"Doug" wrote in message ups.com... What kind of engines did the aircraft on the Jefferson City flight have? What kind of engines are on the Boeings that Bob flew? Gas Turbine Engines. Mike MU-2 |
Mike,
Yes, Gas Turbine Engines. But what design, what manufacturer? Different airplanes and different engines behave differently. But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). But I will yield, as I have no supporting data. The supporting data would be a climb limitation in the manufacturers flight manual. I don't have it, but I am sure it exists. These internet arguments are never won anyway. I'm not really interested in winning. Probably should have worded my initial statement a little less concretely. I honestly thought this was the cause. Apparently not, or at least not sure yet, or not public yet. Whatever. It's just my theory. Sorry about the two pilots dying. That is a tough one for the families I am sure. Whatever the reason is, I am sure we all want it found out so that other pilots and passengers can benefit from the knowledge. Airline travel is very safe, statistically, by the way. But you already know that. Sorry if I ruffled any feathers.. |
"Doug" wrote
But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). Young man...you don't have the foggiest idea about the operation of aircraft jet engines. Bob Moore |
"Doug" wrote in message oups.com... Mike, Yes, Gas Turbine Engines. But what design, what manufacturer? Different airplanes and different engines behave differently. But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). But I will yield, as I have no supporting data. The supporting data would be a climb limitation in the manufacturers flight manual. I don't have it, but I am sure it exists. These internet arguments are never won anyway. I'm not really interested in winning. Probably should have worded my initial statement a little less concretely. I honestly thought this was the cause. Apparently not, or at least not sure yet, or not public yet. Whatever. It's just my theory. Sorry about the two pilots dying. That is a tough one for the families I am sure. Whatever the reason is, I am sure we all want it found out so that other pilots and passengers can benefit from the knowledge. Airline travel is very safe, statistically, by the way. But you already know that. Sorry if I ruffled any feathers.. Frankly the overtemping due to climb theory is ridiculous and it doesn't matter what gas turbine engines you are talking about. The fuel controllers constantly sample inlet air temp and pressure along with the pressure at the compressor discharge and trim the fuel flow to prevent the hot section temperature from changing without power lever movement. More sophisticated fuel controllers will allow the temp to rise with decreasing mass flow to the temperature limit (or one of several limits) while keeping some other parameter constant (like N1, fan rpm) then trim the fuel flow back to avoid over temping the hot section. In any case it is fuel flow (ie mixture) that determines temperature and the fuel controller is not going to be fooled by climbing fast. You are thinking about the problem like you would a piston engine. Limiting turbine engine temperatures are analogous to EGT on a piston engine, they are *not* analagous to CHT on a piston engine. It is a function of fuel flow which is constantly monitored and adjusted by the fuel controller...ie a *mixture* issue not a cooling issue. Mike MU-2 |
Here is another clue:
http://www.ntsb.gov/events/2005/Pinn...its/314036.pdf And, like I said. I really don't know either. |
Yeah, gotta stop thinking climb rate and start thinking climb SPEED.
If you don't climb at enough speed, bad things can happen. (But climb speed is related to rate of climb to some extent, so maybe not so far off). |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Palo Alto airport, potential long-term problems... | [email protected] | Piloting | 7 | June 7th 05 12:32 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| Where to soar near Jefferson City - Missouri? | Peter | Soaring | 2 | September 15th 03 04:29 PM |
