Completing the Non-precision approach as a Visual Approach
Old November 18th 03, 09:15 PM
Matthew Waugh
"Marco Leon" mleon(at)optonline.net wrote in message
I thought the whole reason for a steep-as-reasonable descent profile
during
a non-precision approach was so that if the airport/runway environment is
in
sight before the MAP, you can take advantage of it and land. If you are
forced to fly not a foot lower to the missed, then therefore you can not
take advantage of the early sighting of the airport. In other words, after
arriving at the MDA and you have the runway environment in sight AND you
see
you're about to enter the cloud bases again, then you therefore "must"
enter
the cloud bases because you're not at the MAP yet? Then the only way to
descend is to request and get cleared for a Contact Approach?
Check out 91.175(b)(1). It all depends on your interpretation of "normal
rate of descent" and "normal maneuvers." Only you know if you're making
normal flight maneuvers or "ducking under" and the only way we'll know if
you were ducking under is if somebody peels you off the side of a hill.
Mat
Matthew Waugh
Comm. SEL MEL, CFI-AI
http://home.nc.rr.com/mwaugh/learn2fly/index.htm
Old November 18th 03, 06:26 PM
Steven P. McNicoll
"Bob Gardner" wrote in message
news:bphub.176041$9E1.917544@attbi_s52...
When you are cleared for the VOR-A you are expected to fly the
profile....fly at the MDA and not a foot lower to the missed approach
point
or until you see the runway environment as defined in 91.175. When you see
the airport, you should real quick ask for a contact approach...then you
can
follow ground reference and altitude is not a factor.
There isn't much to this airport other than the "runway environment". If
you have the runway environment in sight you can descend below the MDA and
there's no reason to ask for a contact approach.
Old November 18th 03, 07:06 AM
Hilton
John Clonts wrote:
I'm inbound on the final approach segment of the VOR-A approach at T82
(Fredericksburg Texas):
http://www.myairplane.com/databases/.../T82_vd_gA.pdf
At about 3 miles east of the airport I'm at the MDA of 2460 MSL ("766
AGL"),
This was (one of) your (almost) fatal mistake. At 2460' and 3 miles out,
you probably were not at 766 AGL. The 766 you see is NOT AGL as you would
first think. The 766' is the altitude above the airport elevation (for a
circling approach). Note that 1694 + 766 = 2460.
It's probable that a lot of instrument pilots do not know this.
Hilton
Old November 18th 03, 01:13 PM
EDR
In article . net,
AGL"),
Let's pick nits...
Is it
Height Above Aerodrome?
or
Height Above Threshhold?
Old November 18th 03, 02:27 PM
EDR wrote:
In article . net,
AGL"),
Let's pick nits...
Is it
or
In the U.S. it's HAT for straight-in and HAA for circling. Height Above
Touchdown (the touchdown elevation being the highest point on the first 3,000
feet of the runway). Height Above Airport is based on the highest terrain point
on the airport.
Old November 18th 03, 06:55 PM
Steven P. McNicoll
Height Above Airport is based on the highest terrain point on the airport.
Not quite. Height Above Airport is based on the highest point on an
airport's usable runways. There may be higher points on ramps or taxiways.
Old November 18th 03, 05:09 PM
Hilton
AGL"),
out,
would
a
Let's pick nits...
Is it
or
My point wasn't nitpicking. My point was that at 3 miles out there could be
a little hill that reduces the 766 to less. This becomes very significant
when there are hills on the approach and you think you're at 2000' AGL e.g.
4000 (2000) when actual AGL is significantly less. By saying "airport
elevation" I wasn't picking nits, just being correct since it was a circling
approach.
Hilton
Old November 19th 03, 03:13 AM
J Haggerty
On a circling approach, it's always Height Above Airport (HAA)
EDR wrote:
In article . net,
AGL"),
Let's pick nits...
Is it
or
Old November 18th 03, 06:01 PM
John Clonts
"Hilton" wrote in message
ink.net...
AGL"),
I did realize this. In fact that's why I put quotation marks around the
"766 AGL". Maybe I should have written it: 766 "AGL".
Thanks for your reply though.
The gist of my question involves either or both of these aspects:
1) Does "having the runway environment in sight...make a normal landing"
in 91.175 mean its ok to descend below MDA, fly a couple more miles to the
airport and then fly the pattern (circle to land), as long as the runway is
still in sight.
2) Once I get to class G airspace on my approach and am clear of clouds in
1 mi vis, can I then descend below MDA by doing something like declaring
myself visual, contact, or canceled IFR.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old November 18th 03, 07:08 PM
Steven P. McNicoll
"John Clonts" wrote in message
is
still in sight.
Yes.
in
No, you do not get to Class G airspace at any point at or above the MDA.
Question to the IFR Pilots Out There Cecil E. Chapman Instrument Flight Rules 90 November 21st 03 03:47 PM
DME req'd on ILS (not ILS-DME) approach? Don Faulkner Instrument Flight Rules 13 October 7th 03 03:54 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
