stol wrote...
After 60+ hours on this package it has demonstrated everything I was expecting and more. I don't doubt that someday someone will build a successful auto conversion. Maybe someone already has. Maybe it's you. But you sure as snot don't know for sure after only "60+ hours" unless that plus adds a zero or two to that 60. Dave 'accelerated service test' Hyde |
On Fri, 21 Jan 2005 15:21:19 GMT, "Dave Hyde" wrote:
I don't doubt that someday someone will build a successful auto conversion. Maybe someone already has. Maybe it's you. But you sure as snot don't know for sure after only "60+ hours" unless that plus adds a zero or two to that 60. Does 2,000+ hours count? There is a Ford V6 STOL that achieved that mark several years ago. The owner/builder reached that time and tore the engine and PSRU down for inspection. He found no discernable wear in the cylinders and the belt appeared still viable. My understanding is that he installed new bearings and replaced the psru's cog belt anyway. Bruce can likely give more detailed information. Bruce can also give numbers on how many of the Ford conversions are over 1,000 hours. Corky Scott PS, I did not see where Ben claimed anything other than that he built the conversion and it is working fine so far. |
Geez. Once again I screwed up and posted my results from my auto
conversion on the wrong web group. You see I was trying to inform all the EXPERIMENTAL people that are " dreaming, thinking about, building or just curious about homebuilt aircraft and dumb me I posted it on the CERTIFIED plane group instead I put it here......... Wait !!!!! late breaking news !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is the rec.aviation. HOMEBUILT. newsgroup. Please Dave Hyde find something wrong with this ... Ben' thank god I don't have a certfied Lycoming crank that will break in my plane' Haas. |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
advanced fuel flow mesurement system using microcontroller | khanindra jyoti deka | Home Built | 4 | January 4th 05 01:18 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
