Polar Analysis from flight logs?
Old December 31st 04, 12:43 AM
Tim Ward
"Andreas Maurer" wrote in message
On Thu, 30 Dec 2004 13:36:59 -0800, Eric Greenwell
A Google search turned up laser airspeed sensors that, in concept, could
be used to measure L/D directly from the glider. Some of them were good
for the low speeds we need to measure sink rates. So, have one pointing
forward, one pointing down, divide the forward speed by the sink rate,
and ta-da! L/D. It wouldn't matter what the airmass was doing, since the
measurements are relative to the airmass.
This is exactly what is accomplished by today's L/D calculators that
use GPS speed and barometrical measured height loss over a given time.
No, it's not. That will give you the glide made good over the ground, but
it includes airmass movement.
It's confusing, because glider pilots tend to use glide angle and L/D
interchangeably.
I would suggest "glide angle" for the glide relative to the ground, and
"L/D" for the performance relative to the air.
To show you what I mean:
When I get into weak shear, my 1-26 may make a glide angle of 50:1. But its
L/D is more like 20:1
Tim Ward
Bye
Andreas
  #42
Old December 31st 04, 12:51 AM
Eric Greenwell
GPS speed and pressure altitude are referenced to the earth, not the air
mass, so they would determine a different L/D than airmass referenced
instruments. In concept, a glider flying at constant speed through
rising and falling air would have a constant L/D according to the laser
airspeed sensors, but a widely varying one based on GPS speed and
pressure altitude.
Eric Greenwell
Washington State
USA
  #43
Old December 31st 04, 09:26 PM
Andy Blackburn
in concept, could
of them were good
have one pointing
by the sink rate,
and ta-da! L/D.
Would you need an inertial platform to resolve horizontal
and vertical accurately enough or would eyeballing
it be good enough?
Also, the forward looking and downward looking lasers
would be observing different air, so it's possible
that would cause problems, depending on how far out
they look.
I think it might work - though at a hefty price I bet.
9B
  #44
Old December 31st 04, 10:17 PM
Eric Greenwell
in concept, could
of them were good
have one pointing
by the sink rate,
and ta-da! L/D.
it be good enough?
Since the concept is to measure speed through the airmass, I don't think
inertial systems would help any, as they are referenced to the aircraft,
not the air.
I don't know if any of the systems would actually give us the vertical
speed accuracy we'd like. A major application seemed to be for
helicopters, which can move very slowly (and even back up), so low speed
sensing is certainly feasible. Speeds over 20-30 knots seemed to be easy
to get with the units I glanced at.
they look.
The distances available varied from a "a few feet" to hundreds of feet,
I think. Very application dependent: helicopters couldn't use anything
that sensed closer that the outer edge of the rotor downwash, for
example. I'm guessing one for gliders could be set for, say, 100 feet to
be far enough from the glider's influence on the airmass, and this still
have both the forward and downward airmasses close enough to be the
"same" airmass.
Some of the sensors actually sensed at right angles to the sensor beam
to measure crosswinds, and maybe one of these could be also be pointed
straight down into the same airmass the vertical speed unit was looking at.
Yes, all the units I came across seemed to be high end or developmental,
and rather large to stick into a glider. A careful search might have
better luck.
A mitigating factor for cost is gliders already have a pretty good
forward airmass speed sensor - the ASI - so perhaps only a downward
aimed laser sensor good for measuring 100 to 500 feet per minute at 2%
accuracy would be satisfactory.
Eric Greenwell
Washington State
USA
  #45
Old December 31st 04, 11:09 PM
Tim Ward
snip
at.
better luck.
The sensor I posted a link to was small enough to be mounted on a rifle as a
sight.
http://www.navysbir.brtrc.com/succes...navsea_p3.html
That would seem to be a feasible size, weight and ruggedness for a glider
I've sent an email with some questions I had, but haven't yet received an
answer.
Some of the applications they mention on that website -- Automotive,
Collision Avoidance,
Cruise Control, Parking Aid, would require the cost to be fairly reasonable
(though the volume would be a lot more than sailplanes would ever give
them.)
If the laser and optics can be made to "see" through the canopy, pointing it
upward might make for an easier install. I've seen compasses mounted on top
of the panel.
OTOH, with it pointing downwards, it might give a good input to a gear
warning device. If it can detect small particles, I'll bet it can detect a
solid surface -- and that the signals are way different.
Eric Greenwell
Washington State
USA
  #46
Old January 1st 05, 04:21 AM
Andy Blackburn
I don't think
to the aircraft,
not the air.
I menat an inertial platform for attitude, not velocity.
If you the sensor isn't pointing horizontally/vertically
or parallel/perpendicular to the flight path, you will
likely get confounded results.
9B
  #47
Old January 1st 05, 04:36 AM
Eric Greenwell
better luck.
sight.
I thought it was something telescope sized that sat next to the
rifleman.I can see now it's about the size of a flashlite - much smaller
than the airspeed units I saw.
answer.
Let us know what they write.
them.)
of the panel.
Maybe a mirror adapter to peek out the side window. If the beam is small
enough, mounting it in the baggage compartment and pointing up through a
1/2" hole in the turtledeck wouldn't bother me.
Eric Greenwell
Washington State
USA
  #48
Old January 1st 05, 06:11 AM
Eric Greenwell
I don't think
to the aircraft,
not the air.
I think the angle of attack range for an unflapped airfoil is about 10
degrees, which would suggest errors of 0 (at high speed, for example)
increasing to 1.5% at low speed (or vice versa - depends on where you
aim the sensor). This could be easily corrected using using the
airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range
is even smaller, and the errors could likely just be ignored.
Eric Greenwell
Washington State
USA
  #49
Old January 1st 05, 07:10 AM
Andy Blackburn
airfoil is about 10
for example)
on where you
using the
fuselage AOA range
ignored.
50:1 is an angle of a degree and a bit so if you have
your 'straight ahead' and 'straight down' sensors canted
down/aft by just a degree from true horizontal/vertical,
you'll get a pretty accurate airspeed, but the 'vertical'
speed will likely show zero, I think, since it will
be reading off dust particles that have zero velocity
towards/away from the glider.
9B
  #50
Old January 1st 05, 08:28 PM
Eric Greenwell
airfoil is about 10
for example)
on where you
using the
fuselage AOA range
ignored.
Think of the glider flying straight and steady in still air: it is
descending (vertical motion) through the air at whatever it's sink rate
is. So, at least in concept, a laser airspeed sensor pointed straight
down will be able to measure this. Even if the sensor is aimed a few
degrees one way or the other from perpendicular, the error would be very
small, equal to sine of the angle off of perpendicular.
If the airmass is moving, the measurement would be the same, of course,
since the speed measured is the air motion relative to the glider - it's
just easier to visualize what's happening with still air.
Eric Greenwell
Washington State
USA
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
