"John Sp" wrote in message ... Our gliding club towplane (Piper Super Cub) has developed play in the Fuselage / Main strut connection - Portside. The bolt and clevis (Fork) seem to be OK bolt is a reasonably snug fit in the fork. - I presume the play is in the hole in the Bracket welded to the fuselage. Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle " At the wing tip. Can anyone help with the following - What is the permitted wear at this point ? (If any) What approved repair methods can be used here? Being a pilot myself, I think you have more of a concern that merely fixing the play in the strut end. If it has been wiggling the the hole, there's a high likelihood of fretting corrosion and fatigue in the element around the hole. I hate to say this, but you might need to check if there are any Airworthiness Directives out on that model, about that part. LLoyd |
| Thread Tools | |
| Display Modes | |
| Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 11:38 PM |
| SSA Website problem | Raphael Warshaw | Soaring | 2 | February 12th 04 03:56 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
| Help with serious Glider Registration Problem | Soaring | 5 | November 12th 03 05:01 PM | |
| Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 04:06 PM |
