Warrior cruise RPM settings
Old October 6th 05, 09:32 PM
Jay Honeck
What is "overspeed" on a fixed prop?
Same thing it is on a constant speed prop: the engine exceeds its maximum
allowed RPM.
Let me try that again. How can you overspeed an engine with a (properly)
fixed pitch prop?
"Max RPMs" on an O-320 (and, in fact, all aircraft engines) are so
retarded that the engine is really just loping along at 2700 rpm.
That's simply not true. In fact, the engine manual for any engine has
very specific guidelines about what the true maximum RPM is and how much
you can exceed that for how long before requiring some kind of
maintenance. These numbers are not far above the indicated redline.
I'm just passing along what my A&P has told me. He's got 42 years in the
engine rebuilding business, and is an award winning home builder and antique
aircraft restorer. According to him, our Lycoming/Continental engines are
purposefully designed to be slow-turning engines -- even at full throttle --
in order for them to survive all the way to TBO.
There is no harm running an O-320 with a fixed pitch prop at full throttle.
You'll make more noise, burn more gas, and go (a little) faster.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 6th 05, 10:48 PM
Peter Duniho
"Jay Honeck" wrote in message
news:GZe1f.405624$_o.128570@attbi_s71...
fixed pitch prop?
In level cruise, full throttle is sufficient in some aircraft (may or may
not be in the particular Warrior in question). Even if full throttle is
not, anything that increases airspeed at full throttle is sufficient:
descent (intended or not) or wind shear, for example.
A propeller -- fixed-pitch, variable pitch, constant speed, whatever --
provides a load on the engine which in turns keeps the RPM below the
designed maximum. As airspeed increases, this load is reduced. Some
propellers (constant speed, for example) can increase blade pitch to
compensate and maintain a constant load on the engine. But a fixed-pitch
propeller does not have this option; RPM is determined solely by airspeed
and power setting. If you increase airspeed without reducing the power
setting, the RPM will increase (and of course, as I stated above, in some
installations full-power throttle is sufficient to exceed the designed
maximum RPM when in level cruise flight).
antique aircraft restorer. According to him, our Lycoming/Continental
engines are purposefully designed to be slow-turning engines -- even at
full throttle -- in order for them to survive all the way to TBO.
Your interpretation of even the statement you're attributing to your A&P
(and that's assuming you understood him correctly) doesn't support your
previous statement. An engine designed to turn at low RPM does not preclude
it being harmed at high RPM, and in fact if the design calls for low RPM
it's entirely possible (likely, even) that exceeding that low RPM would harm
the engine.
Beyond that, the reasoning given in your description of his statement is
flawed in any case. The primary reason aircraft engines turn slowly is so
that they match the needs of the propeller without adding a gearcase to the
installation.
throttle. You'll make more noise, burn more gas, and go (a little) faster.
Provided you do not exceed the manufacturer-determined maximum RPM, I will
agree with you 100%. However, one needs to be careful not to exceed that
maximum RPM, and running full-throttle makes it easier to exceed that
maximum RPM.
Pete
Old October 7th 05, 12:01 AM
Jose
fixed pitch prop?
Push the nose down?
Jose
Get high on gasoline: fly an airplane.
Transmittion Noise - High Power Settings Paul Smedshammer Owning 6 August 20th 05 07:17 PM
Lycoming's views on best economy settings [email protected] Piloting 37 July 8th 04 05:00 PM
Power settings for 182RG Andrew Gideon Piloting 19 March 3rd 04 08:41 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 06:04 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 05:14 AM
