Since electronics do not know much about elevation, there are two major
changes - temperature and pressure. The largest change would be a change in temperature. Unless electronics are heated, there could be a major problem for displays. Also, batteries may not work as well. Pressure change should not be much of a problem. When it comes to radiation, the question is how long the electronics are going to be up there? Unless it is a very long time, I doubt the radiation will be a major factor. Colin |
changes - temperature and pressure. The largest change would be a change in temperature. Unless electronics are heated, there could be a major problem for displays. Also, batteries may not work as well. Pressure change should not be much of a problem. When it comes to radiation, the question is how long the electronics are going to be up there? Unless it is a very long time, I doubt the radiation will be a major factor. Actually it might be a factor. NASA research aircraft have had several single event upsets in semiconductor based memories at 40,000 feet on missions lasting even just a few hours. Avionics containing microprocessors and memory were not affected but the desktop grade PCs strapped in equipment racks would crap out with a memory parity error or something once every few days. They believed it was radiation induced. The same computers worked fine on the ground. The Kuiper Airborne Observatory (a C-141 A model) is one example where this happened. |
Aircraft Design 1942 flying boats etc FA | Sally | Aviation Marketplace | 0 | August 17th 04 12:40 AM |
amateur design consultant? | Shin Gou | Home Built | 14 | June 30th 04 01:34 AM |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Naval Aviation | 0 | April 30th 04 09:45 PM |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Military Aviation | 0 | April 30th 04 09:45 PM |
How 'bout a thread on the F-22 with no mud slinging, no axe grinding, no emotional diatribes, and just some clear, objective discussion? | Scott Ferrin | Military Aviation | 23 | January 8th 04 12:39 AM |
