Oscar wrote:
Perhaps you should upgrade to version V3.1 and see if the problem is solved. On 2005-07-21 00:21:30 -0700, "P. Corbett" said: Paul For the record, I am using v2.4. Load a flight where the stats are missing. Look in the General Information area at the top of the statistics page. Is the "soaring begin" time the same as the "soaring end" time? Is the duration zero or possibly even negative? This is what I see when my flight stats are missing. Also, for me this problem occurs about every 2nd or 3rd flight... some are okay. Could this be a logger issue? Paul Corbett "Paul M. Cordell" wrote in message ... P. Corbett wrote: Occasionally, a flight viewed with SeeYou will have a normal General Statistics section but will have a a blank Flight Statistics section. These flights were definitely logged because they can be seen in both 2D and 3D. Here is a clue...each time this happens the General Statistic section shows that the times the flight started and ended are the same and the flight duration is therefore zero. I do not know if this is a software bug or an error I am making in setup or use. I would appreciate any advice or thoughts on this problem. Thanks in advance, Paul I am having the same problem. A flight viewed in V3.1 will show no details in the Flight Statistics Phases. The same flight viewed in v 2.4 will show all statistics. I posted this problem on the SEE YOU support forum on 4/8/05 and supplied flight logs. Still no resolution. |
Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 10:38 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
Help with serious Glider Registration Problem | Soaring | 5 | November 12th 03 04:01 PM | |
EGT Problem | Dennis O'Connor | Owning | 4 | August 27th 03 04:25 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
