How do you know when you're beginning to sand into the glass cloth? Do
you simply sand until you have a smooth finish, then stop? Ot do you keep going? thanks, joe mcguckin |
You will know it trust me !!!
You will see the weave start to appear. Depending on the composite the fibres will have a dull appearance and the resin a more shiny look ... there is a contract that allows you to see the weave of the fabric. If you go into the fabrix it will need to be repaied so go slow. wrote in message ps.com... How do you know when you're beginning to sand into the glass cloth? Do you simply sand until you have a smooth finish, then stop? Ot do you keep going? thanks, joe mcguckin |
![]() Roger wrote: On 27 Jan 2005 01:04:49 -0800, wrote: How do you know when you're beginning to sand into the glass cloth? Do you simply sand until you have a smooth finish, then stop? Ot do you keep going? thanks, Are you sanding to get a smooth finish or to prepare for the next lay-up? If you are getting ready for the next lay-up you are sanding to "rough up" the surface to get a good bond to the next layer, not smooth it. With Vinyl Ester Resin I use 60 or 80 grit (hard to get a smooth finish with thatG) and just rough up the area. I then vacuum the area clean and follow up with an Acetone wash. With the area dry or just barely tacky I do the next lay-up. For smoothing, as opposed to scuffing, has anyone tried scraping instead of sanding? Using a scraper like this: http://www.leevalley.com/wood/page.a...=1,310&p=32669 one can get a finish on wood roughly equivalient to sanding down to 320 or 400 grit. Scrapers are especially good for removing bumps and runs in film finishes like shellac and varnish so I'd imagine that they'd do a good job on hardened epoxies and resins too. The cabinet scraper is not a paint scraper, it is a much more versatile tool. Proper tuning of the scraper is a bit of an art form but with an understanding of the process and a little experience one can remove a large amount of material, or only a small amount with each pass. It is much cleaner and faster than sanding because it raises shavings instead of making dust. -- FF |
Why sand at all. Steve Beert's prize winning Long was sandblasted, then
micro was squeegee over the top , then a little sanding and paint prep. wrote in message oups.com... Roger wrote: On 27 Jan 2005 01:04:49 -0800, wrote: How do you know when you're beginning to sand into the glass cloth? Do you simply sand until you have a smooth finish, then stop? Ot do you keep going? thanks, Are you sanding to get a smooth finish or to prepare for the next lay-up? If you are getting ready for the next lay-up you are sanding to "rough up" the surface to get a good bond to the next layer, not smooth it. With Vinyl Ester Resin I use 60 or 80 grit (hard to get a smooth finish with thatG) and just rough up the area. I then vacuum the area clean and follow up with an Acetone wash. With the area dry or just barely tacky I do the next lay-up. For smoothing, as opposed to scuffing, has anyone tried scraping instead of sanding? Using a scraper like this: http://www.leevalley.com/wood/page.a...=1,310&p=32669 one can get a finish on wood roughly equivalient to sanding down to 320 or 400 grit. Scrapers are especially good for removing bumps and runs in film finishes like shellac and varnish so I'd imagine that they'd do a good job on hardened epoxies and resins too. The cabinet scraper is not a paint scraper, it is a much more versatile tool. Proper tuning of the scraper is a bit of an art form but with an understanding of the process and a little experience one can remove a large amount of material, or only a small amount with each pass. It is much cleaner and faster than sanding because it raises shavings instead of making dust. -- FF |
On Fri, 28 Jan 2005 21:00:17 GMT, "Cy Galley"
wrote: Why sand at all. Steve Beert's prize winning Long was sandblasted, then micro was squeegee over the top , then a little sanding and paint prep. Wow, now there is an inovative guy with a lot of courage. But Cy, a lot of the Long's need the sanding to make the surfaces **REALLY** smooth, y'know, laminar. So they use long pieces of 1x4's with sandpaper glued to it to make sure they don't sand a crater into the surface. The purpose of this type of sanding is to remove any irregularities, not just rough up the surface. Corky Scott |
![]() "Cy Galley" wrote in message news:BJxKd.33031$EG1.4274@attbi_s53... Why sand at all. Steve Beert's prize winning Long was sandblasted, then micro was squeegee over the top , then a little sanding and paint prep. Well, on sailplanes, anyway, you sand to make sure the airfoil is the right shape, (shrinkage can occur over the spars after some time out of the molds), and to make sure that any waves in the contour are less than .004 inches. Tim Ward |
