Hey guys, I am thinking on giving a seminar on Tilt-Rotor Aircrafts as
a part of my Mechanical Engineering Final Year Syllabus. However all the info i found on the net (read Google) deals with the BA-609 and the Osprey specifically and not with the concept of Tilt Rotors. Can anyone help me out? The seminar has to be about 20 pages long. |
The predecessor to the V-22 and the BA609 was the XV-15 NASA program. NASA is a great sourse for information. So is AHS International. AHS has published papers from on tiltrotor reserch from many sources, not just Bell and Boeing. Good luck, CTR |
You may wish to consider tilt-rotor patents; at
http://www.uspto.gov/patft/index.html A few are; Sikorsky's Variable diameter rotor blade actuation system ~ 6,019,578 VTOL airplane with only one tiltable prop-rotor ~ US 6,382,556 Optimum speed tilt rotor ~ US 6,641,365 wrote in message Hey guys, I am thinking on giving a seminar on Tilt-Rotor Aircrafts as a part of my Mechanical Engineering Final Year Syllabus. However all the info i found on the net (read Google) deals with the BA-609 and the Osprey specifically and not with the concept of Tilt Rotors. Can anyone help me out? The seminar has to be about 20 pages long. |
There are many American Helicopter Society technical papers that have
been given at the AHS annual forum over the years, several at a level which would be right for undergraduate work. Ask your school librarian for help, these are usually available in a few days. Also, Stepniewski and Keys "Rotary Wing Aerodynamics" (Dover publications) has a major section on tilt rotor design aspects. Nick Lappos For some broad performance comparisons between helicopters and tilt rotors and supporting sites, see my site: http://webpages.charter.net/nlappos/Disk-Loading.pdf wrote: Hey guys, I am thinking on giving a seminar on Tilt-Rotor Aircrafts as a part of my Mechanical Engineering Final Year Syllabus. However all the info i found on the net (read Google) deals with the BA-609 and the Osprey specifically and not with the concept of Tilt Rotors. Can anyone help me out? The seminar has to be about 20 pages long. |
Thanks a lot Nick.....your comparison was really an eye-opener, so much
so that I am now wondering on whether I should change my topic...any suggestions......(I will be seeking admission for MS in the Aerospace in fall 2006....I guess having a related topic would help.) |
That performance comparison should take little away from the reason why the
Marines are going toward the V22, it has the speed, and they have the mission. It just makes sure that we all recognize the reduction in efficiency and the cost of that speed. I do think that tilt rotors will have their place in the spectrum. Good luck on your paper. Look at the AHS Forum papers for lots of data to help your paper. What school are you attending? Nick "Nishant" wrote in message oups.com... Thanks a lot Nick.....your comparison was really an eye-opener, so much so that I am now wondering on whether I should change my topic...any suggestions......(I will be seeking admission for MS in the Aerospace in fall 2006....I guess having a related topic would help.) |
Should the subject of your seminar be 'future rotorcraft', you may wish to
focus on the coming ability of blades to vary their angle of attack at desecrate locations, as defined by the rotor's polar coordinates. Radial positions being set by active blade twist etc. and azimuthual positions being set by higher harmonic control etc. IMHO, when these two abilities become operationally viable, the two most promising rotor configurations will be the Intermeshing for light agile craft and the Interleaving for fast transport craft. |
.... to vary their angle of attack at desecrate locations, ....
Opps! Where's the Edit button? 'desecrate' sound a little to negative. Please substitute 'discrete' in the above post. ![]() |
Nishant,
If you intend to use data you have collected over the internet to support your Mechanical Engineering Final Year Syllabus, I recommend that you stick to published data from sources like SAE, NASA or AHS. Referencing data, opinions or conclusions from individuals personal web sites is not a good idea. Do your own research of from reputable data sources and then draw your own conclusions. Good luck, CTR |
For those willing to take a close look at Nick Lappos's presentation
and it's referenced supporting data, please note the following: 1) The 1,050 KM range shown for the CH-53 in Nick's presentation is with additional internal and external aux tanks installed. Using only normal internal fuel tanks, the CH-53 ferry range is only 590 KM. 2) The 1,030 KM V-22 ferry range shown in Nick's presentation is actually 2 X the 515 Amphib Assault mission range. With internal ferry tanks installed the V-22 ferry range is 2,100 KM. Twice that of the CH-53. 3) The 1,150 KM ferry range shown for the MILITARY UH-60L in Nick's presentation is with four additional 230 gallon external aux tanks installed. Using only normal internal fuel tanks, the UH-60L ferry range is only 290 KM. 4) The 750 KM ferry range shown in Nick's presentation for the CIVIL BA609 is with using only current internal fuel tanks. This is almost three times the UH-60L ferry range. With internal tanks planned for the Military BA609 version, ferry range is increased to 1,000 KM. In short, for Nick's presentation, using as many internal and external aux fuel tanks as possible for the CH-53 and UH-60L is acceptable. But the use of even additional internal aux tanks on V-22 or BA609 is prohibited. So Nishant, do your own research before you draw any conclusions. Don't take anyone's opinion (even mine) until you look closely at all reliable data sources. Good luck, CTR |
| Thread Tools | |
| Display Modes | |
| EW model "D" IGC approved flight recorder- info needed | MC | Soaring | 0 | March 7th 05 08:14 PM |
| Ball 620H vario info needed | Ray | Soaring | 0 | December 16th 04 04:13 PM |
| Info needed: Slingsby Sky | Erwin Janssen | Soaring | 0 | January 13th 04 09:35 PM |
| Groom Lake/area 51 Migs from 70s info needed | Aerophotos | Military Aviation | 23 | September 13th 03 06:16 PM |
| RB-47H info needed for model | Matt Wiser | Military Aviation | 0 | August 3rd 03 04:54 AM |
