I'm an experienced aircraft painter as well as a retired Auto Body-Man.
If I wasn't sure of what I was doing, but wanted the experience of Painting my own Aircraft, I'd Go to my Dupont jobber ( Phone Book under Paint, Automotive) and buy Imron polyurethane, rent a 'supplied Air respirator', and talk the ears off (asking questions) of the guy behind the counter that has the experience ( there's always at least one guy) and KNOW that if it screws up, IE: gets a run, Gets Dirt in it, Gets a bug in it, goes on too dry, Or you get your pants leg into the wet paint ( Happens wayyy to often) that in the first 20 hours of Imrons life, you can color-sand and Buff just about any Goof-up out to (almost) perfection, Hell, you can even color sand and buff your entire Airplane to a mirror finish if you Practice on something like a refrigerator first, start sanding within the first 10 hours, and don't mind spending 20 to 40 straight hours at hard labor, and your in good enough shape, and had your Wheaties for Breakfast! I'd also use Base Coat - Clear coat. While some might argue that the 2 part system (Base coat- Clear coat) is heavier than just simple solid colors, because... Hey! your putting paint on twice Right? ... Well my 35 years experience says thats just not true. The Base-coats tends to cover much quicker and be a very 'thin' coat that you can 'manipulate' to get as close to perfection as possible. Because a good quality (it should require a 'catalized reducer') Base Coat will dry almost instantly, minor imperfections can be scuffed out and the area can be spot re-coated instantly. This is true with Solid colors AND metallics. Then when the Base coat is satisfactory, the Nature of the Clear-Coat is that it takes very little to achieve a beautiful gloss. It's just soo deep and pretty. With Imron I usually do two coats reduced a little thinner ( Get a viscosity cup from your jobber and test the paint right before you spray) than normal Automotive work to try to keep the material build ( Weight) to a minimum. Clear Coats are not necessary, But if you are thinking of using a metallic color, (and there are some Very beautiful Metallic colors out there) and you lack experience, then I recommend Base coat /clear coat system. Makes life much easier to get the Metallic even in a base coat than trying to spray single stage paint WET and then coming back over it to even out the metallic. Hope this helps. Jay Markland Dayton Ohio |
Opinions wanted on UK integrated CPL(H) courses | Simon Robbins | Rotorcraft | 5 | October 18th 04 05:02 PM |
paint shop recommendations wanted (SE) | Stephen N Mills | Owning | 0 | January 29th 04 03:44 PM |
Opinions Wanted - Arrow, Archer, 182, 177RG, Early 210's | Larryskydives | Owning | 28 | January 25th 04 05:51 AM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
Opinions wanted: Accelerated Flight Training Center of Arizona | Ross Oliver | Instrument Flight Rules | 3 | December 31st 03 06:23 PM |
