I'm calling it The Little Mermaid
Old March 15th 05, 05:26 AM
Morgans
"Jose" wrote in message news:b8uZd.5306
You are missing the point. Take a small engine, divide the output in
half,
and the prop is going to be small.
Why?
Because I can. Because that would divide the HP into two, so a smaller size
bike belt would be reliable. Pay attention.
Jim in NC
Old March 16th 05, 04:00 AM
Highflyer
:Yes, that is all true. The real problem is the rapid decline in the
efficiency of conversion from power to thrust as the propellor rpm
increases. The pounds of thrust per horsepower declines like a capacitor
discharge curve as the rpm increases and you have lost two thirds by the
time the prop rpm gets to 2000!
A ducted fan helps a little, but they are much less efficient than a big old
lazy unshrouded propellor chugging away.
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( KPJY )
PS: Pinckneyville rec.aviation flyin is coming up May 20, 21, and 22. See
the article in AOPA Online.
"Morgans" You are missing the point. Take a
small engine, divide the output in half,
and the prop is going to be small. Small props do not mind turning fast.
Also, if you use the belts for the RPM reduction, you have to put the big
pulley out on the pylon, where you want a small one.
Jim in NC
Old March 15th 05, 05:23 AM
Montblack
("Morgans" wrote)
My ideal sport plane would be an amphibian, if they get the rotating
landing gear back in.
http://www.beriev-usa.com/main/index.html
(You're half way there with this Russian number)
http://web.media.mit.edu/~tim/pix/oshkosh03_1/0788.jpg
(At Oshkosh)
http://web.media.mit.edu/~tim/pix/oshkosh03_1/0791.jpg
(At Oshkosh)
Montblack
Old March 15th 05, 04:17 PM
MJC
I'm calling it "dead in the water" :-)
MJC
"Montblack" wrote in message
High Performance Aircraft out of Germany - HPA TT62
http://www.hp-aircraft.de/edoc/tech.html
I'm calling it The Little Mermaid.
Montblack
I'm calling it The Little Mermaid Montblack Home Built 28 March 16th 05 04:27 AM
US Team Junior News, Calling US Juniors John Seaborn Soaring 0 October 4th 04 10:36 PM
Airman Finds True Calling as Part of 'Best Force' Otis Willie Military Aviation 0 September 10th 04 11:18 PM
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
Calling Tom Cooper. . . Iran stuff. . Drewe Manton Military Aviation 6 August 18th 03 10:35 AM
