... Portable Halon extinguishers made before 1995 are legal for use. Aircraft are still allowed to use Halon. It is illegal to release holon into the environment except for use in "emergency" fires (ie it is illegal to use for "training" purposes) This, of course, varies with the country. IMHO, Halon is not the ideal extinguishing agent for most aircraft fires, especially in-flight. In order for Halon to be effective, it must be applied to the fire before anything in the vicinity of the flammable gases becomes heated to the ignition temperature of the gas, otherwise the fire will re-ignite as soon as the concentration of the Halon drops below the percentage needed to interfere with combustion. Establishing and maintaining the required concentration of Halon is difficult, if not impossible, in an open space. Even closed environments such as sealed buildings are difficult to permeate. It is likely impossible under an aircraft cowling when the plane is moving. One needs to understand the process by which Halon inhibits fire. The fuel (usually carbon-based material) has a greater affinity for the Halogens (Chlorine, Fluorine, Bromine & Iodine) that it does for Oxygen. In the presence of both Oxygen and a Halon, the fuel will "choose" to combine with the Halon without the evolution of heat and light - what we call "Fire". If sufficient Halon is available, all the fuel will combine with the Halon and the fire will go out. If the Halon is removed and there is still a source of ignition, the fire will take up right where it left off. If you've got a cabin fire, that's a horse of a different smell. Rich S. |
Rich S. wrote:
Establishing and maintaining the required concentration of Halon is difficult, if not impossible, in an open space. Even closed environments such as sealed buildings are difficult to permeate. It is likely impossible under an aircraft cowling when the plane is moving. I disagree. Have you ever used a Halon fire extinguisher? Back in the Reagan era when the defense departement had a lot of money and Halon hadn't yet been restriced, we were given training where we used large Halon hand extinguishers to put out diesel fuel fires set in pans outside. If the Halon is removed and there is still a source of ignition, the fire will take up right where it left off. If you've got a cabin fire, that's a horse of a different smell. With a flood system and a relatively closed space it takes a long time for the Halon to disapate. Try lighting a lighter in a space near where halon has been discharged. Of course, much of what you said also applies to CO2. If the CO2 doesn't cool down the metal (which admittedly it has a higher capacity to do than Halon), then you have the same (actually larger) reignition problems. |
the key statement is...
"It is likely impossible under an aircraft cowling when the plane is moving. " For this application it is a waste of weight, money, and time. "Ron Natalie" wrote in message m... Rich S. wrote: Establishing and maintaining the required concentration of Halon is difficult, if not impossible, in an open space. Even closed environments such as sealed buildings are difficult to permeate. It is likely impossible under an aircraft cowling when the plane is moving. I disagree. Have you ever used a Halon fire extinguisher? Back in the Reagan era when the defense departement had a lot of money and Halon hadn't yet been restriced, we were given training where we used large Halon hand extinguishers to put out diesel fuel fires set in pans outside. If the Halon is removed and there is still a source of ignition, the fire will take up right where it left off. If you've got a cabin fire, that's a horse of a different smell. With a flood system and a relatively closed space it takes a long time for the Halon to disapate. Try lighting a lighter in a space near where halon has been discharged. Of course, much of what you said also applies to CO2. If the CO2 doesn't cool down the metal (which admittedly it has a higher capacity to do than Halon), then you have the same (actually larger) reignition problems. |
On Tue, 19 Jul 2005 15:11:53 GMT, "Cy Galley"
wrote: the key statement is... "It is likely impossible under an aircraft cowling when the plane is moving. " For this application it is a waste of weight, money, and time. I remember a "discovery" or "military weapons" show I watched one time where they were attempting to find a substitute for the Halon based fire extinguishing system being used on some military jet. They demonstrated the ability of the Halon system to put out a fire created by a 20mm cannon hit, under controlled conditions. The conditions included being in a wind tunnel, or directing high speed air onto the area to be hit to simulate relatively high speed flight. The Halon based system did a pretty good job of snuffing the fire out from the cannon shell hit, even while the flame was being fanned by the high speed air. Must have been a lot of Halon, I guess. None of the other types of systems shown seemed to work quite so well. This all came to be because Halon is a CFC, as is the refrigerant R-12. They are both similar inert gasses. I recall a demonstration one time wherein this guy breathed in from a hose of R-12, and then breathed out over a lit candle. The R-12 settled over the flame and extinguished it. As a mechanic back in the 70's, we used to discharge that stuff all over the place. It didn't matter we were told, it was an inert gas... Corky Scott |
