"unknown" wrote:
Its too bad there's not a way to test for the ability to differentiate between what is important and what is not. Wow.... There is. Look at the age on death certificates. |
Ken Pruchnick wrote: What is the proper way to switch transponder codes? The way I have been taught is to put the transponder in stand by, switch to the new code. Then turn it to mode C I had an instructor tell me to just change it to the new code without turning it to stand by first. Like to hear from controllers as to what they prefer. Just change the numbers, it doesn't matter how you do it. On my plane the transponder never goes into standby, there's no good reason to ever turn your transponder off of the ALT position if it is working properly and you have an avionics master. |
I put mine in the alt position after clearing the runway. That way, next
time I turn on the avionics I'm not squawking an IFR code that might be in use. Newps wrote: Ken Pruchnick wrote: What is the proper way to switch transponder codes? The way I have been taught is to put the transponder in stand by, switch to the new code. Then turn it to mode C I had an instructor tell me to just change it to the new code without turning it to stand by first. Like to hear from controllers as to what they prefer. Just change the numbers, it doesn't matter how you do it. On my plane the transponder never goes into standby, there's no good reason to ever turn your transponder off of the ALT position if it is working properly and you have an avionics master. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
"Ray Andraka" wrote in message ... I put mine in the alt position after clearing the runway. That way, next time I turn on the avionics I'm not squawking an IFR code that might be in use. I assume you meant to write "stby" in place of "alt". |
No, I only squawk on the ground. That way no one knows where I am ;-).
Guess it is old age catching up with me, huh? "Steven P. McNicoll" wrote: "Ray Andraka" wrote in message ... I put mine in the alt position after clearing the runway. That way, next time I turn on the avionics I'm not squawking an IFR code that might be in use. I assume you meant to write "stby" in place of "alt". -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Ray Andraka wrote: I put mine in the alt position after clearing the runway. That way, next time I turn on the avionics I'm not squawking an IFR code that might be in use. Doesn't matter as the software in the radar is calibrated so as not to display a code on the airport. We have ours set so no transponder returns show until you get more than 1/2 mile away from the antenna, otherwise the airport would be a clogged mess of returns. And you're not worried about a code that is in use but one that is not yet in use. |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| FS: Narco AT-50A Transponder with ACK Encoder | JR | Home Built | 0 | April 29th 04 12:33 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| For Jim Weir: Transponder Installation | Ron Wanttaja | Home Built | 11 | February 3rd 04 04:26 PM |
| transponder check? | Russell Duffy | Home Built | 10 | August 15th 03 12:36 AM |
