draggy. ISTR that the Swiss and maybe the Finns were interested in
developing a pure AAM pylon that would be much smaller and less draggy than the current pylons, but I don't know if that ever went forward. You can see the results of that research on the F-18 E/F as stations 2 and 10. Ray |
Raymond Marshall wrote:
draggy. ISTR that the Swiss and maybe the Finns were interested in developing a pure AAM pylon that would be much smaller and less draggy than the current pylons, but I don't know if that ever went forward. You can see the results of that research on the F-18 E/F as stations 2 and 10. I think not. 2 & 10 are designed to carry 1,000 lb. A/G stores IIRR, far heavier than needed for an AAM, and in addition there's no room for such a pylon on an F-18A/C wing. The intent was to replace the current 2 & 8; presumably 3 and 7 wouldn't need to be carried for the AD role in Swiss or Finnish airspace. At most they might need a C/L tank. Guy |
As it can be seen on aviation photo web sites (like www.airliners.net)
Suomi's and Switzerland's Hornets are quite often flown in a clean or "almost clean" (w/fuel tank on the centerline) fighter configuration. As for the USN/USMC Hornets it's a different story. You put one fuel tank under the wing. You put the second on the centerline (this pylon in F/A-18A/C is not suitable for PGMs, also not very good for dumb bombs, so why waste another underwing pylon for a fuel tank?!) You put FLIR/NITE Hawk on the port nacelle station. And you have an aircraft for any mission - day or night, fighter or strike, 2VX/4VX self-escort flight... That's a bit different with Marine F/A-18Ds, carrying LITENING on no.5 (centerline)station. East or West - the rule must be the same - when something is assembled and works well, DON'T TOUCH IT! - so I would not be surprised when a Rhino once configured as a tanker stays as a tanker for a next few days... The F/A-18E/F gives some more capabilities: Thanks to ATFLIR (two pods in one, as a matter of fact!), an AMRAAM can be carried also for CAS sorties. You can use the "small" outboard wing stations for additional HARM or AMRAAMs for self-defense, being still capable of carrying PGMs and LOT OF extra fuel. You can even put a Maverick on a Rhino in a tanker configuration, in case any surface contacts may appear in the area! Jacek |
