be ignored. 50:1 is an angle of a degree and a bit so if you have your 'straight ahead' and 'straight down' sensors canted down/aft by just a degree from true horizontal/vertical, you'll get a pretty accurate airspeed, but the 'vertical' speed will likely show zero, I think, since it will be reading off dust particles that have zero velocity towards/away from the glider. 9B |
Andy Blackburn wrote:
At 07:00 01 January 2005, Eric Greenwell wrote: I think the angle of attack range for an unflapped airfoil is about 10 degrees, which would suggest errors of 0 (at high speed, for example) increasing to 1.5% at low speed (or vice versa - depends on where you aim the sensor). This could be easily corrected using using the airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range is even smaller, and the errors could likely just be ignored. 50:1 is an angle of a degree and a bit so if you have your 'straight ahead' and 'straight down' sensors canted down/aft by just a degree from true horizontal/vertical, you'll get a pretty accurate airspeed, but the 'vertical' speed will likely show zero, I think, since it will be reading off dust particles that have zero velocity towards/away from the glider. Think of the glider flying straight and steady in still air: it is descending (vertical motion) through the air at whatever it's sink rate is. So, at least in concept, a laser airspeed sensor pointed straight down will be able to measure this. Even if the sensor is aimed a few degrees one way or the other from perpendicular, the error would be very small, equal to sine of the angle off of perpendicular. If the airmass is moving, the measurement would be the same, of course, since the speed measured is the air motion relative to the glider - it's just easier to visualize what's happening with still air. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
If the sensor is aiming straight down, at a glide angle of 40/1 the air
is going 40" aft for every 1" that it rises relative to the instrument. If the sensor is aimed slightly aft (1/40, whatever that is in degrees), the air won't be rising at all relative to the sensor. Right? So isn't angle crucial? Also, can the sensors measure speed when the air mostly is going crossways in front of the sensor? |
Greg Arnold wrote:
If the sensor is aiming straight down, at a glide angle of 40/1 the air is going 40" aft for every 1" that it rises relative to the instrument. If the sensor is aimed slightly aft (1/40, whatever that is in degrees), the air won't be rising at all relative to the sensor. Right? So isn't angle crucial? OK, I'm persuaded! It now appears the sensor would need to be aimed up or down rather accurately, or the at least the angle off vertical measured accurately. Dang - that's harder. Perhaps the inertial system would be a reasonable way to achieve this, or maybe differential GPS system with antennas on the nose and tail. Also, can the sensors measure speed when the air mostly is going crossways in front of the sensor? I think it depends on the sensor: some are optimized for speed in line with the beam, some for speed perpendicular to the beam (cross wind measurement, like for bullets). Perhaps there are ones that can read the vector wind? I have no idea how much crossways speed the various sensors can tolerate. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
I think it depends on the sensor: some are optimized for speed in line with the beam, some for speed perpendicular to the beam (cross wind measurement, like for bullets). Perhaps there are ones that can read the vector wind? If so, you would just need a single sensor facing forward. You still would have the problem of getting it perfectly horizontal, though. I have no idea how much crossways speed the various sensors can tolerate. I am betting that these sensors can only measure speed directly toward or away from the sensor. Sort of like a radar gun. So I am not understanding how they could measure a glider's sink rate. |
It seems to me that having the sensor hanging freely like a pendulum
(pointing down) would make it measure the vertical component. "Eric Greenwell" wrote in message ... OK, I'm persuaded! It now appears the sensor would need to be aimed up or down rather accurately, or the at least the angle off vertical measured accurately. Dang - that's harder. Perhaps the inertial system would be a reasonable way to achieve this, or maybe differential GPS system with antennas on the nose and tail. |
Bob Salvo wrote:
It seems to me that having the sensor hanging freely like a pendulum (pointing down) would make it measure the vertical component. "Eric Greenwell" wrote in message ... OK, I'm persuaded! It now appears the sensor would need to be aimed up or down rather accurately, or the at least the angle off vertical measured accurately. Dang - that's harder. Perhaps the inertial system would be a reasonable way to achieve this, or maybe differential GPS system with antennas on the nose and tail. Maybe that would be good enough - especially for flying in smooth air, like wave flying or early morning test flights. Or, maybe these units would measure quickly enough, all you'd need would be occasional 5-10 seconds of smooth air. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 08:13 PM |
| AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 03:13 PM |
