I've been reading every post here for a few weeks. I am absolutely amazed by
the amount of knowledge that lives here! With the butt kissing done, I hope you'll excuse my ignorance. ![]() I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? What about titanium? Carbon fiber? What kind of testing needs to be done on a home built prop? Are there prop styles that can be copied without patent infringements? Has anybody tried making a flexible prop? My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. Could something like that give the performance of a constant speed prop without the complexity and added weight? If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? -- "Don't be misled, bad company corrupts good character." www.LCTPaintball.com www.LCTProducts.com |
![]() "LCT Paintball" wrote in message With the butt kissing done, I hope you'll excuse my ignorance. ![]() That is some first class "butt kissing." g I don't have many answers, but I'll answer what I think I know, since no one else has answered. I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? They are a standard in larger props. What about titanium? Don't know. I think the answer here, is that it is too brittle to stand up to the vibration, torque, and twisting. Carbon fiber? Yes. Some have been made with carbon fiber or fiberglass over wood or foam cores. What kind of testing needs to be done on a home built prop? Much has been written, and there are even programs to predict performance. Are there prop styles that can be copied without patent infringements? As long as you don't copy too closely. There are some special features of some props that are copyrighted. Has anybody tried making a flexible prop? Yes. Warp drive makes a flexible prop with a steel rod in the middle that twists the tips with an electric motor, to change profiles for climb to cruise. That is one feature that had better not be copied. My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. This has been done with a extremely swept back shape, called "scimitar", that as it unloads at high speed, the tips twist back to higher angles of attack. I am unaware if this is currently being produced. The trick is to select materials and thickness, to get the twist just right, to work as desired. Could something like that give the performance of a constant speed prop without the complexity and added weight? There will always be tradeoffs of complexity and weight for this. If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? Hmm. My suggestion is learn, and do it yourself. g I am sure there are more, here, that will correct some of what I have said, and add more, given time. -- Jim in NC |
news:wtn4e.12908$Vx1.12789@attbi_s01: I've been reading every post here for a few weeks. I am absolutely amazed by the amount of knowledge that lives here! With the butt kissing done, I hope you'll excuse my ignorance. ![]() I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? What about titanium? Carbon fiber? Yes, to carbon fiber at least. What kind of testing needs to be done on a home built prop? Are there prop styles that can be copied without patent infringements? Whatever you feel safe with, and a minimum of 40hrs (I think) on an experimental, if it is a new combination or major change. Has anybody tried making a flexible prop? My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. Could something like that give the performance of a constant speed prop without the complexity and added weight? Warnke almost constant speed among some. If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? Can you also provide the proper vehichle for the test period? x-- 100 Proof News - http://www.100ProofNews.com x-- 3,500+ Binary NewsGroups, and over 100,000 other groups x-- Access to over 1.6 Terabytes per Day - $8.95/Month x-- UNLIMITED DOWNLOAD |
Morgans wrote:
"LCT Paintball" wrote in message What about titanium? Don't know. I think the answer here, is that it is too brittle to stand up to the vibration, torque, and twisting. Not that I know (because I don't know), but it doesn't make sense that titanium would be an unsuitable material. Gas turbines using titanium alloy compressors have been around for, well, decades. Sort of an apples and oranges comparison, but still... On the other hand google doesn't seem to turn up anything, and it _always_ seems to turn up something (!?). |
![]() Morgans wrote: "LCT Paintball" wrote in message With the butt kissing done, I hope you'll excuse my ignorance. ![]() That is some first class "butt kissing." g I don't have many answers, but I'll answer what I think I know, since no one else has answered. I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? They are a standard in larger props. What about titanium? Don't know. I think the answer here, is that it is too brittle to stand up to the vibration, torque, and twisting. Carbon fiber? Yes. Some have been made with carbon fiber or fiberglass over wood or foam cores. What kind of testing needs to be done on a home built prop? Much has been written, and there are even programs to predict performance. Are there prop styles that can be copied without patent infringements? As long as you don't copy too closely. There are some special features of some props that are copyrighted. Has anybody tried making a flexible prop? Yes. Warp drive makes a flexible prop with a steel rod in the middle that twists the tips with an electric motor, to change profiles for climb to cruise. That is one feature that had better not be copied. My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. This has been done with a extremely swept back shape, called "scimitar", that as it unloads at high speed, the tips twist back to higher angles of attack. I am unaware if this is currently being produced. The trick is to select materials and thickness, to get the twist just right, to work as desired. Could something like that give the performance of a constant speed prop without the complexity and added weight? There will always be tradeoffs of complexity and weight for this. If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? Hmm. My suggestion is learn, and do it yourself. g I am sure there are more, here, that will correct some of what I have said, and add more, given time. -- Jim in NC |
"Yes. Warp drive makes a flexible prop with a steel rod in the middle that
