With the engine at ~2000 rpm, the system voltage should be 13.6 to 14.2
volts, depending upon the state of battery charge... denny |
Denny wrote:
: Also, does your GPS show voltage? The Garmin 295 does, and perhaps : others... : denny Denny, where is this feature? I've had my 295 for 4 years and have never seen this.. I do know the 195 shows voltage, perhaps this is what you mean? -- Aaron C. |
195 not 295... Sorry for the typos..
Any and all thoughts welcomed at this point - this is the worst kind of problem to hunt down. A few months ago the low voltage light started intermittently illuminating on my Bonanza. Since the alternator was newly rebuilt and the battery new, we suspected that the low voltage sensor itself was having a problem. The mechanic found that the wire leading to the low voltage sensor (don't recall which end of the wire, however) was loose. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Thanks! That was one possibilty I had not thought of.
Ian |
I just spent 5 years chasing down a similar intermitant problem in my
Mooney. Turned out to be that the alternator had worn the back bearing out of the alternator's case and was causing movement of the shaft against the back of the case. As it torqued under load it would sometimes lose contact. -Robert |
I have a 1978 M20J Mooney that has been doing exactly that for 15 years.
When I first got the plane it started doing that intermitent flashing. I changed out the voltage regulator twice and the alternator once to no avail. I was then told by someone who should know that it was probably some kind of a phase poblem that was not serious, and that when it happens, just check to be sure the the alternator is charging normally and if it is don't worry about it. He seemed to feel that it would probably go away eventually or get bad enough that it could be tracked down. In fifteen years it has done neither. Sometimes it will go for months without flashing, and then it will sometimes flash for a while on almost every trip. It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. Don I don't know whether this will make you feel better or not. wrote in message oups.com... Can anybody help me diagnose this problem? Just bought my new (to me) 1978 Mooney 201, flew it back from Kansas City to Atlanta, no problem. Flew to Richmond, VA - again no problem. Leaving RIC for Atlanta, the low voltage light started flashing. Didn't want to carry on IFR so stopped into Danville. Left the plane there, and the mechanic removed the altinator and tested it (all ok) and replaced the voltage regulator with a new one. All ok (charging 13.9 volts). Started the plane, the altinator gauge was showing a charge, and took off. About 30 mins into the flight again the low voltage started flashing. By the time I had checked all the CB's it stopped. Then about an hour later it started again. I tried pulling the Alt Field CB and resetting, no joy. It continued to flash untill I was in the pattern at LZU. So, now - what next? Bad Diodes on the Altinator breaking down at altitude?(I was at 8000'), loose altinator belt? (unlikely - it had just been reinstalled). Over voltage on the Altinator causing the Voltage reg to drop off line, and I didn't wait long enough when I reset the Alt-Field circuit breaker? Bad ground straps?? Any and all thoughts welcomed at this point - this is the worst kind of problem to hunt down. Thanks Ian |
![]() Donald Royer wrote: It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. You can never have too many field grounds. I have 3 on my Mooney. They don't cost much and its an easy back up to make. People spend thousands on back up vac systems but sometimes miss the opportunity to spend 5 minutes putting an extra ground wire from the alternator to the frame. -Robert |
Thanks, I think, Don!
I don't like the idea of an intermittant flashing warning light. But for now, I have put an in-line digital volt meter in the cigarette lighter, and will be able to keep an eye on the voltage. I am probably going to replace the battery and alternator, just to be safe, and of course recheck all the grounds, and perhaps try to check the wiring to the warning panel. But if that doesn't stop it, then, I hope I get to the point that it doesn't bother me! Thanks to everyone for the input! Ian "Donald Royer" wrote in message link.net... I have a 1978 M20J Mooney that has been doing exactly that for 15 years. When I first got the plane it started doing that intermitent flashing. I changed out the voltage regulator twice and the alternator once to no avail. I was then told by someone who should know that it was probably some kind of a phase poblem that was not serious, and that when it happens, just check to be sure the the alternator is charging normally and if it is don't worry about it. He seemed to feel that it would probably go away eventually or get bad enough that it could be tracked down. In fifteen years it has done neither. Sometimes it will go for months without flashing, and then it will sometimes flash for a while on almost every trip. It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. Don I don't know whether this will make you feel better or not. wrote in message oups.com... Can anybody help me diagnose this problem? Just bought my new (to me) 1978 Mooney 201, flew it back from Kansas City to Atlanta, no problem. Flew to Richmond, VA - again no problem. Leaving RIC for Atlanta, the low voltage light started flashing. Didn't want to carry on IFR so stopped into Danville. Left the plane there, and the mechanic removed the altinator and tested it (all ok) and replaced the voltage regulator with a new one. All ok (charging 13.9 volts). Started the plane, the altinator gauge was showing a charge, and took off. About 30 mins into the flight again the low voltage started flashing. By the time I had checked all the CB's it stopped. Then about an hour later it started again. I tried pulling the Alt Field CB and resetting, no joy. It continued to flash untill I was in the pattern at LZU. So, now - what next? Bad Diodes on the Altinator breaking down at altitude?(I was at 8000'), loose altinator belt? (unlikely - it had just been reinstalled). Over voltage on the Altinator causing the Voltage reg to drop off line, and I didn't wait long enough when I reset the Alt-Field circuit breaker? Bad ground straps?? Any and all thoughts welcomed at this point - this is the worst kind of problem to hunt down. Thanks Ian |
Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 07:00 PM |
Landing a Mooney | iain_hutchison | Piloting | 0 | November 4th 04 02:38 PM |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Loading luggage in other than Mooney | Robert M. Gary | Piloting | 21 | June 28th 04 06:23 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
