required eqipment for ifr
Old December 15th 03, 04:27 AM
Roy Smith
Andrew Gideon wrote:
It's certainly time well spent to *really* learn the GPS. But a good NDB
approach, or hold, is quite satisfying. Given the choice of which to
carry, I'd pick the GPS. But if I have the NDB, I'll use it.
The question is not whether there is greater than zero value in NDB.
It's clear that there is. As for satisfaction, well yes, I agree that
there is satisfaction in mastery of almost any skill. That's why I
learned how to work a sextant. Am I ever going to use that skill for
real? Hardly, but it sure is satisfying to spend half an hour working a
round of sights and getting a nice tight fix (say, under a mile probable
error).
The question is whether it's worth investing the time it takes to master
it. Especially when that time could be spent mastering a tool which
provides such a vastly greater amount of information, utility, safety,
etc. It's pretty much a zero sum game. If you spend an hour working on
one thing, that's one hour less you get to spend on something else.
Of course, if the student *wants* to learn how to fly NDB approaches, I
see nothing wrong with teaching them, as an optional part of the
curriculum. I just don't see the point of making it required.
My club recently voted to get rid of all our ADFs. We'll keep them in
the planes as long as they work, but won't spend any more money fixing
them when they break.
Old December 15th 03, 03:25 PM
Andrew Gideon
real? Hardly,
Well...it's getting unlikely for me too. The club to which I belong has
also adopted the "if it breaks, don't fix it" mentality. I think that a
bit of a shame, but it's true that I'd rather spend maintenance dollars
elsewhere.
Oh, see, I don't see it as a zero sum game (excluding maintenance costs).
Part of why I fly is that satisfaction of flying well. Circular, I know,
but true nevertheless. So getting/staying good at using the NDB - as long
as I have one grin - is a reason to fly. I suppose it's my version of a
$100 burger.
Hmm...that's more a function of the airplane, right? As I understood it,
the DE could test me on anything in the aircraft. Since I was flying with
a GPS, I had to be able to use it. I was also flying with an ADF, so I had
to be able to use that.
[Actually...I might not have flown with a GPS. Now that I think on it, the
one 172S with a GPS at my FBO at the time was on a trip. So I took the
checkride in an airplane with DME and ADF, but no GPS. And yes, one of my
checkride approaches was an NDB (into MGJ, I think).]
[Actually, the DE snuck in an extra approach, counting the one we did
getting back to CDW. I think he didn't expect that we'd be able to get
that one from ATC.]
Perhaps we can just convince our respective clubs to "get it over with" and
go for the new Garmin glass panel in our aircraft.
- Andrew
Old December 15th 03, 04:37 PM
PaulaJay1
In article , Roy Smith
writes:
That's why I
error).
I did the same thing re the sextant, Roy. Did it for fun on my sailboat. Then
found that I couldn't work up the sights till I got back to land. I'd go down
into the cabin and start to figure and the stomach would not sit still. It
isn't much good to know "where you were".G
Chuck
Old December 15th 03, 11:47 PM
Michael
error).
The real question is - did you learn things about navigation by
learning to work a sextant that you would not have learned otherwise,
and are those things important? Some (maybe most) students have to
have VOR triangulation explained to them. Clearly some never learn,
or forget - I have a friend who works at a FSS that long ago lost DF
steer capability, and he has to talk pilots through the procedure on a
regular basis. On the other hand, I bet you intuitively grasped the
procedure without having it explained, and immediately understood the
impact of geometry on the accuracy of the fix.
It's really not possible to do an NDB approach acceptably unless you
really understand the difference between heading, bearing, course, and
track - not in the sense that you can parrot back dictionary
definitions on the ground, but in the sense that you immediately
understand what the differences are and what's important. Can those
things be learned without the NDB? Certainly - but the pilot who has
learned and internalized those things finds an NDB approach easy, even
if he has never done one before. On the other hand, a pilot who gets
those things confused is going to have no end of trouble with NDB
approaches. He might well need 10 hours of training before he can do
them. He's not learning to do NDB approaches - he's learning to
maintain situational awareness in real time with minimal resources.
Is that important? I think it is. If I had a dollar for every time
I've ever had to tell an instrument student "Just because the needle
is centered does not mean you're flying the right heading..."
Actually, flight instructor compensation being what it is, I probably
do. More to the point, an awful lot of pilots seem to lose
situational awareness and crash. Loss of situational awareness is
probably the single biggest killer in IMC.
I suppose one day we will all have multiply redundant moving maps, and
at that point the ability to maintain situational awareness with
minimal resources may not be important anymore. I don't believe that
day is here yet, and it may never come.
I've also heard the argument that the time is better spent learning
GPS. I don't believe that. First of all, even a moving map GPS is no
substitute for situational awareness. I've seen an instrument student
using an IFR moving map GPS turn the wrong way on a published segment
and proceed to descend while going away from the airport.
Second, flying a GPS approach is trivial. It's just like a VOR
approach, except that the radial is perfectly straight, there is no
zone of confusion, and you get a constant readout on distance to the
next fix. The hard part of flying GPS approaches is working the user
interface on the box - and they're all different.
In my opinion, the most important reason to retain the ADF in the
instrument trainer is as a hedge against the generally low quality of
instrument instruction. A good instrument instructor can teach good
situational awareness habits even without it, just as a good primary
instructor can teach good takeoff and landing habits without a
tailwheel. But the lack of an ADF, like the lack of a tailwheel,
allows a student to get by with sloppy habits if the instructor
doesn't intervene.
Michael
Old December 17th 03, 10:40 PM
Andrew Gideon
Michael wrote:
Is that important?
How interesting. Your reasoning on this matter is quite similar to why I
think programmers/computer-scientists should still learn assembler
programming and other "low level" skills.
