Give that man a free $100 tow.
With Humphrey Bogart. Great dark movie about human greed. - John |
ContestID67 wrote:
Quick - where did the line "Badges? We don't need no stinkin' badges!" come from? Mel Brooks "Blazing Saddles" Tony V. |
First known usage:
Treasure of the Sierra Madre (1948) Gold Hat (Mexican): "Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges." Mike Tony Verhulst wrote: ContestID67 wrote: Quick - where did the line "Badges? We don't need no stinkin' badges!" come from? Mel Brooks "Blazing Saddles" Tony V. |
Don't be misleading.
If someone tries to claim a badge using an EW and a 'mouse type GPS' it will be rejected. The IGC approval of the EW barographs requires the use of a GPS off an approved list. The approved list GPS's output a proprietary NMEA sentence for selected map datum which is recorded by the logger to stop people displacing turnpoints by changing map datum in flight. I'm not saying this is the way it should be, there is an argument for COTS loggers, but this is the way it is, you can't claim a badge with an EW and just any old GPS. At 08:54 16 September 2005, Jancsika wrote: ttaylor at cc.usu.edu wrote: I have old cameras you can have if you want them and I have an EW-D logger you can barrow if you would like to try some badge flights. All you need is a Garmin GPS to feed a signal to it. Or any other cheap mouse type GPS. The final igc file will be fine ![]() This badge&cheap GPS issue come up year by year. Few enthusiastic pilot joined and created COTS proposal to IGC but nothing has changed so far ![]() /Janos |
![]() Hehe, if there is no datum change from the GPS (like in case of most of the mouse type GPS) the final igc file will be the same as if it were from an approved Garmin. This is what I said. Yes, it's against the current rules, but who cares. Let's have their fun with the valid igc file ![]() /jancsika Andrew Warbrick wrote: Don't be misleading. If someone tries to claim a badge using an EW and a 'mouse type GPS' it will be rejected. The IGC approval of the EW barographs requires the use of a GPS off an approved list. The approved list GPS's output a proprietary NMEA sentence for selected map datum which is recorded by the logger to stop people displacing turnpoints by changing map datum in flight. I'm not saying this is the way it should be, there is an argument for COTS loggers, but this is the way it is, you can't claim a badge with an EW and just any old GPS. At 08:54 16 September 2005, Jancsika wrote: ttaylor at cc.usu.edu wrote: I have old cameras you can have if you want them and I have an EW-D logger you can barrow if you would like to try some badge flights. All you need is a Garmin GPS to feed a signal to it. Or any other cheap mouse type GPS. The final igc file will be fine ![]() This badge&cheap GPS issue come up year by year. Few enthusiastic pilot joined and created COTS proposal to IGC but nothing has changed so far ![]() /Janos |
I realise you are just trying to recruit disgruntled
pilots to the COTS cause. They will be disgruntled because their NAC will have rejected their claim. I'll say it again, clearer this time and using shorter words. The EW will log with any GPS but it will only make an IGC file valid for a badge claim with one of the approved GPS's, your NAC will reject a claim made with an EW and any non approved GPS. You could, in theory, build a circuit to inject valid datum sentences into the EW, but any OO who let you get away with it shouldn't be an OO and it's more effort than just using an approved GPS. At 10:24 16 September 2005, Jancsika wrote: Hehe, if there is no datum change from the GPS (like in case of most of the mouse type GPS) the final igc file will be the same as if it were from an approved Garmin. This is what I said. Yes, it's against the current rules, but who cares. Let's have their fun with the valid igc file ![]() /jancsika Andrew Warbrick wrote: Don't be misleading. If someone tries to claim a badge using an EW and a 'mouse type GPS' it will be rejected. The IGC approval of the EW barographs requires the use of a GPS off an approved list. The approved list GPS's output a proprietary NMEA sentence for selected map datum which is recorded by the logger to stop people displacing turnpoints by changing map datum in flight. I'm not saying this is the way it should be, there is an argument for COTS loggers, but this is the way it is, you can't claim a badge with an EW and just any old GPS. At 08:54 16 September 2005, Jancsika wrote: ttaylor at cc.usu.edu wrote: I have old cameras you can have if you want them and I have an EW-D logger you can barrow if you would like to try some badge flights. All you need is a Garmin GPS to feed a signal to it. Or any other cheap mouse type GPS. The final igc file will be fine ![]() This badge&cheap GPS issue come up year by year. Few enthusiastic pilot joined and created COTS proposal to IGC but nothing has changed so far ![]() /Janos |
