Dan, U.S. Air Force, retired wrote:
Dick wrote: Received an old , externaly corroded Piper altimeter a while ago and I'd like to take it apart for a look-see but can't figure how the guts mechanism comes out. Presently have the glass lens, holder and knob off. Any suggestions short of cutting the case in two G would be appreciated. Thanks, Dick Look at the back of the case for screws. The innards are mounted to the back of the case. Dan, U.S. Air Force, retired Dan, can it be opened without destroying the instrument? I have a Garwin, Inc. altimiter. Serial number 721, dated Mar 29 1962. It's in working condition, and I'd like it to stay that way. It has a little crust on the inside of the front glass. Not enough for me to pay someone to clean it, but I'd like to run a damp cloth across it if I could get to it. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote:
Dan, U.S. Air Force, retired wrote: Dick wrote: Received an old , externaly corroded Piper altimeter a while ago and I'd like to take it apart for a look-see but can't figure how the guts mechanism comes out. Presently have the glass lens, holder and knob off. Any suggestions short of cutting the case in two G would be appreciated. Thanks, Dick Look at the back of the case for screws. The innards are mounted to the back of the case. Dan, U.S. Air Force, retired Dan, can it be opened without destroying the instrument? I have a Garwin, Inc. altimiter. Serial number 721, dated Mar 29 1962. It's in working condition, and I'd like it to stay that way. It has a little crust on the inside of the front glass. Not enough for me to pay someone to clean it, but I'd like to run a damp cloth across it if I could get to it. Sure can, just remove the faceplate. If you can find some gasket material to replace the old one so much the better, in any even use a pencil to make a witness mark on one side where the bezel meets the case. It's going to take a razor blade to scrap the crust. Just be very careful when you separate the bezel from the case. If it is internally lit don't try to take the glass out of the bezel. In internally lit instruments the glass is actually 2 wedge shaped pieces and lining them up is a royal pain. Make sure you leak check it when you are done. Dan, U.S. Air Force, retired |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
Local altimeter at BFM | Dan Luke | Instrument Flight Rules | 3 | June 15th 04 02:01 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 07:58 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