twists the tips with an electric motor, to change profiles for climb to cruise. That is one feature that had better not be copied." Sorry Morgan, but it is Ivo that makes them prop. Warpdrive are rather rigid. J.P. "Morgans" wrote in message news ![]() "LCT Paintball" wrote in message With the butt kissing done, I hope you'll excuse my ignorance. ![]() That is some first class "butt kissing." g I don't have many answers, but I'll answer what I think I know, since no one else has answered. I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? They are a standard in larger props. What about titanium? Don't know. I think the answer here, is that it is too brittle to stand up to the vibration, torque, and twisting. Carbon fiber? Yes. Some have been made with carbon fiber or fiberglass over wood or foam cores. What kind of testing needs to be done on a home built prop? Much has been written, and there are even programs to predict performance. Are there prop styles that can be copied without patent infringements? As long as you don't copy too closely. There are some special features of some props that are copyrighted. Has anybody tried making a flexible prop? Yes. Warp drive makes a flexible prop with a steel rod in the middle that twists the tips with an electric motor, to change profiles for climb to cruise. That is one feature that had better not be copied. My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. This has been done with a extremely swept back shape, called "scimitar", that as it unloads at high speed, the tips twist back to higher angles of attack. I am unaware if this is currently being produced. The trick is to select materials and thickness, to get the twist just right, to work as desired. Could something like that give the performance of a constant speed prop without the complexity and added weight? There will always be tradeoffs of complexity and weight for this. If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? Hmm. My suggestion is learn, and do it yourself. g I am sure there are more, here, that will correct some of what I have said, and add more, given time. -- Jim in NC |
![]() "Jim Carriere" wrote Not that I know (because I don't know), but it doesn't make sense that titanium would be an unsuitable material. Gas turbines using titanium alloy compressors have been around for, well, decades. Sort of an apples and oranges comparison, but still... Two big differences, as I see it. One, props on piston engines receive massive power pulses, which are almost like stop and go, every 1/3rd to 1/2 rotation. A gas turbine blade has no pulses going to it; constant power and constant rotation. Two, the turbine blade is very short and wide, compared to the long slender prop. -- Jim in NC |
![]() "Jean-Paul Roy" wrote Sorry Morgan, but it is Ivo that makes them prop. Warpdrive are rather rigid. Ivo that makes them prop, Huh? g See, I told you I wuld git somethang wong. ;-) -- Jim in NC |
twists the tips with an electric motor, to change profiles for climb to cruise. That is one feature that had better not be copied. That has been done by Ivo Prop for a long time - www.ivoprop.com |
On Tue, 05 Apr 2005 03:19:57 GMT, "LCT Paintball"
wrote: I was interested in the discussion concerning the weight of different prop materials. Has anybody tried to make a hollow aluminum prop? What about titanium? Carbon fiber? I am not a prop expert and don't play one on TV either, but like you I've been hanging around here for a while (quite a long while actually) and have learned a thing or two. I also spoke with a Hamilton Standard engineer about a prop they built for the Lexus V-8 engine conversion. Hollow aluminum props are not uncommon. Don't know about titanium. Carbon fiber props are made all the time by a number of manufacturers, many are certified. Googling "carbon fiber propeller" brings many hits including Warp Drive, Ivo and Sensenich, to name a few. What kind of testing needs to be done on a home built prop? Are there prop styles that can be copied without patent infringements? Be aware, props live in an EXTREMELY harsh environment. They are subject to twisting loads, bending loads, centrifical forces and engine power pulses. In addition they suffer abrasion from sand, dust and gravel to rain and hail. The one material I'm pretty sure you can use without much worry about having one half of it disappear in flight is wood. Wood props dampen vibration, metal and some composites can accelerate vibration if encountered at the right frequency. The engineer I mentioned warned me that in his opinion, many of the non certified prop makers were making props that scared the absolute bejeesus out of him. Very few did the kind of comprehensive vibration testing that they (the makers of certified props) had to do, nor did they do long term systematic test runs. He thought that people should be extremely careful about what they use for a prop. Has anybody tried making a flexible prop? My thinking is that it might be possible to create a prop with a low angle of attack for high power take offs, then have it flex to a higher angle of attack as the load decreases. Could something like that give the performance of a constant speed prop without the complexity and added weight? Yes, a company did attempt to create a fixed pitch prop that varied it's pitch by being flexible fairly recently. They called it the Quasi Constant Speed Prop. It was computer designed using very special composite materials oriented in specific patterns and thread direction. They were scimitar shaped. They also incorporated different airfoils for different parts of the prop because the prop itself sees different airspeeds at different locations from the hub to the tip. Many props use a Clark Y airfoil, which seems counter intuitive when you realise that out at the tip, most props are going some 400 to 500 mph. Unfortunately, during vibration testing they discovered that the prop had some problems and the last time I checked they'd given up attempting to make an actual fixed yet variable pitch prop. If I were to play around with different prop designs, is there somebody around here with the knowledge and time that might be willing to test them for me? -- There are several on-line programs that allow you to design a prop. The problem is prop design is inherently complicated due to the many factors that go into their design. You have to factor in airplane weight, wingspan, how fast the airplane is supposed to go, altitude it will fly, air density, drag of the airframe, engine speed, prop diameter, pitch, material to be used, air foil design, planform. I mean it's almost hopelessly endless. The formulas used to determine various aspects of prop design look like nighmarish versions of greek. And that's if you're a mathematician. :-) There are also proprietary software designs that allow you to design your own prop. These aren't cheap but they will allow you to create your own prop and design virtually all aspects of it including the planform. All the formulas are built into the program. You have to plug in the particulars of your airplane. To me, prop making is such a black art that I gave up attempting to design my own and bought an Ivo. Corky Scott |
Options | [email protected] | Soaring | 32 | March 14th 05 05:33 PM |
Countering Widespread Ignorance About the National Guard | Rick Folkers | Military Aviation | 80 | March 14th 04 02:54 AM |
Fw: For Countering Widespread Ignorance about the National Guard | George Z. Bush | Military Aviation | 1 | March 3rd 04 10:02 PM |
Fw: For Countering Widespread Ignorance about the National Guard | George Z. Bush | Military Aviation | 1 | March 3rd 04 05:08 AM |
