It's all so nebulous. There's one section on transponders and
altitude reporting equipment requirements that says it applies to "airplanes and helicopters." An "experimental" is neither, it's an "experimental" aircraft period. A gyroplane is not an airplane or a helicopter. The FARS are such a general can of worms, if you ask 5 FAA employees for an interpretation, you'll usually get at least 3 differing answers. I'se keeps me mouf' shut, don't axe questions an' goes about me bidniss. KJSDCAUSA "Gerry Caron" wrote in message . com... "Russell Duffy" wrote in message news ![]() Greetings, I'm expecting to make the first flight of an RV-3 later this month, and am trying to figure out exactly what needs to be done about the transponder. Does anyone know for sure? Since the plane is day VFR only, I'm pretty sure I don't need to have the pitot static system tested. Lots of people don't have any sort of certification done on experimentals, but I think something is probably required. It seems like I've seen a statement that says the manufacturer of the aircraft (that's me) is responsible for verifying the operation of the transponder. If I call up ATC from outside their airspace, and ask for a readout, isn't that verifying the operation. The following are from Part 91 which covers all operations not under Parts 121 or 135. It doesn't matter whether you are flying an experimental, a C172, or a Citation. Part 91.413 for transponder checks applies regardless. You're correct in that 91.411 for altimeter systems (incl: static system) only applies if you want to fly IFR. But even VFR you may want ATC services and if your altitude reporting is off, you may get a request to stop altitude squawk. Don't know what the reaction might be if you're in a Mode C required area with a continually bad Mode C. But from a practical point of view; if you've got Mode C, make sure it's working right. If it isn't working, it certainly doesn't contribute much to safety and at worse could be a hazard (If somebody else thinks you're at a given altitude when you're really at a different altitude--think TCAS.) The rules spell out the verification and who may do them. The tests are in Appendix E and F of Part 43. |
It's the 91.411 and 91.413 deal. Legally only the transponder check
(91.413) is required for VFR every 24 months. But to use your encoder you also have to comply with part 43 appendix e paragraph C, or anytime work has been done that could effect the mode c output. If your looking for someone to do this work in the DFW area I'll be available in the next couple of weeks. I'm just getting my repair station up and going for doing the VFR and IFR system inspections. Dave Dallas tx Ken Sandyeggo wrote: It's all so nebulous. There's one section on transponders and altitude reporting equipment requirements that says it applies to "airplanes and helicopters." An "experimental" is neither, it's an "experimental" aircraft period. A gyroplane is not an airplane or a helicopter. The FARS are such a general can of worms, if you ask 5 FAA employees for an interpretation, you'll usually get at least 3 differing answers. I'se keeps me mouf' shut, don't axe questions an' goes about me bidniss. KJSDCAUSA "Gerry Caron" wrote in message . com... "Russell Duffy" wrote in message news ![]() Greetings, I'm expecting to make the first flight of an RV-3 later this month, and am trying to figure out exactly what needs to be done about the transponder. Does anyone know for sure? Since the plane is day VFR only, I'm pretty sure I don't need to have the pitot static system tested. Lots of people don't have any sort of certification done on experimentals, but I think something is probably required. It seems like I've seen a statement that says the manufacturer of the aircraft (that's me) is responsible for verifying the operation of the transponder. If I call up ATC from outside their airspace, and ask for a readout, isn't that verifying the operation. The following are from Part 91 which covers all operations not under Parts 121 or 135. It doesn't matter whether you are flying an experimental, a C172, or a Citation. Part 91.413 for transponder checks applies regardless. You're correct in that 91.411 for altimeter systems (incl: static system) only applies if you want to fly IFR. But even VFR you may want ATC services and if your altitude reporting is off, you may get a request to stop altitude squawk. Don't know what the reaction might be if you're in a Mode C required area with a continually bad Mode C. But from a practical point of view; if you've got Mode C, make sure it's working right. If it isn't working, it certainly doesn't contribute much to safety and at worse could be a hazard (If somebody else thinks you're at a given altitude when you're really at a different altitude--think TCAS.) The rules spell out the verification and who may do them. The tests are in Appendix E and F of Part 43. |
"Dave" wrote in message
et... It's the 91.411 and 91.413 deal. Legally only the transponder check (91.413) is required for VFR every 24 months. But to use your encoder you also have to comply with part 43 appendix e paragraph C, or anytime work has been done that could effect the mode c output. Thanks. I've talked to another shop, and have been told that they can come to the airport for at least part of the check. They want to check the transponder on the bench, then put it in the plane to check the system. I'm trying to talk them into skipping the bench check, since it's a brand new Garmin transponder. Unfortunately, the owner of the shop is the one I need to talk to, and he's failed to return my call twice now. How hard is it to get started as a repair station :-) (only half kidding) Thanks, Rusty |
![]() Russell Duffy wrote: "Dave" wrote in message et... It's the 91.411 and 91.413 deal. Legally only the transponder check (91.413) is required for VFR every 24 months. But to use your encoder you also have to comply with part 43 appendix e paragraph C, or anytime work has been done that could effect the mode c output. Thanks. I've talked to another shop, and have been told that they can come to the airport for at least part of the check. They want to check the transponder on the bench, then put it in the plane to check the system. I'm trying to talk them into skipping the bench check, since it's a brand new Garmin transponder. Unfortunately, the owner of the shop is the one I need to talk to, and he's failed to return my call twice now. How hard is it to get started as a repair station :-) (only half kidding) Thanks, Rusty There is no real reason to bench check then check it in the airplane except to verify the transponder works prior to a new installation or if it is a mode "s" transponder, he may only have bench equipment to test it. A bad antenna or antenna connection can swing a transponders frequency out of range to pass the test. He may be trying to get a baseline to validate the installation. If he isn't charging more for the bench check and it's not a mode "s" go for it. If he is charging lots more and your confident that the installation is sound, make a few more calls. Since your static system is new, it should be checked for leaks. That can be done by an A&P, manufacturer or the guy who does your transponder check. You as the manufacutrer of the aircraft who installed the transponder can also test and inspect the transponder installation, but it still needs to comply with appendix f. dave |
except to verify the transponder works prior to a new installation or if it is a mode "s" transponder, he may only have bench equipment to test it. A bad antenna or antenna connection can swing a transponders frequency out of range to pass the test. He may be trying to get a baseline to validate the installation. If he isn't charging more for the bench check and it's not a mode "s" go for it. If he is charging lots more and your confident that the installation is sound, make a few more calls. Since your static system is new, it should be checked for leaks. That can be done by an A&P, manufacturer or the guy who does your transponder check. You as the manufacutrer of the aircraft who installed the transponder can also test and inspect the transponder installation, but it still needs to comply with appendix f. dave Thanks for all the extra info Dave. I talked to my preferred avionics shop today, the one who said they wouldn't come to my airport. When he really understook that I couldn't bring the plane to him, he agreed to come over next week to do a "functional test". He's the one that tested my RV-8 a year or so ago, so I'm pretty happy that he's agreed to do this. I think I'm all set now. Thanks again, Rusty |
Check this out! | [email protected] | Aerobatics | 0 | November 30th 04 12:58 AM |
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt | Juan E Jimenez | Home Built | 0 | August 6th 03 04:21 AM |
check your tachometer | Robert Scott | Home Built | 0 | August 4th 03 05:05 PM |
Recommendation for Radio, transponder and Altimeter | Ron Natalie | Home Built | 0 | July 8th 03 03:40 PM |