Understanding how and why one's tools work can often be important in
understanding them - and therefore in using them properly.
- Andrew
Old December 15th 03, 07:41 AM
Larry Fransson
I'm surprised nobody made the obligatory FAR reference: 91.205(d).
Larry Fransson
Seattle, WA
Old December 15th 03, 03:53 PM
paul k. sanchez
Larry Fransson
Seattle, WA
Larry:
Since you asked. My favorite is 91.205 (e) which refers to DME requirements
at/above FL240 but only if using VOR navigation. I love it when I explain to
other lesser knowing instructors that a great many aircraft do not have DME but
yet they do have IFR clearances at/above FL240. The trick is not use VOR
navigation.
How poorly understood, worst so how poorly taught.
§91.205 Powered civil aircraft with standard category U.S. airworthiness
certificates: Instrument and equipment requirements.
(d) Instrument flight rules. For IFR flight, the following instruments and
equipment are required:
(1) Instruments and equipment specified in paragraph (b) of this section, and,
for night flight, instruments and equipment specified in paragraph (c) of this
section.
(2) Two-way radio communications system and navigational equipment appropriate
to the ground facilities to be used.
(3) Gyroscopic rate-of-turn indicator, except on the following aircraft:
(i) Airplanes with a third attitude instrument system usable through flight
attitudes of 360 degrees of pitch and roll and installed in accordance with the
instrument requirements prescribed in §121.305(j) of this chapter; and
(ii) Rotorcraft with a third attitude instrument system usable through flight
attitudes of ±80 degrees of pitch and ±120 degrees of roll and installed in
accordance with §29.1303(g) of this chapter.
(4) Slip-skid indicator.
(5) Sensitive altimeter adjustable for barometric pressure.
(6) A clock displaying hours, minutes, and seconds with a sweep-second pointer
or digital presentation.
(7) Generator or alternator of adequate capacity.
(8) Gyroscopic pitch and bank indicator (artificial horizon).
(9) Gyroscopic direction indicator (directional gyro or equivalent).
(e) Flight at and above 24,000 ft. MSL (FL 240). If VOR navigational equipment
is required under paragraph (d)(2) of this section, no person may operate a
U.S.-registered civil aircraft within the 50 states and the District of
Columbia at or above FL 240 unless that aircraft is equipped with approved
distance measuring equipment (DME). When DME required by this paragraph fails
at and above FL 240, the pilot in command of the aircraft shall notify ATC
immediately, and then may continue operations at and above FL 240 to the next
airport of intended landing at which repairs or replacement of the equipment
can be made.
(f) Category II operations. The requirements for Category II operations are the
instruments and equipment specified in --
(1) Paragraph (d) of this section; and
(2) Appendix A to this part.
(g) Category III operations. The instruments and equipment required for
Category III operations are specified in paragraph (d) of this section.
(h) Exclusions. Paragraphs (f) and (g) of this section do not apply to
operations conducted by a holder of a certificate issued under part 121 or part
135 of this chapter.
paul k. sanchez, cfii-mei
on eagles’ wings
2011 south perimeter road, suite g
fort lauderdale, florida 33309-7135
305-389-1742 wireless
954-776-0527 fax
954-345-4276 home/fax
Old December 15th 03, 08:14 PM
Ralf S.
You're lucky guys in the US. That's what is required in Germany for a IFR
certified "little" Cessna:
It only lists the radio/navigational equipment:
- 2 Radios for simultaneous use
- 2 VOR's
- 1 ADF
- Transponder Mode A/C or Mode S
- 1 DME
Isn't that a little bit strange? Even if you don't need it you will have to
have it.
What do you think? In my opinion that's why you pay for a IR rating about
15 - 20000 bucks in Germany.
Ralf
"Mark" schrieb im Newsbeitrag
news
I was looking at starting my ifr training and realized the 172s in the
club I blelong to don't have DMEs. Is that required for IFR flight? I
noticed alot of checkpoints and such are distance from navaid.
Thanks
Mark
Old December 15th 03, 08:18 PM
David Megginson
- 2 VOR's
- 1 ADF
- 1 DME
have it.
It actually sounds like a normal 172 or Cherokee avionics stack -- it's
exactly what my Warrior II came with when I bought it. Every IFR-certified
rental plane I've seen has this equipment, +/- the DME (which is hit or miss).
An instrument rating in Canada is about 40 hours' instruction (at around USD
30/hour) plus rental time, ground school, and a few fees. Most pilots
already have 10 hours IFR from the PPL and 5 from the night rating, so
practically, it's around 25 hours, though there will probably be 4-5 hours
of ground briefing added on.
All the best,
David
Old December 15th 03, 08:36 PM
Ralf S.
Yeah, sounds much better. That's why I will do it somewhere in the US.
Here in Germany many airplanes are not equiped for IFR. Most of them have
only one VOR and one radio. Maybe a ADfF but not too many have a DME. And as
you can imagine the new ones that are equiped are more expensive. So for one
hour IFR you'll have to count with 200 EUR and more per hour.
rgds
ralf
"David Megginson" schrieb im Newsbeitrag
able.rogers.com...
- 2 VOR's
- 1 ADF
- 1 DME
to
have it.
about
IFR-certified
miss).
USD
All the best,
David
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
Inconol 713 required Martin Home Built 18 January 7th 04 05:38 AM
required readback on clearance [email protected] Instrument Flight Rules 15 September 17th 03 04:33 PM
Why is ADF required on ILS approach? Rich Raine Instrument Flight Rules 27 August 1st 03 05:14 PM
Radio license required? Marty Ross Instrument Flight Rules 10 July 17th 03 09:58 PM
