I had a strange experience with our CNX-80 earlier today. Heading back
into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? |
"Roy Smith" wrote in message ...
I had a strange experience with our CNX-80 earlier today. Heading back into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? Without going out to the airport, I can't check my CNX-80. However, my JeppView charts show 126.4 on all the KDXR approaches, and all the KHPN approaches show 126.4 for the hours 0700-2300. So the 126.4 didn't get dropped completely from Jeppesen's master database. |
FYI
I reported here some trouble with airport data in my King cycle 0510, that King blamed on Jeppesen. I recently received another reply from King that the data were corrected in cycle 0511 which is now available. I downloaded it and have confirmed that the problems I had seen before were indeed corrected... BTW, how do you do the cycle updates on the CNX-80? Does Garmin/Jeppesen use the same cycle number designations as I describe above? -- Cheers, John Clonts Temple, Texas N7NZ |
Roy Smith wrote:
I had a strange experience with our CNX-80 earlier today. Heading back into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? A few years ago there was a Jeppesen update that had Waterbury-Oxford (KOXC) over by Dutchess County (KPOU), almost 50 miles in error. Jeppesen said it was Garmin's problem, Garmin said it was Jeppesen's. When I asked Jepp who I should file the lawsuit against, it got fixed PDQ. Rip |
On Mon, 24 Oct 2005 02:48:09 GMT, "John R. Copeland"
wrote: "Roy Smith" wrote in message ... I had a strange experience with our CNX-80 earlier today. Heading back into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? Without going out to the airport, I can't check my CNX-80. However, my JeppView charts show 126.4 on all the KDXR approaches, and all the KHPN approaches show 126.4 for the hours 0700-2300. So the 126.4 didn't get dropped completely from Jeppesen's master database. That's why it is still required to have a paper version with you and not rely solely on the CNX-80 database. I have the CNX-80/MX20 system in one of the planes that I fly and I will not go out without having my paper ones with me. I have all too often seen reboots on the system when they were having some software issues with the integrated WSI weather causing the system to shut down. I have not seen an error like this yet, but that makes me feel even stronger about keeping my paper plates clipped on the yoke where they should be. Scott D. |
In rec.aviation.owning Roy Smith wrote:
: Anybody else seen this? I assume it's a problem with the database? Not with the CNX80, but I have an old M-3 approach which gets Jepp databases. I got home from a trip (not in the plane) and I had 3 UPS overnight letters leaning against my door. In each was a 1/2 sheet of paper from Jeppesen saying there was an enormous error in the latest cycle of database and to update NOW. I got one more envelope each day until I updated. -- Aaron C. |
On Sun, 23 Oct 2005 22:25:40 -0400, Roy Smith wrote:
I had a strange experience with our CNX-80 earlier today. Heading back into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? Roy, I just loaded the latest cycle (511) onto my datacard. Since I had it at home, I copied it into the simulator and 126.4 is not there, either. It IS listed on the JeppView plates. I don't understand why it is not on the CNX80. On another topic, have you noticed that you cannot select VTF until within 30 miles of the destination. I drove myself crazy yesterday going EPM-BGR. I dialed in the BGR ILS 33 Vectors procedure; but the box never sequenced away from my PPOS--KBGR flight path. Come to find out that was because I was more than 30 miles away (outside the terminal area). What I should have done was go back to the PROC page AFTER I got into the terminal area, and I would have seen the VTF smart key. I don't recall if you're an instructor, but having someone dial in a Vectors approach while outside the Terminal area might result in an interesting GOTCHA. Took a call to GarminAT and about an hour of playing with the simulator before I realized what I had done wrong on the flight. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote: I just loaded the latest cycle (511) onto my datacard. Since I had it at home, I copied it into the simulator and 126.4 is not there, either. Glad to know I'm not crazy. On another topic, have you noticed that you cannot select VTF until within 30 miles of the destination. I drove myself crazy yesterday going EPM-BGR. I dialed in the BGR ILS 33 Vectors procedure; but the box never sequenced away from my PPOS--KBGR flight path. I just perused the user manual and couldn't find anything about it, but I do recall reading that once (and noticing it in practice). I have this vague recollection that it's actually mandated behavior. I don't recall if you're an instructor Sometimes my students forget too :-) Took a call to GarminAT and about an hour of playing with the simulator before I realized what I had done wrong on the flight. I have found that most of what I know about the CNX-80 is as a direct result of some screw-up I made in the air and eventually puzzled out on the ground later. |
On Tue, 25 Oct 2005 21:15:47 -0400, Roy Smith wrote:
In article , Ron Rosenfeld wrote: On another topic, have you noticed that you cannot select VTF until within 30 miles of the destination. I drove myself crazy yesterday going EPM-BGR. I dialed in the BGR ILS 33 Vectors procedure; but the box never sequenced away from my PPOS--KBGR flight path. I just perused the user manual and couldn't find anything about it, but I do recall reading that once (and noticing it in practice). I have this vague recollection that it's actually mandated behavior. In the GNS480 manual, it is vaguely alluded to in the sidebar on P87, but it sure doesn't say that's the only time you can do it. As a matter of fact, in the example given on page 88, it seems to me there is a clear implication that one might have selected VTF mode outside of 30 miles. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Hi Roy
I was under the impression Jepp got it's information from the FAA. Al "Roy Smith" wrote in message ... I had a strange experience with our CNX-80 earlier today. Heading back into HPN, we tried to bring up the approach frequency 126.4, and discovered it wasn't in the database. There were the normal secondary freqs (120.8 and 124.65), but no 126.4. Then I looked up DXR (Danbury, right next door) which should have also had 126.4 listed, and found no approach freqs in the database at all. We called NY on 126.4 as normal, and they answered as usual, so I assume it's still in use. Anybody else seen this? I assume it's a problem with the database? |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Solution to DAFIF data going away? | Paul Tomblin | Piloting | 1 | June 5th 05 12:36 PM |
Jepp Flitemap - text labels, weird font sizes | Peter R. | General Aviation | 0 | May 4th 05 10:18 PM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
The Irony of Boeing/Jeppesen Being Charged User Fees! | Larry Dighera | Piloting | 9 | January 23rd 04 12:23 PM |
