Fueling from plastic gasoline containors
Old March 1st 05, 03:40 AM
Morgans
"LCT Paintball" wrote in message
news:17RUd.77210$tl3.9758@attbi_s02...
They usually are kinda expenssive in the short run, but will pay
off after a quanity of cheaper fuel has run through it. The fuel must
have
no alcohol, though.
What is kinda expensive?
STC's could be a hundred, to several hundred, or thousands if new pistons
and stuff for an engine are required. Top of head info only; I've never got
an auto fuel STC.
Why no alcohol?
Most airplane fuel systems and engines contain parts that do not react well
to alcohol. Some hoses and gaskets can swell up to more than double their
size.
The other major thing that needs to be looked at, is engine compression
ratios. If it is too high, the engine will detonate, and hammer or melt
holes in the pistons, and other important parts. Also, some fuel systems are
prone to vapor lock.
Jim in NC
Old March 2nd 05, 02:25 AM
LCT Paintball
are
Jim in NC
So, would it be safe to assume that an engine modified to use 87 octane auto
fuel would not run well on Aviation fuel?
What would you do if your auto fueled airplane was at an airport without
access to auto fuel?
Old March 2nd 05, 03:55 AM
Orval Fairbairn
In article fu9Vd.21974$Ze3.3954@attbi_s51,
are
Jim in NC
No.
Engines designed (or modified) to run on 87 octane auto fuel run on
100LL, with proper leaning. They can have a tendency to foul plugs if
proper care is not taken, however. Mogas STCs allow mixing of aviation
fuel with mogas, in any ratio. The main caveat is alcohol in the gas,
which is a no-no.
Old March 2nd 05, 04:50 AM
Morgans
which is a no-no.
You know how some people with cars put hi octane in, thinking it is going to
get them better performance? Waste of money, since no more power is
produced, without re-tuning the engine, but no problem.
Same with the airplane, going to the 100 octane. Problem is the Lead in the
100(L)ow (L)ead
There is a problem at times, with the lead buidup on valves. Usually not a
problem, if done on occasion. I you have to burn 100 LL, and want to be
perfectly safe, you can buy some stuff that will scavenge the lead out, but
it is pricey.
Jim in NC
Old March 2nd 05, 02:25 PM
Corky Scott
On Tue, 1 Mar 2005 23:50:28 -0500, "Morgans"
Unless it's one of those engines that has computer controlled
individual cylinder timing using a knock sensor. Those things will
retard the timing if knocking is sensed, and advance the timing as far
as possible when knocking is not sensed.
I remember seeing a Saab with such a system being dynoed using regular
first and then high test. The engine gained some power, although I
don't remember the exact figures. I just remember that it did gain
some.
With engines that do not have constantly adjusting timing, you are
correct, using high octane gas won't make any difference in power.
Corky Scott
Old March 2nd 05, 05:02 PM
Marv
Some links that may be of interest on the subject of static
discharge while fueling:
http://www.faa.gov/avr/afs/news/arch...ch/Static1.htm
http://www.faa.gov/avr/afs/news/arch...ch/Static2.htm
http://www.faa.gov/avr/afs/news/arch...ch/Static3.htm
http://www.globalair.com/discussions...cle~/msgID=237
3 of the above articles are at:
http://www.faa.gov/avr/afs/news/archive/march.cfm
Old March 2nd 05, 07:01 PM
jls
I have been fueling for years with plastic containers. As the first link
(from FAA) recommends, the fuel container nozzle is inserted into the tank
opening before fuel begins to flow, and the container nozzle continues
contact with the aircraft fuel tank throughout the process. I have never
seen a spark or had a fire, but always keep a halon fire extinguisher handy.
The aircraft is, of course, never refueled in the hangar. It is always out
on the ramp away from buildings, vehicles, and other aircraft.
That's not to say that a grounding wire should not be used.
"Marv" wrote in message
Old March 2nd 05, 11:06 PM
Morgans
Corky Scott
Given the fact that most airplane engines don't even have the most basic
advantage, even of vacuum advance, I didn't think that was a very important
factor. g
Good point, but most will only advance within a certain set of parameters.
I doubt if it would be enough to take advantage as much as if you changed it
manually.
Life rules state that there are always exceptions to the rules, right?
Jim in NC
Old March 2nd 05, 08:18 AM
Roger
On Mon, 28 Feb 2005 22:40:34 -0500, "Morgans"
have
no alcohol, though.
an auto fuel STC.
Why no alcohol?
size.
Just a note, that is not due tot he alcohol though.
Alcohol raises the octane rating with the maximum coming around 10%.
This is strange as Alcohol by itself has a very low octane rating.
My IO470N for one. The high compression and heat can be a real bear
in the summer for hot starts. OTOH it's built for the 100 octane
avgas.
www.rogerhalstead.com
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) J.R. Sinclair Aviation Marketplace 0 August 16th 04 05:59 AM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
