What indicated airspeed do you normally rotate at? (no real answer, just
curious) Take off with the twin requires us to hold it onto the runway until 80mph, we definately do not want to rotate prematurely in case of an engine failure. We usually start to rotate (and that's not really what we're doing -- more like applying mild back pressure) around 70 mph -- but that's not a hard and fast figure. It all depends on "feel", in my experience -- which, in turn, is based on weight, wind, temperature, etc. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote We usually start to rotate (and that's not really what we're doing -- more like applying mild back pressure) around 70 mph -- but that's not a hard and fast figure. It all depends on "feel", in my experience -- which, in turn, is based on weight, wind, temperature, etc. Ground fog forms because the ground is cooling the air near it (due to radiational cooling) faster than the air further from it. You already knew that, though. MY guess what happen, is that after you started to rotate, the warmer air above started getting pushed down into the cooler air, warmed it up, (or you got into the warmer air) gave you less lift than the cool ground air, then you started not lifting so good. Just a guess, though. -- Jim in NC |
above started getting pushed down into the cooler air, warmed it up, (or you got into the warmer air) gave you less lift than the cool ground air, then you started not lifting so good. Just a guess, though. Man, that would require a layer just a few feet thick -- is that possible? Actually, I know it is, as I've seen it at altitude. I suppose it can form close to the ground, too, in a calm wind. Strange how I can study weather in college, I can observe it carefully for years, and I can spend so much time in the air -- and yet not understand it very well at all. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Yep, we get it here often. You can stand in it and your head will stick above it and your feet will be below it. Pretty freaky. Jim |
Laser danger | [email protected] | Home Built | 0 | January 9th 05 06:54 AM |
IO 360 Power down (danger, long, rambling post!) | Jim Harper | Home Built | 24 | July 11th 04 12:04 AM |
Winching-Cable danger | Andy Davey | Soaring | 0 | March 23rd 04 03:32 PM |
Low-Tech Grenades A Danger to Helicopters | Otis Willie | Military Aviation | 9 | November 22nd 03 06:13 AM |
World War II airmen remember danger | Otis Willie | Military Aviation | 0 | September 29th 03 09:32 PM |
