Don't drill out those rivets! They are only holding a circular
gasket flange ring on the top skin. After all the screws are out, you have to be a little less gentle with that skin and lift it enough that the gasket flange ring will clear the tank neck and allow the skin to slide out from under the leading edge skin and cabin roof skin. Cessna wants those skins off every 1000 hours, and there's good reason. We have found broken tank restraining straps, missing strap chafe protection, rubber tank support and top skin straps rotted away and the tank rubbed through (or almost through) against aluminum structure, fuel stains around the filler neck weld indicating a crack that could suddenly get serious, and so on. (Line boys with their big fuel nozzles tend to let the tank neck take the hose weight, and that cocks the tank neck and cracks the weld.) Once the mechanic has done a couple of these inspections they're not a big deal. The skins are much harder to get back into place thatn they are to take out, especially if the tank was moved a bit; the filler neck will no longer line up with the skin when the skin's screw holes are lined up with the wing's holes. You'll need a couple of new gaskets for the filler neck, at typical Cessna prices. Dan |
Thank you very much Dan for the info.
Tom wrote in message ups.com... Don't drill out those rivets! They are only holding a circular gasket flange ring on the top skin. After all the screws are out, you have to be a little less gentle with that skin and lift it enough that the gasket flange ring will clear the tank neck and allow the skin to slide out from under the leading edge skin and cabin roof skin. Cessna wants those skins off every 1000 hours, and there's good reason. We have found broken tank restraining straps, missing strap chafe protection, rubber tank support and top skin straps rotted away and the tank rubbed through (or almost through) against aluminum structure, fuel stains around the filler neck weld indicating a crack that could suddenly get serious, and so on. (Line boys with their big fuel nozzles tend to let the tank neck take the hose weight, and that cocks the tank neck and cracks the weld.) Once the mechanic has done a couple of these inspections they're not a big deal. The skins are much harder to get back into place thatn they are to take out, especially if the tank was moved a bit; the filler neck will no longer line up with the skin when the skin's screw holes are lined up with the wing's holes. You'll need a couple of new gaskets for the filler neck, at typical Cessna prices. Dan |
Cessna wants those skins off every 1000 hours, and there's good reason. We have found broken tank restraining straps, missing strap chafe protection, rubber tank support and top skin straps rotted away and the tank rubbed through (or almost through) against aluminum structure, fuel stains around the filler neck weld indicating a crack that could suddenly get serious, and so on. snip I'll second that assessment. Tank skins need to be pulled far more often than most people bother to pull them. The OP's mechanic is doing his job. See our recent experience on my site. Click through: Aviation-Articles-Maintenance-Fuel Tank Repair -Doug -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
Good article. Your airplane has an older style fuel cap and flange
arrangement than the original poster, and his skins are more difficult to remove. His advantage is not having that recessed pit around the cap that collects water and dirt; the cap flange is flush with the wing. His disadvantage is getting that gasket back into place while replacing the skin; a bit of fuellube will hold it in place. I suspect his tank skin is being hard to remove because someone used Form-A-Gasket or something tough to seal the gasket last time, and it's stuck good. 172s used all-brass floats by the time our L and M models came out. They're OK, but we had one fail because the arm stop was misadjusted and the float was tapping the top of the tank when the tank was full of fuel. It wore a hole in the float, which filled and sank. Dan |
![]() wrote in message ups.com... Good article. Your airplane has an older style fuel cap and flange That is correct Dan. My cap is flush with wingskin. Once I get it the skin loose, the skin will slide across the neck. a bit of fuellube will hold it in place. I suspect his tank skin is being hard to remove because someone used Form-A-Gasket or something tough to seal the gasket last time, and it's stuck good. Yes, I saw the hardened sealant when I removed the screws. There is definitely no way or place to pry or use a tool to losen the skin without ruining any components so it is going to be interesting. \The Cessna manual calls for some specific types of sealant to use, one being a Dow Corning product, and others. I have not ordered any gaskets yet as I am waiting to see if I to need any other components such as tank restraining straps, chafe protection, rubber tank supports, top skin straps, and the sealant. Tom |
Cessna wing jig plans | Clay | Aviation Marketplace | 0 | December 21st 03 03:58 PM |
Cessna wing jig plans | Clay | Owning | 0 | December 21st 03 03:57 PM |
Cessna Wing Jig | Clay | Owning | 0 | December 17th 03 01:56 PM |
Cessna Wing Jig | Clay | Restoration | 0 | December 17th 03 01:55 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
