Steep bank=higher wing loading=more drag. More thrust means you overcome
the added drag. Think of it as having the thrust to pull through a tight turn -- especially a climbing turn. "Newps" wrote in message ... George Patterson wrote: Later in the war, the Thunderbolt was re-equipped with a prop which had comparatively wide blades -- the pilots called it a "paddle-blade" prop. Rate-of-climb and maneuverability immediately improved to the point that a good Jug pilot could out-maneuver a Spitfire. How does a prop change make the plane more manuverable? |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
New Prop on my Mooney Ovation | Charles Talleyrand | Owning | 1 | July 7th 03 10:30 PM |