I have to presume that he was both quick and gentle with the sandblasting;
as the most common theme that I have heard, over many years, from experts in composites is: "the less you sand, the better you sand." That is very much in keeping with Burt Rutan's remarks, back when he was actively selling plans for the Vari-Eze and Long-Eze. The one I remember best was: 'The more time you spend on your cores, the less time you will spend on your airplane.' The reason for the single quotation marks is that I believe the statement to be a very close paraphrase, but probably not exact, as more than twenty years has elapsed. The other was that a very slightly dry top layer was regarded as less detrimental than a too wet top layer. Both reduce strength, and the too wet surface also adds weight and additional finishing requirements. As I recall it, the primary control of the wetness of the layup was the angle of the squeegee when removing the excess resin which had been stippled in... Keep in mind that Burt was quite emphatic regarding the need for the entire lay-up to be fully wetted out. Therefore, I really like the idea of a light pass of sandblasting (or bead blasting) to prepare the surface for the last micro application. I plan to use the advice! "Cy Galley" wrote in message news:BJxKd.33031$EG1.4274@attbi_s53... Why sand at all. Steve Beert's prize winning Long was sandblasted, then micro was squeegee over the top , then a little sanding and paint prep. wrote in message oups.com... Roger wrote: On 27 Jan 2005 01:04:49 -0800, wrote: How do you know when you're beginning to sand into the glass cloth? Do you simply sand until you have a smooth finish, then stop? Ot do you keep going? thanks, Are you sanding to get a smooth finish or to prepare for the next lay-up? If you are getting ready for the next lay-up you are sanding to "rough up" the surface to get a good bond to the next layer, not smooth it. With Vinyl Ester Resin I use 60 or 80 grit (hard to get a smooth finish with thatG) and just rough up the area. I then vacuum the area clean and follow up with an Acetone wash. With the area dry or just barely tacky I do the next lay-up. For smoothing, as opposed to scuffing, has anyone tried scraping instead of sanding? Using a scraper like this: http://www.leevalley.com/wood/page.a...=1,310&p=32669 one can get a finish on wood roughly equivalient to sanding down to 320 or 400 grit. Scrapers are especially good for removing bumps and runs in film finishes like shellac and varnish so I'd imagine that they'd do a good job on hardened epoxies and resins too. The cabinet scraper is not a paint scraper, it is a much more versatile tool. Proper tuning of the scraper is a bit of an art form but with an understanding of the process and a little experience one can remove a large amount of material, or only a small amount with each pass. It is much cleaner and faster than sanding because it raises shavings instead of making dust. -- FF |
![]() Tim Ward wrote: Well, on sailplanes, anyway, you sand to make sure the airfoil is the right shape, (shrinkage can occur over the spars after some time out of the molds), and to make sure that any waves in the contour are less than ..004 inches. That's another reason to try scraping. Scrapers can be filed to a particular curve for just that sort of work. -- FF |
![]() wrote in message oups.com... Tim Ward wrote: Well, on sailplanes, anyway, you sand to make sure the airfoil is the right shape, (shrinkage can occur over the spars after some time out of the molds), and to make sure that any waves in the contour are less than .004 inches. That's another reason to try scraping. Scrapers can be filed to a particular curve for just that sort of work. -- FF The curvature changes continuously chordwise, and most sailplane wings have taper, so the curvature will change with the spanwise station as well. So it's difficult for me to see how you could cut a single curve that would match. Now, for a constant chord wing, that might make an interesting production technique: Build your wing, then build up an extra layer of filler, then "extrude" the whole wing panel through a CNC cut scraper, getting exact, smooth coordinates on the way. Tim Ward |
composites propeller | Philippe | Home Built | 2 | August 4th 04 10:45 AM |
composites vs. aluminum | John C | Home Built | 23 | May 7th 04 04:31 AM |
Marske Flying Wings workshop in composites | Matthew J Redsell | Home Built | 1 | February 10th 04 01:41 PM |
Scaled Composites builds plane for solo nonstop globe circumnavigation attempt | David O | Home Built | 23 | October 30th 03 11:15 AM |
Scaled Composites X-Prize vehicle flying again after mods | David O | Home Built | 0 | October 26th 03 05:47 AM |
