Our club just received our newest 172.  The previous owner put a decal
	on the door advertising his company and we would like to remove it without harming the paint. Any suggestions?  |
			 wrote in message oups.com... Our club just received our newest 172. The previous owner put a decal on the door advertising his company and we would like to remove it without harming the paint. Any suggestions? A heat gun maybe? I used one to get inch-wide tape stripes from an aircraft. Slow but sure and with care no damage to the paint.  |
	oups.com... Our club just received our newest 172. The previous owner put a decal on the door advertising his company and we would like to remove it without harming the paint. Any suggestions? Goo Gone® - Sticker Lifter http://www.organize-everything.com/stickerlifter.html Rich S.  |
			 wrote in message oups.com... Our club just received our newest 172. The previous owner put a decal on the door advertising his company and we would like to remove it without harming the paint. Any suggestions? Mineral spirits works well, and won't hurt the paint. It is the primary ingredient in most of the "tar removal" products sold for cleaning automobiles. Someone suggested a heat gun, but those things are very sensitive to proper use. Hold 'em a little too close or on one spot for a couple seconds too long and you'll not only bubble the paint, you might even set it on fire... Try a blow dryer instead. KB  |
			 "Kyle Boatright" wrote Mineral spirits works well, and won't hurt the paint. It is the primary ingredient in most of the "tar removal" products sold for cleaning automobiles. Some stick-on removers contain mostly naphtha. (commonly know as cigarette lighter fluid) Try that. If the sticker has a face that will not peel off, then the solvent can't get to the glue. Try taping a solvent soaked paper towel over the sticker, and a piece of plastic on top of that, and let it stew over night. If you can prick the decal with something like an exact knife, that will also help the solvent get down to the glue. -- Jim in NC  |
On Mon, 8 Aug 2005 19:56:58 -0400, "Kyle Boatright"
	wrote: wrote in message roups.com... Our club just received our newest 172. The previous owner put a decal on the door advertising his company and we would like to remove it without harming the paint. Any suggestions? What you refer to as a decal is probably a vinyl graphic. A true decal is made up of multple layers of silk screened ink with a clear layer on each side which is printed on a paper that has a water soluble coating on it. They are soaked in water then slid of the paper onto the surface to be adorned. The water is squeegeed out from under them and they adhere thru surface tension. The advise you have received so far are probably pretty good for removing a vinyl graphic. Sign companies make solvents to remove the remaining adhesive after they are peeled of with heat, but mineral spirits might just do the job. A true decal is a real bitch to get off.  |
			 I just noticed that jauns name has been removed from ANN's web site.Is he no longer writing for zoom? Did he quit? Was he fired? Will he join the ranks of the zoomed ex employee? We await the answers to this GREAT mystery...well actually I'm just courious....ahhh frankly I don't give a hoot just wondering ....ehh so what who cares? :-) Chuck S  |
"karel"  wrote in message
	... "ChuckSlusarczyk" wrote in message ... I just noticed that jauns name has been removed from ANN's web site And WHAT is the relation with removing decals? Karel......... I don't know what newsreader you are using, but it may not display the fact that Chuck clearly wrote the subject line to read jaun missing JJJJJJJJ. I'm not sure why or how it was grouped under the Removing decals thread. Rich S.  |
On Tue, 09 Aug 2005 06:56:03 GMT, Ed Sullivan
	wrote: On Mon, 8 Aug 2005 19:56:58 -0400, "Kyle Boatright" wrote: wrote in message groups.com... Our club just received our newest 172. The previous owner put a decal on the door advertising his company and we would like to remove it without harming the paint. Any suggestions? What you refer to as a decal is probably a vinyl graphic. A true decal is made up of multple layers of silk screened ink with a clear layer on each side which is printed on a paper that has a water soluble coating on it. They are soaked in water then slid of the paper onto the surface to be adorned. The water is squeegeed out from under them and they adhere thru surface tension. The advise you have received so far are probably pretty good for removing a vinyl graphic. Sign companies make solvents to remove the remaining adhesive after they are peeled of with heat, but mineral spirits might just do the job. A true decal is a real bitch to get off. *Sometimes* and I emphasize the sometimes, the reverse of the application will work. A towel soaked in hot water and held firmly in place over the decal (if it is a true decal) can soften them and they almost slide off. This usually takes a good half hour to hour of soaking while keeping the water at least warm. It's an interesting exercise on vertical surfaces and an exercise in frustration on overhead surfaces. I have removed good sized decals this way and I've run into some where the water soaking didn't do a thing. Those with adhesive on the backs have been pretty well covered in other posts. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com  |
Rich S. wrote:
	"karel" wrote... And WHAT is the relation with removing decals? I don't know what newsreader you are using, but it may not display the fact that Chuck clearly wrote the subject line to read jaun missing JJJJJJJJ. I'm not sure why or how it was grouped under the Removing decals thread. This is why: References: .com From Chucks post... He changed the subject, but his message was a reply to Ed Sullivan's post: From: Ed Sullivan Message-ID: NNTP-Posting-Date: Tue, 09 Aug 2005 02:56:03 EDT  |
| Thread Tools | |
| Display Modes | |
| Removing water repelent from fiberglass lay-up? | Roger | Home Built | 2 | December 3rd 04 12:15 AM |
| You can now by water-slip inkjet decals by the sheet | Charlotte Gaisford | Restoration | 0 | November 8th 04 03:00 PM |
| You can now by water-slip inkjet decals by the sheet | Charlotte Gaisford | Aviation Marketplace | 0 | November 8th 04 02:59 PM |
| Removing old antennas | Jay Honeck | Owning | 30 | March 21st 04 05:34 PM |
| Info needed to make decals for missiles | TJ | Simulators | 1 | January 16th 04 03:29 PM |
