O2 Mask On Pilot?
Old August 15th 05, 10:59 PM
Bob Gardner
Bob Gardner
"fred" wrote in message
At some point in time I remember hearing that above a certain altitude the
pilot or co-pilot must be wearing an O2 mask on commercial flights. Am I
right? Details?
Old August 15th 05, 11:05 PM
fred
"Bob Gardner" wrote in message
91.211
So what the devil is "91.211"?
Bob Gardner
the pilot or co-pilot must be wearing an O2 mask on commercial flights.
Am I right? Details?
Old August 15th 05, 11:14 PM
Steven P. McNicoll
FAR 91.211, applicable to the US.
§ 91.211 Supplemental oxygen.
(a) General. No person may operate a civil aircraft of U.S. registry-
(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including
14,000 feet (MSL) unless the required minimum flight crew is provided with
and uses supplemental oxygen for that part of the flight at those altitudes
that is of more than 30 minutes duration;
(2) At cabin pressure altitudes above 14,000 feet (MSL) unless the required
minimum flight crew is provided with and uses supplemental oxygen during the
entire flight time at those altitudes; and
(3) At cabin pressure altitudes above 15,000 feet (MSL) unless each occupant
of the aircraft is provided with supplemental oxygen.
(b) Pressurized cabin aircraft. (1) No person may operate a civil aircraft
of U.S. registry with a pressurized cabin-
(i) At flight altitudes above flight level 250 unless at least a 10-minute
supply of supplemental oxygen, in addition to any oxygen required to satisfy
paragraph (a) of this section, is available for each occupant of the
aircraft for use in the event that a descent is necessitated by loss of
cabin pressurization; and
(ii) At flight altitudes above flight level 350 unless one pilot at the
controls of the airplane is wearing and using an oxygen mask that is secured
and sealed and that either supplies oxygen at all times or automatically
supplies oxygen whenever the cabin pressure altitude of the airplane exceeds
14,000 feet (MSL), except that the one pilot need not wear and use an oxygen
mask while at or below flight level 410 if there are two pilots at the
controls and each pilot has a quick-donning type of oxygen mask that can be
placed on the face with one hand from the ready position within 5 seconds,
supplying oxygen and properly secured and sealed.
(2) Notwithstanding paragraph (b)(1)(ii) of this section, if for any reason
at any time it is necessary for one pilot to leave the controls of the
aircraft when operating at flight altitudes above flight level 350, the
remaining pilot at the controls shall put on and use an oxygen mask until
the other pilot has returned to that crewmember's station.
Old August 15th 05, 11:59 PM
Dave S
I flew on an air ambulance Lear 25 for a while.. and I can say I NEVER
saw the cockpit crew remove the masks from the hangars and place them in
"the ready position" even though we routinely went to FL 450-490. I am
wondering how many operators follow this rule.
Dave
Old August 16th 05, 02:28 PM
Edwin Johnson
On our 25D the position of the hangers for the masks were considered in the
'ready' position, so you just made sure they were there. Believe it was a
5-sec operation (required time) to get them on your head, for the
quick-doning masks.
The old joke, before the quick-doning type masks, was that the Learjet
pilots always squeezed their noses before de-boarding to make it look like
they had been wearing their masks.
....Edwin
__________________________________________________ _____
"Once you have flown, you will walk the earth with your
eyes turned skyward, for there you have been, there you
long to return."-- da Vinci ... www.shreve.net/~elj
Old August 16th 05, 12:09 AM
Bob Moore
the controls of the airplane is wearing and using an oxygen mask that
is secured and sealed and that either supplies oxygen at all times or
automatically supplies oxygen whenever the cabin pressure altitude of
the airplane exceeds 14,000 feet (MSL), except that the one pilot need
not wear and use an oxygen mask while at or below flight level 410 if
there are two pilots at the controls and each pilot has a
quick-donning type of oxygen mask that can be placed on the face with
one hand from the ready position within 5 seconds, supplying oxygen
The Part 121 requirement for Certificated Aircarriers is more restrictive
than for Part 91 Operators. The FL350 is replaced with FL 250.
Bob Moore
Old August 16th 05, 12:37 AM
Steven P. McNicoll
"Bob Moore" wrote in message
21...
But still not applicable to the Greek 737 that went down yesterday, although
a similar requirement may have existed for them.
Old August 16th 05, 04:13 AM
GeorgeB
On Mon, 15 Aug 2005 23:37:07 GMT, "Steven P. McNicoll"
. 121...
What would have been the effect if the O2 bottle for the cockpit had
been inadvertently filled with breathing air rather than O2? I seem
to remember that this was discovered to have happened somewhere in the
US in the last few months? I would think that a casual test would
have found it normal, but that the PPO2 would have been substantially
too low even with a pressurized mask?
Old August 16th 05, 08:54 AM
Stefan
They would have tested the system before the flight and found it
working. They would have put on their mask in flight and thought it
worked, slowly fading away without recognizing it. You may or may not
recognize hypoxia when you suspect it and really watch your body, you
definitely don't recognize it when you're unwary.
Stefan
Old August 18th 05, 07:50 PM
Steven P. McNicoll
"GeorgeB" wrote in message
From what would the oxygen system be serviced in your scenario? A
compressor?
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 05:45 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 05:40 PM