![]() Corky Scott wrote: This all came to be because Halon is a CFC, as is the refrigerant R-12. They are both similar inert gasses. They ARE very stable, but not 'inert gasses'. Historically 'inert gasses' were a handful of chemical elements, that in their natural state at room temperature were monatomic gasses, and which would not form any chemical compounds under any conditions. Sometime after the mid 20th century some shortlived compounds of Neon (and maybe some others) were formed under laboratory conditions. Consequently, the proper term for these gasses was changed to 'noble' gasses, meaning the were reluctant to combine with other elements, but not completely inert. AFAIK 'inert gas' remains as an archaic term synominous with 'noble gas'. ... It didn't matter we were told, it was an inert gas... I think welders use the term 'inert gas' for any gas that will not ready with the metal they are welding by whatever technique they are using. But CFCs/Freons never qualified as 'inert' even by that defintion. Oh well, such is the nature of slang. I remember the screens used to support a beaker over a bunsen burner. they had a disc of asbestos in the middle so the flame would not burn through the wire. Bet those were a great source of airborne asbestos fibers. -- FF |
![]() Corky Scott wrote: ... I was just impressed that anyone would inhale the stuff. I'm impressed also, and not favorably. Although CFC refrigerant itself is non-toxic, like air from a shop compressor it usually contains trace contamination by lubricants making it dangerous to inhale. Ditto for helium sold to inflate balloons. Sure, you can make your voice sound funny but you can get chemical pnemonia too. -- FF |
m... Have you ever used a Halon fire extinguisher? Yup. I have fought actual aircraft fires using Halon, Dry Chemical (both "Purple K" and "Super K"), Protein foam, CO2, etc., etc. For a picture, see http://temp.corvetteforum.net/c4/elw...mp/oysters.jpg or http://tinyurl.com/csndg . That's me in the middle next to the pilot's seat. All those little black dots are fresh oysters he was bringing back from Canada. The white stuff is Dry Chemical - 1,500 pounds of it. It wouldn't stop the fire until we covered it with foam. Items like the burning tires would reignite the gasoline behind us after we had moved the hose line past. Had to replace my bunking outfit after that one - too many burn holes to repair it. With a flood system and a relatively closed space it takes a long time for the Halon to disapate. Try lighting a lighter in a space near where halon has been discharged. I spent several years inspecting, discharging and signing off fixed Halon system in computer rooms, satellite communications buildings, and one 180,000 sq. ft. building for Boeing that I can't even talk about. There are no areas on a light aircraft which are sealed tightly enough to establish or maintain a proper concentration of Halon. You can "overkill" a simple pan fire with a portable extinguisher, but that won't work on an engine compartment fire when you're in the cockpit. Halon is a wonderful product, for it's purpose. Of course, much of what you said also applies to CO2. If the CO2 doesn't cool down the metal (which admittedly it has a higher capacity to do than Halon), then you have the same (actually larger) reignition problems. Some other factors must be considered with CO2. Being heavier than air, it tends to settle in a low spot - very important in ship fires. Halon diffuses throughout the space. I'm not sure how the Latent Heat of Vaporization compares between Halon and CO2. In either case the cooling capability is a very minor effect when it comes to extinguishment. If you want cooling, use water. If you want to secure the area and prevent reignition, use foam. In a three-dimensional fire such as an aircraft fire, all bets are off. Even foam may not prevent reignition. Trust me - it is scary to be wading in Jet A trying to plug a leaking tank when the stream coming from the tank keeps igniting. Even in a drill. 8-} Rich S. |
![]() Rich S. wrote: ... Some other factors must be considered with CO2. Being heavier than air, it tends to settle in a low spot - very important in ship fires. Halon diffuses throughout the space. Recalling Avogodro's law, Isn't Halon also heavier than air? In fact, isn't it heavier than CO2? -- FF |
oups.com... Recalling Avogodro's law, Isn't Halon also heavier than air? In fact, isn't it heavier than CO2? Well, I don't remember. I know it's typically discharged from the high point in an enclosed space through specially designed diffuser nozzles, so what you say may be correct. I seem to remember that, like air, it is a homogenous mixture of gasses and tends to diffuse throughout the atmosphere. Maybe that's why some are concerned about the "Ozone hole" and Halon affecting that in the upper atmosphere. It's been a long time since I've studied any basic chemistry and I didn't know that much about it then. If different gaseous elements tended to separate out, wouldn't Nitrogen separate from Oxygen in the atmosphere? But we know it doesn't. I don't know enough to hold up my side of a technical discussion based on Avocados. ![]() different heights inside buildings where we were discharging Halon systems and would measure the concentration at all levels. Rich "Getting old is no job for a sissy!" S. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
