1) Our engine monitor (JPI EDM-700) sometimes indicates sporadic EGT
values for #1 cylinder. It behaves like a sensor or connection issue as the engine runs fine and the fuel burn is within expected values. #1 CHT value dances up and down fairly rapidly +/- 25 degrees or so of the value as compared to the other cylinders. The value changes fairly rapidly (much more so than with the other cylinders). The problem has come and gone consistent with some sort of wiring issue. Anyone seen a similar problem? Engine is IO-360. Follow the wiring for the #1 cylinder from the spark plug to the firewall. We had a similar problem with our #2 cylinder, and it turned out to be a bad in-line connection/splice. An easy, ten second fix. 2) Right brake pedal travel is noticeably more than the left. Stopping power of both brakes is fine and the fluid level is only slightly down from the full line. Applying the parking brake while rolling causes the plane to slightly turn left, consistent with the left brake applying ahead of the right. No hydraulic leaks anywhere that I can see. Could it be air in the system that needs to be bled? I've had the exact problem, ever since my last annual, when we replaced a brake hose. I've had my A&P bleed that brake three times now -- each time it gets a little better -- but it's still not quite "right." Bleeding Cherokee brakes properly is a real bitch, involving more than just bleeding the system down at the wheel. You have to get under the panel, stand on your head, and bleed the system under there, too, resulting in the inevitable brake fluid on the carpet, etc. It's not a great system. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Fun weekend buying an Arrow (long) | Jack Allison | Owning | 44 | April 20th 05 12:29 PM |
Any real-life advice on inflight refueling? | tscottme | Naval Aviation | 5 | November 17th 04 03:56 PM |
Route Advice? KGEU (Phoenix) -> KEMT (Los Angeles) | Eclipsme | Piloting | 4 | August 13th 04 04:15 AM |
Opinions Wanted - Arrow, Archer, 182, 177RG, Early 210's | Larryskydives | Owning | 28 | January 25th 04 05:51 AM |
Tail Skid Help / Advice | Ray Lovinggood | Soaring | 3 | January 2nd 04 08:16 PM |
