For Sale: Duo Discus Turbo
Old August 3rd 05, 03:05 AM
Bill Daniels
"Mark Lenox" wrote in message
I don't have any experience rigging the duo.
Do you know the weight of the individual panels?
Are the inner panels as heavy as, say, a typical 15M complete wing?
If two people can handle the individual panels reasonably easily, then
that
would be quite nice. My only experience rigging and de-rigging large
2-seat ships has been with ASK-21s and Blaniks, and they are both quite a
challenge to rig due to the heavy wings.
I am also assuming that all connections are automatic?
Mark
It's heavier than any 15M I have assembled. I'd say it's similar to most
2-seaters - not easy but two people can do it with assembly aids. The
controls are automatic.
Bill D
Old August 3rd 05, 03:18 AM
Bob Korves
that would be quite nice. My only experience rigging and de-rigging
large 2-seat ships has been with ASK-21s and Blaniks, and they are
both quite a challenge to rig due to the heavy wings.
The Duo Discus inner wing panels weigh 215 lbs. / 98kg each. The glider
goes together just like a Discus, only bigger and heavier. We have
assembled ours with 2 people and without rigging aids (other than wing
stands) numerous times. 3 people make it easier. 4 mostly get in the
way...
-Bob Korves
5H Duo Discus
5K LAK-17a
Old August 3rd 05, 01:51 PM
Ruud
On 2 Aug 2005 21:18:04 -0500, Bob Korves bkorves@winfirstDECIMALcom
We have
In the long run that will ruin your back!
way...
I can rig my duo all by myself without any help and without any heavy
lifting in light wind conditions.
At stronger wind conditions I need someone to stabilize the wing
dolly.
The only lifting I need to do is rolling the wing panels out of the
trailer into the wingdolly, but I'm working on a solution for that.
See the video on the web site.
Old August 3rd 05, 03:45 PM
John Galloway
I too have rigged a Duo T solo from a Cobra trailer
with a Cobra rigging aid. It can be done. The wing
is very heavy but that isn't the main problem I found.
If the rigging ground is rough and grass then the rigging
aid does not roll well at the point that you are trying
to pull the flat wing into the fuselage. It tends
to tilt and dig into the wing surfaces. The little
stabilizer wheel do not help and actually tend to get
caught in the grass or ground undulations. A rope
to pull on the rigging aid axle helps. On firm smooth
ground it would be very much easier.
Also everything in a two seater is just plain bigger
and things that are easy in little gliders are much
more awkward - such as that I could not reach over
the wing sufficiently to lift it and simultaneously
pull it inwards as the drag pins are inserted - like
I can easily do in a little glider.
Having said that - buy a Duo - get some help to rig
it - and appreciate what a lovely glider it is.
John Galloway
We have
(other than wing
way...
without any heavy
the wing
dolly.
out of the
for that.
Old August 3rd 05, 07:20 PM
Ruud
On Wed, 03 Aug 2005 16:42:17 +0200, Asbjorn Hojmark
If you like a real race horse for long X-country flights, you better
buy a Duo.
Well, except of cause if DG is right, and the DG1000 actually performs
better: http://www.dg-flugzeugbau.de/vergleich-duo-e.html
See: http://www.gliderforum.com/thread-vi...did=40&start=1
Old August 3rd 05, 08:16 PM
Stefan
Ruud wrote:
If you want to buy a club work horse, the DG1000 is a good option.
buy a Duo.
Things I hate about the Duo:
The cockpit is a joke. Despite it's roomy as my saloon, there's no way
to carry even a simple water bottle without permanently fearing that it
will slip under the seat and jam some controls. Besides, I hate the
smell of my co-pilot's feet.
The spoilers are a joke for such a heavy glider. I have done outlandings
at fields which I wouldn't want to try in a Duo.
I forces me to abandon a good thermal at cloud base, when the cloud
above indicates that there are still 2000 metres of good climb, which
would allow me to cross that blue hole in front of me.
And, probably the most annoying thing: I'm not allowed to do that
occasional loop, just for fun, during a cross country flight.
The DG 1000 my club has ordered will be delivered only next spring, so I
don't know yet what I'll hate about that one. :-)
Stefan
Old August 3rd 05, 09:29 PM
John Galloway
there's no way
fearing that it
I hate the
when the cloud
good climb, which
me.
to do that
flight.
next spring, so I
Stefan
Why carry water in inconvenient bottles in any glider?
For the Duo 2-3 litres of water in a Camelbak fit
fine for me tied horizontally behind the top of the
front seat back. Alternatively for tall front pilots
their water bag can go in the little rucksack in front
of the rear cockpit with a tube to the front. The
rear cockpit pilot can carry his water bag secured
elsewhere such as behind the rear head rest.
Front seat pilot's food and oddments sit nicely in
the deep well under the right thigh that is meant to
hold lead ballast but rarely does so. With that space
there is actually as much oddments room in the front
of a Duo as a solo SH glider. The side pocket is tiny
but you can tuck a surprising amount of stuff into
it.
Also the rear pilot acts as butler when required -
part of the fun of XC in a two seater
The weakness Duo airbrakes is greatly overplayed.
The forces required for full airbrake are excessive
IMHO until you adjust the hydraulic wheelbrake a little
and also make sure the glider has the modified airbrake
lever (in the mid fuselage) to reduce the forces.
Without those changes I was not able to fully open
the brakes without real effort. Then when you can
easily pull full brake you find that you have a glide
angle of 6.7:1. The Discus 2C, which is judged by
reviewers to have powerful airbrakes, gets 6.6:1.
If you can't manage with 6.7:1 to get into a field
then you ought not to be flying XC. The difference
between landing single and two seaters in fields is
the relative lengths of the float and ground run which
is directly proportional to the weights (for the same
approach speed) - except that the Duo has an extremely
powerful wheel brake and it is very difficult to get
a Turbo Duo to go onto its nose so full wheel braking
is available when needed.
If you want to critcise the Duo the one unquestionably
poor feature is the unsprung undercarriage which can
make landings on rough hard ground uncomfortable.
That (and all the other usual Duo moans) is done away
with in the Duo X. BTW when I was at the factory a
few weeks ago I was told that that there were further
developments of the Duo X in the pipeline - specifically,
on the front cockpit to improve storage and also separation
between that and the rear cockpit.
John Galloway
Old August 6th 05, 02:55 AM
Gerhard Wesp
Bruce wrote:
The DG1000 also comes with a choice of 18 and 20m wingspan, the former endowing
it with Aerobatic rating...
It's aerobatic rated in *both* configurations. Difference is, with 18m,
it's full aerobatic, with 20m it's "limited" aerobatic, i.e. loop, turn
and the likes. And these are very easy and straightforward to fly with
20m. I really like this ship.
Cheers
-Gerhard
o o
Gerhard Wesp | http://www.cosy.sbg.ac.at/~gwesp/
\_/ See homepage for email address!
FS: Duo Discus Turbo - Houston, TX - price reduced Mark Zivley Soaring 0 July 21st 05 01:16 AM
FS: Duo Discus Turbo - Houston, TX - price reduced Mark Zivley Soaring 0 June 23rd 05 03:32 AM
FS: 2002 Duo Discus Turbo - Texas Mark Zivley Soaring 0 May 8th 05 07:44 PM
FS: Duo Discus Turbo - Texas, USA Mark Zivley Soaring 2 May 4th 05 11:34 PM
All Czech built Discus grounded Paul Soaring 0 September 14th 03 02:22 AM
