prop seal
Old July 22nd 05, 11:33 PM
On Fri, 22 Jul 2005 04:21:41 GMT, "Jay Honeck"
All these props (first with #5, then with #6) had nasty grease pumped
out of 'em-and fresh grease pumped in every 100 hrs (usually 6-8
weeks). Never had corrosion issues, had very very very very few grease
leaks at the hub.
Hey TC, when should we be overhauling our props?
Mine is getting up there in years/time, but my A&P believes that if it ain't
leaking, and everything is functioning properly, there is no reason to mess
with it.
True?
You need to find a "friendly" prop shop that will split the hub, do a
very general inspection-looking for corrosion or other very bad
things-replace all the seals and put it back together with a re-seal
sign-off. I would recommend every 6-8 years.
The trick is not to let anything expensive get corroded/worn beyond
limits. Prop overhaul is pretty much like engine overhaul when you're
flying Pt 91. You definitely don't need to follow the mfg's TBO, but
you can't ignore it (engine or prop) completely.
TC
Old July 23rd 05, 03:59 AM
Jay Honeck
sign-off.
What, in your recommendation, is a "friendly" prop shop.
Heck, I can't even name a prop shop -- period -- let alone a "friendly" one!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
