Please understand that this is not an IT discussion forum. Many people here
would not know what to do with a .zip file, much less understand what C++, SDK or even .exe mean. I suggest you post your request for help in a physics or programming forum, or post in a completely non I.T. technical way - for example: In a single engine Cessna is it normal to stall at 60 knots with 10 degrees of flaps? It may help you to find a forum in your first language. Regards, Tim "Grandss" grandss@nospam wrote in message ... Hi All, I need a pilot help here is a little simultor in c++ and directx with an .exe http://examples.oreilly.com/physicsgame/flightsim.zip it is a "real" simulation i don't arrive to pitch down when I flying (because plane stalling) if someone can do it, please inform me thanks |
Tim Epstein a écrit :
Please understand that this is not an IT discussion forum. Many people here would not know what to do with a .zip file, much less understand what C++, SDK or even .exe mean. I suggest you post your request for help in a physics or programming forum, or post in a completely non I.T. technical way - for example: In a single engine Cessna is it normal to stall at 60 knots with 10 degrees of flaps? It may help you to find a forum in your first language. Regards, Tim "Grandss" grandss@nospam wrote in message ... Hi All, I need a pilot help here is a little simultor in c++ and directx with an .exe http://examples.oreilly.com/physicsgame/flightsim.zip it is a "real" simulation i don't arrive to pitch down when I flying (because plane stalling) if someone can do it, please inform me thanks OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme |
OK,
I downloaded the program and tried running it. It did, in fact, indicate a stall as soon as I pitched down. There appears to be a problem with the program. My plane does not react this way. I was unable to get it indicate a stall while pitching up, however it does actually stall, as is clearly demonstrated when the nose pitches down, even though I was still pitching up. I guess I'll have something for my son to play with this week. I suppose I'll have to go get him the 'Physics for game developers' book too. "Grandss" grandss@nospam wrote in message ... Tim Epstein a écrit : Please understand that this is not an IT discussion forum. Many people here would not know what to do with a .zip file, much less understand what C++, SDK or even .exe mean. I suggest you post your request for help in a physics or programming forum, or post in a completely non I.T. technical way - for example: In a single engine Cessna is it normal to stall at 60 knots with 10 degrees of flaps? It may help you to find a forum in your first language. Regards, Tim "Grandss" grandss@nospam wrote in message ... Hi All, I need a pilot help here is a little simultor in c++ and directx with an .exe http://examples.oreilly.com/physicsgame/flightsim.zip it is a "real" simulation i don't arrive to pitch down when I flying (because plane stalling) if someone can do it, please inform me thanks OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme |
Grandss grandss@nospam wrote in :
Snipola OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme Let me get this straight... You know nothing about aviation, yet you are trying to program a flight simulator? Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Blog: http://www.skywise711.com/Blog Sed quis custodiet ipsos Custodes? |
Skywise a écrit :
Grandss grandss@nospam wrote in : Snipola OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme Let me get this straight... You know nothing about aviation, yet you are trying to program a flight simulator? Brian ABSOLUTELY but I know something about forces, moments, angular velocity ...... It's for a student project in IT. Normally, i received flight equations, but I think my teacher have not all datas, and he don't answer me bout my question. So i found this little simultor with a book about physics in game and I try to learn a little bit. As simulator is "real", I think there is something I do wrong with this plane, and i ask help with expert ![]() Perhaps it's normal to have that when you you pitch down (but i don't believe it). And I can say that I learn lot of thing about aviation (in english and in french) here and somewhere else. |
Skywise a écrit : Grandss grandss@nospam wrote in : Snipola OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme Let me get this straight... You know nothing about aviation, yet you are trying to program a flight simulator? Brian ABSOLUTELY but I know something about forces, moments, angular velocity ..... And I can say that I learn lot of thing about aviation (in english and in french) here and somewhere else. A simulator project sounds like an excellent way to learn about aerodynamics! One source that you might find helpful, given your technical background, is http://www.av8n.com/how/ (written by a pilot who is also a physicist). I apologize for the embarrassing conduct of some people here who are being hostile or disparaging for no discernable reason. Please don't let them discourage you. --Gary |
Vous avez besoin du livre "Aerodynamique du vol de l'avion," par A. Boison.
Ou, allez ici: http://www.chez.com/aerodynamique/ -- introduction court avec des avions modeles. Seth "Grandss" grandss@nospam wrote in message ... Skywise a écrit : Grandss grandss@nospam wrote in : Snipola OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme Let me get this straight... You know nothing about aviation, yet you are trying to program a flight simulator? Brian ABSOLUTELY but I know something about forces, moments, angular velocity ..... It's for a student project in IT. Normally, i received flight equations, but I think my teacher have not all datas, and he don't answer me bout my question. So i found this little simultor with a book about physics in game and I try to learn a little bit. As simulator is "real", I think there is something I do wrong with this plane, and i ask help with expert ![]() Perhaps it's normal to have that when you you pitch down (but i don't believe it). And I can say that I learn lot of thing about aviation (in english and in french) here and somewhere else. |
Aussi: http://pierre.rondel.free.fr/portance.htm
Grandss a écrit :
Skywise a écrit : Grandss grandss@nospam wrote in : Snipola OK I try to do it. But I just think it's more explicit with this small simulator. My english is not very good and i know nothing about aviation. Only that I learn with my project. merci quand meme Let me get this straight... You know nothing about aviation, yet you are trying to program a flight simulator? Brian ABSOLUTELY but I know something about forces, moments, angular velocity ..... It's for a student project in IT. Normally, i received flight equations, but I think my teacher have not all datas, and he don't answer me bout my question. So i found this little simultor with a book about physics in game and I try to learn a little bit. As simulator is "real", I think there is something I do wrong with this plane, and i ask help with expert ![]() Perhaps it's normal to have that when you you pitch down (but i don't believe it). And I can say that I learn lot of thing about aviation (in english and in french) here and somewhere else. THANKS for links. Very very interresting. |
