Garmin 396 Glitch??
Old October 20th 05, 10:43 PM
Jonathan Goodish
Default Garmin 396 Glitch??
In article .com,
"Jeff B" wrote:
Has anyone experienced significant "loss of signal" hiccups with their
new 396?? Since getting ours a few months ago, we have had
several...some lasting 15-20 minutes. System shutdowns/start ups may
or may not re-initialize it. THe antenna is unobstructed and in plain
view of the sky. An older Garmin is still in our plane and works fine
so its not some GPS system glitch.
I've been using the 396 for almost 2 months, and I haven't had a loss of
GPS signal in flight EXCEPT when I was using the "stick" GPS antenna on
the unit. Since I switched to the external patch antenna, I've had no
problems. However, I have continuously updated the software, so I would
recommend that you update to the latest software (v2.60) and try again.
I seem to recall that the 296 had a similar issue when it was new, and
that successive software updates eventually fixed it. I would be
surprised if that same issue exists in the 396 with current software.
JKG
Old October 21st 05, 04:03 AM
Aluckyguess
I used to get that problem with the stick antenna flying north. I started
using the other antenna and the problem went away.
"Jonathan Goodish" wrote in message
In article .com,
JKG
Garmin 396 Glitch?? Jeff B Piloting 55 November 11th 05 08:19 PM
Garmin 96c glitch? Barry Piloting 2 January 11th 05 09:11 PM
Garmin 96c glitch? Barry General Aviation 0 January 11th 05 06:27 AM
Garmin 96c glitch? Barry Rotorcraft 0 January 11th 05 06:24 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
