"O. Sami Saydjari" wrote in
: When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. That's right... 2 knots increase in TAS per 1000 feet MSL is a rough guideline, but good enough for calculations. Note that this only holds true, however, for altitudes where you can hold the same power output. This means, all other things being equal, that the most efficient altitude is the maximum one at which you can still output your desired power. For a normally aspirated aircraft flying at 75% or 65% power, we are looking at between 5500 and maybe 8500 feet MSL. For your turbo Arrow it depends on the condition of your turbocharger and whether you have a Merlyn wastegate or not. With a Merlyn you can easily hold 75% well up into the flight levels. So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? Right, but only a small part of the story. How bad is the thermals and other turbulence at the altitude you want to fly. How hot is it? [In Texas we often see 80+ degrees at 10,000 or higher.] Are you out sightseeing, or trying to get somewhere. Icing? Thunderstorms around (and do you have 'sferics equipment on board). How far are you going (is it worth the time/fuel to climb)? Other reason to want to climb high? [Like bad terrain at night.] Do your passengers like sucking on an O2 hose? And of course, which way is the wind blowing!!! Lots of things to consider, and often not just one "right" answer. Purely my own habit (also in a turbo Arrow III) I will fly anything over an hours trip at least around 10,000 unless there is a big reason no to (high winds). Gives good speed and ride (usually) without too much time-to-climb. Over that, especially if by myself, I will climb up to the O2 levels (again, depending upon wind). Long trips - ALWAYS go high unless you are really fighting a massive headwind. This time of the year, flying from Austin to El Paso (450 nm west of here) in the winter (winds almost always out of the west up high) - I will fly out there (west) at around 10K. That gives me acceptable headwinds, while still keeping me high enough over the Davis mountain range to avoid most turbulence. Coming back I will climb into the flightlevels, pull back the power, and look for a 75+ knot tailwind. [One trip I had a nice 250 - 275 knot groundspeed, on 55% power!!!] BTW, some years ago I put all my flight characteristics into a small computer program and just sat there playing with the results. For a flight of X miles was it faster to climb to Y altitude, etc. Taking into account the slower climb, the faster cruise, and the glide - figured time and fuel. [Remember, this is always a no-wind simulation, since it was a hypothetical trip.] The results was not what I expected. Turned out that for anything much over about 50 miles higher was pretty much always better. Time was shorter the higher you went (descent doesn't buy back all the time you lose on the climb, but it gets back a LOT of it). Fuel burn was minimized at the highest altitude where you had anything over 1/3rd of your time in cruise. -- ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
Optimal Frequency of Lessons | David B. Cole | Aerobatics | 18 | October 28th 04 12:50 AM |
Sparkplug picking tool | Michael Horowitz | Home Built | 3 | November 1st 03 01:51 PM |
Center vs. Approach Altitudes | Joseph D. Farrell | Instrument Flight Rules | 8 | October 21st 03 08:34 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
