Ford V-6 engine work
Old August 12th 03, 09:05 PM
Corky Scott
On Tue, 12 Aug 2003 14:22:27 -0500, Barnyard BOb --
On Tue, 12 Aug 2003 16:14:27 GMT,
(Corky Scott) wrote:
The block was baked, then shot peened and then blasted clean. That
entire process takes about half an hour. Next, the block was rough
bored to .0028 over so we could see if that would take care of any
cylinder irregularities. It was obvious that the rough bore had
cleaned up the cylinders so we settled on pistons that were a standard
.0030 over. I got those from Wiseco, the company that makes pistons
for a huge number of vendors including many Detroit automakers.
Corky Scott
Could you possibly mean...
.028
.030
28 thousandths
30 thousandths
Barnyard BOb --
My apologies. I don't use a micrometer much and every time I do I
have to study and learn it over and over again.
I meant to say that the cylinders were rough bored to twenty eight
thousandths over, then honed to the final size which incorporated the
sixty thousandths piston clearance.
If that's .060" clearance, then that's what I meant to say.
I always read those numbers as first place to the right of the decimal
as tenths, second hundredths and third place thousandths.
So is .060" reading 6 hundredths, or 60 thousandths. Or are they the
same? It's always been a mystery to me.
Corky Scott
Old August 13th 03, 11:33 AM
Barnyard BOb --
.028
.030
28 thousandths
30 thousandths
Barnyard BOb --
I sympathize, since I did use a micrometer for many years. g
[Got that... big mouth Latchless Larry?]
To throw you another curve....
I'm thinking your piston clearance is really .006 or 6 thousandths.
Clare or Bruce may be chiming in on this one. g
Corky Scott
600 ten thousandths
60 thousandths
6 hundredths
..6 tenths....
All the same thing.
Barnyard Bob -
Old August 21st 03, 02:29 AM
clare @ snyder.on .ca
On Wed, 13 Aug 2003 05:33:03 -0500, Barnyard BOb --
.028
.030
28 thousandths
30 thousandths
Barnyard BOb --
Standard "rule of thumb" for engines you had no specs for was 2 thou
plus 2 thou per inch diameter. Which would be roughly 8 thou.
Camground pistons were usually fitted a bit tighter. Like about half
or less.
Factory spec for a 3.8 is 0.0014 to 0.0028
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
Painting is still tough work Orval Fairbairn Home Built 8 July 23rd 03 04:02 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