I realise you are just trying to recruit disgruntled pilots to the COTS cause. They will be disgruntled because their NAC will have rejected their claim. You are right more or less ![]() (otherwise fantastic) expensive tool for this purpose. I'll say it again, clearer this time and using shorter words. The EW will log with any GPS but it will only make an IGC file valid for a badge claim with one of the approved GPS's, your NAC will reject a claim made with an EW and any non approved GPS. You could, in theory, build a circuit to inject valid datum sentences into the EW, but any OO who let you get away with it shouldn't be an OO and it's more effort than just using an approved GPS. No, EW WILL create valid IGC file with any GPS provides (RMC, GGA) NMEA sentences at 4800. EW could recognize if there is a change in datum if you use a garmin, because garmin sends this information inside NMEA. I can send samples if you need. There is no need to create any special circuit. And I think at least 99% of the OO will accept it. /jancsika (finally a Colibri user) |
At 06:24 20 September 2005, Jancsika wrote:
Eric Greenwell wrote: Jancsika wrote: Or any other cheap mouse type GPS. The final igc file will be fine ![]() This badge&cheap GPS issue come up year by year. Few enthusiastic pilot joined and created COTS proposal to IGC but nothing has changed so far ![]() Like it, or not, if one wants to get a badge with an EW, one must use one of the Garmin GPS units listed in the approval document... Marc It's just funny to see the weakness of the system... It's my understanding the IGC file will NOT be fine if a mouse type GPS is used, because it will be missing the NMEA sentence with the datum that is in use. With a Garmin GPS, the sentence is not sent only when the datum is changed, but with every data point. I also suspect the Garmin GPS sends a sentence identifying itself, which is recorded in the file, but I don't know that for sure. Perhaps Marc or other knowledgeable person can comment? At startup some GPS sends (even a cheap mouse type could do it) this data but to get a valid IGC file boot messages doesn't have to be in the NMEA stream. I sent you one example (Vali-ewa.exe validated this). Regards, /Janos Here we go again. Vali-ewa.exe only checks the hash of the file against the G line, if there are no datum records in the file your OO or the NAC's badge secretary should reject the claim. |
Andrew Warbrick
Here we go again. Vali-ewa.exe only checks the hash of the file against the G line, if there are no datum records in the file your OO or the NAC's badge secretary should reject the claim. Hmm, and why does it print this info same cases? "The following fixes are not recorded as being relative to the WGS84 geodetic datum. Care should be taken that these fixes are not used to validate the flight. 22 fixes from 05-04-04 11:22:59 UTC to 05-04-04 11:24:02 UTC inclusive. EW Flight Recorder security checks indicate file '544E7AM3.igc' is VALID." |
At 08:36 20 September 2005, Jancsika wrote:
Andrew Warbrick Here we go again. Vali-ewa.exe only checks the hash of the file against the G line, if there are no datum records in the file your OO or the NAC's badge secretary should reject the claim. Hmm, and why does it print this info same cases? 'The following fixes are not recorded as being relative to the WGS84 geodetic datum. Care should be taken that these fixes are not used to validate the flight. 22 fixes from 05-04-04 11:22:59 UTC to 05-04-04 11:24:02 UTC inclusive. EW Flight Recorder security checks indicate file '544E7AM3.igc' is VALID.' That's interesting, it would appear I was wrong. Are you saying that file was generated with a 'mouse GPS' and contains more than 22 fixes? I was under the impression the datum record would only be generated by Garmin's proprietary PGRMM sentence. My 'mouse GPS', based on the SiRF chipset definitely can't output this sentence. I'm afraid I can't do any testing, as I haven't owned an EW for nearly four years now. If you've got sample files, feel free to send me a copy (I do have some old files generated with an IGC upgraded EW model B and a GPS from the approved list). |
First badges 2005 Marfa, TX | Burt Compton | Soaring | 0 | January 2nd 05 02:28 PM |
Cheap GPS Loggers for FAI Badges - Status? | Papa3 | Soaring | 154 | June 17th 04 10:33 PM |
Cheap GPS Loggers for FAI Badges - FAI Footdragging | stephanevdv | Soaring | 1 | June 9th 04 01:44 PM |
GPS Hand Held for Badges | Papa3 | Soaring | 17 | June 1st 04 09:12 PM |
