If you were really smart you would have ditched your pump and installed
the Aeon pump instead. More expensive than the normal dry pump but the next best thing to a wet pump. abripl wrote: Just a warning for those who might consider purchasing Rapco dry vacuum pumps. Make sure that your engine does not leak oil. If there is any chance of an oil drip onto the Rapco vacuum pump it may eventually stop working. The connecting shaft is vented to air. But if some oil drops on the shaft it may get sucked into the pump and after the oil dries it may seize the pump. I puchased a 216CW new pump from Spruce and after 20 hours of use it does not work. After returning it to Rapco they said it was "oil contamination" and not eligible for warranty service, but offered to replace it at a discount. They really ought to have a better seal there to prevent the problem. |
...you would have ... installed the Aeon pump instead
Actually I removed the vac pump and went to all electric - saved some weight. But I do think that Rapco or any mfg should prevent something like that with a seal. Did you check the Aen pump for oil drip problems? Do they warranty against oil entry? |
Rapco can't put any serious seal on that pump that would last any
time because it's a dry pump, and seals need some lube. Rapco does have a pump to fit the under-nose mountings like the O-200, where oil tends to get into the pump, and that pump has a flinger and a drain port to keep oil out. Washing the engine with solvent can also wreck the pump. It needs to be covered during spraydown. We use Rapco pumps exclusively on five airplanes, and have no trouble at all reaching 1000 hours. Basically, your oil leak need fixing. Oil leaks represent an attraction for dirt, which does no engine any good, and they're a fire hazard. And some oil leaks are warnings to fix something before it blows off completely and all the oil is lost overboard in flight. Dan |
Rapco can't put any serious "seal" on that pump...
... [They have a]... pump has a "flinger and a drain port" to keep oil out... I don't care what its called - it should be on there. Is the manufacturing cost of such feature so significant? I don't recall any warnings that came with my new Rapco pump about simple oil drip hazards or about a special pump model required. I only found out when warranty service was denied. ...Basically, your oil leak need fixing..... No kidding. But while you are trying to fix it or if you are unaware of oil leaks you take a flight risk with the pump. Engines can START leaking and ruin these "sensitive" pumps. A lot of homebuilders, like me, have initial leaks until they are found and fixed - its not a lack of trying. This post is a warning to others about the risk they may take with such pumps - unless they are 100% sure their engine does not leak and never will leak. Even if they find/fix the leak quickly they will not know if the pump is OK, since the pump tends to work for a while after oil gets in there. |
![]() "abripl" wrote in message oups.com... Rapco can't put any serious "seal" on that pump... ... [They have a]... pump has a "flinger and a drain port" to keep oil out... I don't care what its called - it should be on there. Is the manufacturing cost of such feature so significant? I don't recall any warnings that came with my new Rapco pump about simple oil drip hazards or about a special pump model required. I only found out when warranty service was denied. ...Basically, your oil leak need fixing..... No kidding. But while you are trying to fix it or if you are unaware of oil leaks you take a flight risk with the pump. Engines can START leaking and ruin these "sensitive" pumps. A lot of homebuilders, like me, have initial leaks until they are found and fixed - its not a lack of trying. This post is a warning to others about the risk they may take with such pumps - unless they are 100% sure their engine does not leak and never will leak. Even if they find/fix the leak quickly they will not know if the pump is OK, since the pump tends to work for a while after oil gets in there. Any good mechanic can find an oil leak its not that hard. |
? Any good mechanic can find an oil leak its not that hard.
You miss the point. After you find it, it may already be too late because the oil might have leaked on the pump. So anytime you discover a (new) leak you cannot be sure that the pump was not contaminated. The only sure way is to replace the pump. This is not necessary if Rapco designed the pump to reject accidental oil spillage. |
In article .com,
"abripl" wrote: You miss the point. After you find it, it may already be too late because the oil might have leaked on the pump. So anytime you discover a (new) leak you cannot be sure that the pump was not contaminated. The only sure way is to replace the pump. This is not necessary if Rapco designed the pump to reject accidental oil spillage. As far as I know, engines shouldn't leak oil in this location, so why would Rapco or anyone else waste time designing a pump that is immune to it? It seems that the solution would be to fix the real problem, the oil leak, and simply replace the (relatively inexpensive) pump. If you don't know how to fix the oil leak the first time, you may want to consult with an experienced mechanic. JKG |
Problems with Rapco dry vacuum pumps. | abripl | Home Built | 28 | September 25th 05 05:29 AM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
Dual vacuum pumps bad news | Javier Henderson | Owning | 3 | May 7th 04 09:06 PM |
Low vacuum at idle | Chad Lemmen | Owning | 1 | August 18th 03 09:24 PM |
