On Sun, 24 Apr 2005 15:06:51 -0700, "Matt Barrow"
wrote: Pushing can be done with the tractor because it has a nice (read strong) two speed reverse gear (and three forward). I use it to get the bird back into the hanger as there is about a 2" lip to across on the foundation slab. Our tractor has multiple slow speeds, too. I think there are about ten or twelve forward and four reverse. But my problem has to do with the joints at the towbar-tractor and towbar-a/c. Once I get a little off, I can't seem to (easily) get things straightened out again. And the Mooney has fairly narrow nosewheel turning limits (+/-15° if I recall correctly). I'm sure with practice I could do better. But now with the Nose Dragger Dragger I don't use the tractor, unless I have to tow long distances (in which case I pull and don't push). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... On Sun, 24 Apr 2005 15:06:51 -0700, "Matt Barrow" wrote: Pushing can be done with the tractor because it has a nice (read strong) two speed reverse gear (and three forward). I use it to get the bird back into the hanger as there is about a 2" lip to across on the foundation slab. Our tractor has multiple slow speeds, too. I think there are about ten or twelve forward and four reverse. But my problem has to do with the joints at the towbar-tractor and towbar-a/c. Once I get a little off, I can't seem to (easily) get things straightened out again. And the Mooney has fairly narrow nosewheel turning limits (+/-15° if I recall correctly). I think that's more than the Bonanza. Hmmm... I always found it was like backing a trailer. If things get out of whack (as opposed to in whack) just go forward and start over. I try to avoid counting on the nosewheel being able to make up for my misalignment. One thing is to avoid trying to cut some sharp angles. Also, having enough room is helpful; if our taxiway lane was more cramped, I'd probably find it a lot more traumatic. Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
On Mon, 25 Apr 2005 07:14:02 -0700, "Matt Barrow"
wrote: Hmmm... I always found it was like backing a trailer. If things get out of whack (as opposed to in whack) just go forward and start over. Well, I don't have any experience backing a trailer. So that's probably why I spent almost equal times in forward as in reverse :-)) Fortunately, for me, I have another solution , now. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... On Mon, 25 Apr 2005 07:14:02 -0700, "Matt Barrow" wrote: Hmmm... I always found it was like backing a trailer. If things get out of whack (as opposed to in whack) just go forward and start over. Well, I don't have any experience backing a trailer. So that's probably why I spent almost equal times in forward as in reverse :-)) Fortunately, for me, I have another solution , now. Just remember that the trailer (or whatever) goes in the direction you turn the steering wheel. :~) -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
On Tue, 26 Apr 2005 07:35:35 -0700, "Matt Barrow"
wrote: Just remember that the trailer (or whatever) goes in the direction you turn the steering wheel. :~) I do. I still can't get the nack of it. Lots of PIO here :-( Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
